Breaking Down Systems: Level 0, Level 1, Level 2 Explained
Temps estimé :6 minutes 604 vues
Think of a restaurant kitchen. At a glance, you see orders arrive, ingredients are prepared, meals are served. That’s Level 0 — a single process that captures the entire system as one black box. You don’t need to know how the chef chops vegetables or when the oven preheats. But if you’re designing the kitchen’s workflow, you can’t stop at the big picture.
Most beginners miss a crucial point: Level 1 isn’t just a “zoomed-in” version of Level 0. It’s a full functional breakdown that reveals the internal processes, data stores, and external interactions that make the system work. The real challenge isn’t drawing more detail — it’s ensuring that the data flows you define in Level 1 align precisely with the inputs and outputs of Level 0.
Over two decades of modeling systems, from hospital workflows to e-commerce platforms, has taught me this: consistency between levels isn’t a formality. It’s the foundation of a trustworthy model. In this chapter, I’ll walk you through how to build Level 0, decompose into Level 1, and then verify alignment — with practical examples and a clear DFD decomposition process.
Understanding the Core: Level 0 and Level 1 in Practice
Level 0: The Context Diagram
Level 0 is the system’s identity card. It shows only one process — the entire system — along with its external entities and data flows.
Consider a university registration system. Level 0 shows:
  • External entity: Student
  • External entity: Registrar’s Office
  • Data flow: Registration request → System
  • Data flow: Registration confirmation ← System
This is the minimal view. It defines scope, boundaries, and purpose. But it’s not useful for design. You can’t implement “one process” — you need to break it down.
Level 1: The Functional Breakdown
Level 1 introduces the first real decomposition. The single system process from Level 0 splits into 3–5 core functions.
For our university system, Level 1 might include:
  • Process 1: Validate Student Credentials
  • Process 2: Check Course Availability
  • Process 3: Enroll Student in Course
  • Process 4: Generate Enrollment Confirmation
  • Data store: Student Records
  • Data store: Course Schedule
Notice how each process has inputs and outputs — and every data flow must match the flows in Level 0.
Here’s where most errors happen. A system might show “Generate Confirmation” in Level 1 but fail to deliver a “confirmation” in Level 0. That’s a red flag: the model has lost consistency.
The DFD Decomposition Process: A Step-by-Step Guide
Decomposition isn’t arbitrary. It follows a pattern rooted in functional granularity.
Step 1: Identify the Main Functions
Start by asking: What are the key tasks the system performs? Use verbs and objects: “Process payment,” “Verify identity,” “Update inventory.”
Avoid verbs like “handle” or “manage” — they’re too vague. Instead, use precise actions.
Step 2: Map Inputs and Outputs
For each process, list:
  • Input data: What flows in?
  • Output data: What flows out?
  • Required data stores: Where is state maintained?
Ensure every input and output from Level 1 appears in Level 0. If a flow is missing, your model is incomplete.
Step 3: Check for Completeness
Use this checklist:
  • Are all external entities from Level 0 represented?
  • Do all data flows in Level 0 have corresponding flows in Level 1?
  • Are all data stores from Level 1 supported by valid processes?
  • Is every process self-contained and atomic?
If any question is “no,” revisit the decomposition.
Real example: In a billing system, Level 1 showed “Calculate Tax” and “Generate Invoice,” but Level 0 only listed “Payment Request” and “Invoice Sent.” The missing input — “Tax Rules” — caused an imbalance. Adding it fixed the flow.
Context Diagram vs Level 1: Key Differences
Many confuse context diagrams with Level 1. They are not the same.
Aspect Context Diagram (Level 0) Level 1 Diagram
Processes One 3–5 functional processes
Data Stores None Yes, if necessary
Focus System boundaries and external interactions Internal logic and flow
Use Case Initial scoping and stakeholder alignment Functional design and validation
Level 1 is where the system’s intelligence begins. It answers: Who does what, with what data, and where is it stored?
Building Level 2: When More Detail Is Needed
Level 2 comes after Level 1. It’s not always required — but when a process is complex, it needs deeper decomposition.
Take “Enroll Student in Course.” This might involve:
  • Check prerequisites
  • Verify credit load limits
  • Confirm instructor approval
  • Update student credit count
  • Update course enrollment count
Each of these becomes a sub-process in Level 2. But only decompose if the process is not atomic — if it involves multiple logical steps.
Remember: Don’t decompose for the sake of detail. Decompose only when clarity suffers.
Common Pitfalls in DFD Level 0 and 1 Modeling
Even experienced analysts stumble. Here are the top three:
  • Missing external entities: If a Level 1 process uses data from an external source not in Level 0, you’ve broken consistency. It must be modeled in Level 0.
  • Non-atomic processes: A process like “Handle Registration” is too broad. Split it to reflect actual functions.
  • Data store mismatches: A data store in Level 1 must be accessible via a process. If a store is “read” but never updated, it’s redundant.
These aren’t just errors — they signal poor decomposition. Fix them early.
Best Practices for DFD Level 0 and 1 Success
After years of reviewing models across industries, here are the habits that separate good from great:
  1. Use consistent naming: Start all process names with verbs. “Process Payment,” “Generate Report,” “Update Status.”
  2. Limit processes to 5–7 per level: More than that, and the diagram becomes unreadable. Group logically.
  3. Validate with the DFD decomposition process: After each level, ask: Do all Level 0 flows appear in Level 1? Do all Level 1 processes have clear, measurable outputs?
  4. Reference the data dictionary: Ensure each data flow is defined. This avoids ambiguity.
  5. Review with stakeholders: Show Level 0 to executives. Show Level 1 to developers and business analysts. Their feedback reveals gaps.
These aren’t just tips — they’re rules of engagement.
What is the difference between a Level 0 and Level 1 data flow diagram?
Level 0, or the context diagram, shows the system as a single process with external entities and data flows. Level 1 breaks that process into 3–5 functional components, revealing internal logic, data stores, and detailed flows. Level 1 is the first real model for design and validation.
Can I skip Level 1 and go straight to Level 2?
No. Level 1 is required to ensure consistency. You cannot decompose Level 2 without first validating Level 1. Skipping it risks creating untraceable, inconsistent flows.
What should I do if a data flow in Level 1 doesn’t match Level 0?
Re-examine your decomposition. Either the flow is not part of the system’s scope, or you’ve misaligned the parent process. Remove invalid flows or correct the Level 0 diagram.
How many processes should a Level 1 DFD have?
Optimally, between 3 and 7. Too few suggest oversimplification. Too many indicate poor decomposition. Aim for granularity without clutter.
Are there any free tools for drawing DFD level 0 and 1 diagrams?
Yes. Tools like Visual Paradigm support DFD creation. But ensure they allow hierarchical nesting and flow tracing for proper decomposition.
Why is DFD balancing important in Level 0 and 1?
Balancing ensures that data flows into and out of a process are consistent across levels. Without it, your model misrepresents system behavior, leading to flawed designs and implementation errors.
Retour en haut
