Defining the Decision Context and Inputs
Lectura estimada: 6 minutos 50 vistas
When I walk into a project where the decision table is failing to capture edge cases, I rarely see misaligned conditions. I almost always find the root issue is a poorly scoped set of inputs—variables not clearly defined, boundaries undefined, or contextual constraints ignored. It’s not the rules that break; it’s the foundation.
Too many teams rush to write conditions without first asking: What exactly are we deciding? What factors matter? Who or what is being evaluated? The answers define the input space—and if the inputs are fuzzy, so is the entire table.
This chapter is built on over two decades of guiding teams through real-world rule modeling. You’ll learn how to identify decision variables, define their valid ranges, and establish context boundaries that prevent gaps and overlaps. You’ll also discover how to approach decision table setup with a rigor that scales from simple workflows to enterprise-grade logic.
Identifying the Core Decision Variables
Start not with a rule, but with the question: What decision are we actually making?
Ask yourself: What is the outcome we are trying to determine? Is it eligibility? Risk level? Approval status? The answer defines the decision context.
Once you know the decision type, extract the variables that influence it. These are your core decision table inputs.
For example, in a loan approval system, the decision is “approve loan.” The inputs might include:
  • Applicant income
  • Debt-to-income ratio
  • Credit score
  • Loan-to-value ratio
  • Employment duration
These aren’t just fields. They are decision variables—each capable of taking discrete values or ranges that must be formally defined.
Defining Decision Variables with Precision
Each variable must be defined in a way that’s unambiguous, measurable, and consistent across all rules. A common mistake is using vague terms like “high income” or “good credit.” These are not inputs—they are interpretations.
Instead, define variables with exact thresholds and clear data types:
Variable Definition Values/Ranges
Credit Score External bureau score (FICO) 300–850 (integer)
Debt-to-Income Ratio Monthly debt / Gross monthly income 0.0 to 1.0 (float, up to 2 decimals)
Employment Duration Years employed at current job 0.0 to 50.0 (float, 1 decimal)
By defining inputs this way, you eliminate ambiguity. Every rule can now reference credit score ≥ 700 or debt-to-income ratio ≤ 0.35—not “good” or “low.”
Setting Scope Boundaries and Context Constraints
Defining variables isn’t enough. You must also define the operational scope: what’s in, what’s out, and what’s assumed.
Consider a healthcare eligibility table. You might need to ask:
  • Are dependent children included in income calculations?
  • Do we consider part-time employment as sufficient for coverage?
  • Are applicants under 18 excluded by default?
These aren’t rules. They’re constraints that shape the input space.
Documenting Context with Input Constraints
Always document the assumptions and exclusions that define the decision context. These are not part of the rule logic—but they are essential for interpreting it correctly.
For example:
  • Eligibility Age: Must be 18 or older. Applicants under 18 are not eligible, regardless of income or coverage type.
  • Dependents: Only children under 19 are eligible as dependents. Adult dependents are not covered unless they are disabled.
  • Income Source: Only gross monthly income from employment is considered. Retirement, disability, or investment income does not qualify.
These constraints are not conditions to be evaluated. They are preconditions that must be enforced before any rule applies.
When these are missing, teams often miss edge cases—like a 17-year-old with high income or a disabled adult seeking coverage.
Validating Input Completeness
After defining variables and constraints, validate your inputs using a simple three-part checklist:
  1. Are all relevant variables included? Ask: Could any rule be affected by a factor not listed? If yes, you’ve missed an input.
  2. Are all variables mutually exclusive and exhaustive? If a variable has overlapping ranges or undefined values, your table may miss cases.
  3. Are there any hidden assumptions? If the variable behavior depends on an external system or policy not documented here, the table will fail in production.
I once worked on a payroll system where the “overtime eligibility” rule failed because the input “hours worked” wasn’t defined as “weekly hours.” The system assumed daily, causing incorrect overtime calculations.
Decision Table Setup: A Step-by-Step Framework
Here’s how I structure decision table setup in practice:
  1. Define the decision goal — “Determine if employee is eligible for overtime pay.”
  2. Extract influencing variables — Weekly hours, job classification, union rules, shift type.
  3. Define values and ranges — e.g., Weekly hours: ≥40, Job classification: exempt or non-exempt.
  4. Define context constraints — e.g., Only full-time employees are considered, Shifts must be 8+ hours.
  5. Map constraints to input validation — Add a validation rule: Reject if hours worked < 0 or > 80.
This process ensures your decision table inputs are not just defined—but pre-validated.
Common Pitfalls in Decision Table Inputs
The most frequent errors I see stem from poor input modeling. Here are the top three:
  • Using natural language without definitions — “Good credit” or “stable job” are not inputs. They’re interpretations.
  • Ignoring boundary conditions — What happens if income is exactly 70,000? Is it included? Define thresholds clearly.
  • Assuming input values are consistent — If one rule uses “months” and another “years,” your logic will break.
Always normalize input values. If your system uses months, convert all data to months. If it uses years, convert consistently. Inconsistency leads to logic errors.
How do I know which variables to include in a decision table?
Ask: “What changes in this decision if this factor changes?” If the outcome could shift, it’s a variable. If not, it’s irrelevant. Use stakeholder interviews and workflow analysis to identify key influencers.
Can decision table inputs include external data sources?
Yes—but only if they’re stable, reliable, and consistently formatted. If the input relies on a third-party API, define its expected output format clearly. Treat external sources as variables with defined constraints.
What if the decision logic changes after the table is built?
Revisit your inputs. If the change affects an input variable (e.g., new eligibility age), update the definition and revalidate all rules. A modular input definition makes this easier.
How do I handle categorical inputs like “status” or “type”?
Define each category explicitly. For example, “Employment Status” should list: Full-Time, Part-Time, Contract, Temporary, Unemployed. Avoid open-ended values like “active” or “working.” Use standardized codes if needed.
Is it okay to have inputs that are not Boolean or numeric?
Yes—but they must be fully defined. A string input like “location” must specify valid values: e.g., “NYC”, “LA”, “Chicago”. Use a controlled vocabulary to prevent invalid entries.
Why should I document context constraints separately from inputs?
Constraints are not conditions—they are assumptions that govern the table’s validity. If you embed them in rules, you risk duplication and contradictions. Keeping them separate ensures clarity and easier maintenance.
