Customer Support Management Case
Temps estimé :6 minutes 59 vues
Most support cases don’t follow a fixed path. They evolve based on user behavior, urgency, and expert judgment. This is where CMMN support case modeling shines—not as a rigid sequence, but as a living structure that adapts to real-time triggers.
When modeling a customer support case, I’ve found that teams often misunderstand the role of tasks: they’re not just steps to do, but dynamic elements that activate based on conditions. The real power lies in how tasks are triggered by events, not just time or sequence.
By the end of this guide, you’ll know how to model a full support request lifecycle using the CMMN Case Plan Model—complete with dynamic entry conditions, escalation logic, and flexible task sequencing. You’ll walk away with a working example that mirrors real-world ticket management CMMN practices.
Mapping the Customer Support Case Lifecycle
Let’s start with a simple scenario: a customer reports a login failure. This isn’t a one-size-fits-all fix. The path forward depends on the ticket’s severity, user history, and response time.
Begin by defining the case’s core structure: stages, tasks, milestones, and case file items.
Define the Case Plan Structure
Start with the top-level case plan. In Visual Paradigm, this means creating a new CMMN Case Plan Model.
Use three clear stages:
  • Initial Assessment – Verify ticket validity and gather initial data.
  • Resolution Attempts – Execute diagnostic and fix workflows.
  • Escalation and Closure – If unresolved, escalate; otherwise, close.
Each stage is a container for tasks. But remember: stages are not just labels. They communicate progress and help the support team visualize where the case stands.
Modeling Dynamic Task Triggers
Tasks in CMMN aren’t manually triggered. They’re activated by sentries—conditions that evaluate in real time.
Here’s how I model dynamic task triggers:
  1. Define a task called Verify User Credentials.
  2. Attach a sentry with the condition: ticket.severity == "High" OR ticket.firstResponse > 4 hours.
  3. Set the sentry to wait for the condition to be true.
This means the task won’t appear in the task list unless the condition is met. It’s not a rule—it’s a trigger.
For example, if a high-severity ticket is flagged, the system automatically activates diagnostics tasks. But if it’s low priority and no escalation is detected, the task stays hidden until needed.
Do this consistently: use sentries to control visibility, not task lists.
Escalation Logic: From Support to Experts
Escalation is not a manual step. It’s a dynamic state transition driven by time, status, and data.
Model this with a two-part approach:
Set Up Escalation Criteria
Create a milestone named Escalation Deadline with a due date rule:
  • Due in 8 hours for high-severity tickets.
  • Due in 48 hours for medium-severity tickets.
  • No deadline for low-severity.
Use a case file item: ticket.escalationDeadline.
Then, attach a sentry to the Escalate to Senior Support task:
caseFile.escalationDeadline <= now() AND caseFile.status == "In Progress"
This condition ensures the task only activates when the deadline is near and the case hasn’t been resolved.
Dynamic Task Reassignment
When escalation is triggered, the task gets reassigned. But in CMMN, reassignment isn’t a task—it’s a property of the case.
Set the Assignee field in the task to:
  • escalationTeam for high-severity cases.
  • seniorSupport for medium.
Use a case file condition to dynamically assign team roles based on ticket severity.
Why it works: it removes manual handover. The system knows who to assign the task to—based on logic, not hierarchy.
Using Case File Items for Context
Support cases are data-rich. The case file is where you store and manage all information.
Define key items:
Item Type Use Case
ticket.severity String (High/Medium/Low) Drives task visibility and escalation
ticket.resolutionTime DateTime Tracks performance metrics
ticket.history List of Events Logs all actions and decisions
ticket.escalationTeam Team Auto-assigns when needed
These items aren’t static. They’re updated as the case evolves.
For example: when a technician logs a diagnostic step, the ticket.history list is updated automatically. This ensures full auditability without requiring extra workflow steps.
Best Practices for CMMN Service Desk Example
After modeling multiple support cases, I’ve distilled five key principles for robust, maintainable CMMN service desk example models:
  1. Use sentries, not time-based triggers – Let the system evaluate conditions in real time. Don’t rely on “after 4 hours” unless it’s part of a milestone.
  2. Keep tasks atomic – Each task should represent one logical action: contact user, check logs, run test script.
  3. Model severity early – Define ticket.severity as a case file item at model start. It will be used across multiple sentries.
  4. Use milestones only for time-bound checkpoints – These help track SLA compliance, not just document progress.
  5. Log decisions in the case file – Every critical decision—like escalating to engineering—should be recorded for audit and analysis.
These aren’t rules. They’re patterns I’ve seen work across industries: from SaaS platforms to government helpdesks.
Even experienced modelers fall into traps. Here are three I’ve seen most often:
  • Overusing tasks – Too many tasks create confusion. Use stages to group related tasks. A task should be a single action, not a process.
  • Hardcoding escalation paths – Avoid “if severity = high, then escalate.” Instead, use dynamic sentries and case file logic to reflect real-time rules.
  • Ignoring case file visibility – The case file is the source of truth. If a task needs data, it should come from the file—never be assumed.
When I first modeled a support case for a telecom client, I used 12 tasks. After refactoring with stages and sentries, it dropped to 7—with better clarity and fewer exceptions.
How does CMMN support case differ from BPMN in support ticketing?
BPMN is ideal for structured, repeatable processes—like a standard onboarding workflow. CMMN is built for uncertainty. In support, the path isn’t known in advance. CMMN lets you model what could happen, based on real-time data. You’re not designing a flow; you’re designing a response system.
Can I use CMMN for both IT service desk and customer support?
Absolutely. The same modeling principles apply. Whether it’s a login failure or a refund request, the case structure—stages, tasks, sentries, case file—remains consistent. You adapt the data and conditions to the domain.
How do I handle multiple support agents working on a single case?
Assign tasks dynamically using the case file. For example, set task.assignee to currentAgent or escalationTeam based on severity. CMMN doesn’t require a dedicated agent role—it works with organizational roles.
What if a sentry condition is never met?
That’s fine. The task won’t activate. CMMN is event-driven, not time-driven. If the condition never evaluates to true, the task remains inactive. This prevents unnecessary work and keeps the interface clean.
Is CMMN scalable for enterprise-level support teams?
Yes. Many large enterprises use nested CMMN models—where one case spawns sub-cases for diagnostics, engineering, or compliance. The key is to keep the main model focused on control logic, while delegating detailed workflows to sub-cases. This way, the model stays manageable and maintainable.
