Hybrid Modeling Patterns
Temps estimé :6 minutes 50 vues
Most modelers assume they must choose between BPMN and CMMN. But in practice, real-world work doesn’t fit neatly into one box. Complex processes often start with structured logic—BPMN’s domain—but require adaptive handling when exceptions arise, where CMMN shines. This is where hybrid CMMN BPMN patterns come into play.
My experience over two decades has shown that rigid adherence to either notation leads to models that either over-control or under-manage. The real power lies in orchestrating both. Think of it as using BPMN as the backbone and CMMN as the adaptive nervous system.
You’ll learn how to embed CMMN cases inside BPMN flows, use BPMN to trigger CMMN case plans, and manage exceptions through coordinated decision logic. The goal isn’t just to combine tools—it’s to build models that reflect reality, not just rules.
Core Principles of Hybrid Modeling
Hybrid CMMN BPMN patterns aren’t about mixing two standards at random. They’re grounded in a simple insight: structured processes often break down at the edges. That’s where adaptive case handling becomes essential.
When you model a loan approval process, BPMN handles the predictable steps: application receipt, credit check, income verification. But when an anomaly appears—say, a disputed credit history—the system should pause the process and shift to a CMMN case for investigation.
This shift isn’t a workaround. It’s a design choice. Hybrid modeling allows you to keep the flow of control clear while empowering knowledge workers to respond dynamically to uncertainty.
Why Not Just Use CMMN for Everything?
Because CMMN excels in flexibility, but that flexibility comes at a cost: complexity and reduced automation potential. Not every process needs a case plan.
BPMN, on the other hand, thrives in predictable, repeatable scenarios. But when exceptions emerge, modeling them in BPMN often leads to bloated, hard-to-maintain diagrams with endless gateways and alternate paths.
Hybrid modeling keeps the strengths of both. Use BPMN for the predictable core. Use CMMN for the exceptional path.
Key Hybrid Integration Patterns
1. BPMN Initiates a CMMN Case
One of the most reliable patterns: let BPMN detect a deviation and trigger a CMMN case.
Example: A customer service ticket flows through BPMN stages—receipt, triage, assignment. If the issue is complex or unresolved after three attempts, a gateway checks: “Is this an edge case?” If yes, the BPMN process triggers a CMMN case named “Investigation Workflow.”
The BPMN diagram remains clean. The CMMN case handles the investigation with stages, tasks, and sentries. When resolved, the case signals back to BPMN to resume.
This pattern is ideal for customer complaints, insurance claims, or incident management.
2. CMMN Subcase within a BPMN Process
Use this when part of a larger workflow is inherently unpredictable.
Consider a loan underwriting process. After initial data validation (BPMN), you reach a point where the decision depends on a deep risk assessment. That assessment isn’t linear—it involves reviewing documents, consulting experts, and adjusting thresholds.
Here, embed a CMMN case as a subprocess. The BPMN flow calls the CMMN subcase. The subcase manages its own tasks, milestones, and entry conditions. When complete, it returns control to BPMN to proceed with approval or rejection.
This keeps the high-level BPMN flow readable while preserving adaptability in the complex region.
3. Exception Handling via CMMN in BPMN
Most BPMN diagrams fail to model exceptions well. They either ignore them or hardcode them into parallel paths.
Instead, use CMMN as the exception handler. When a BPMN process hits a failure point—say, a required document is missing—instead of adding another branch, create a CMMN case named “Document Reconciliation.”
The CMMN case defines: what documents are needed, who can request them, and what conditions allow resumption. Once the case is complete, the BPMN process continues.
This approach avoids flow explosion. It also aligns with how real teams operate: they don’t follow a fixed path when something goes wrong—they create a new plan.
Design Patterns in Practice
Here’s how these patterns look in a real-world scenario: insurance claim processing.
Step 1: A claim is submitted. BPMN handles data capture, initial validation, and fraud screening.
Step 2: If fraud risk is low and the claim is straightforward, BPMN continues to settlement.
Step 3: If fraud risk is medium or high, the BPMN process triggers a CMMN case: “Fraud Investigation.”
Inside the CMMN case, tasks like “Review transaction history,” “Interview claimant,” and “Consult forensic analyst” are defined. Entry conditions ensure the case only starts when fraud risk exceeds threshold.
When the case is complete, a “case complete” event triggers the BPMN flow to resume. The claim proceeds to settlement or denial.
This design is not just elegant. It reflects how real claims teams operate. It’s not a flowchart—it’s a decision framework.
Implementation Checklist
  • Define clear boundaries between BPMN and CMMN—what belongs in each.
  • Use BPMN gateways to evaluate when a case should be triggered.
  • Ensure CMMN cases can signal back to BPMN via defined events.
  • Keep CMMN case plans simple—avoid over-complexity.
  • Validate both models together in simulation to ensure correct handover logic.
Tools and Modeling Support
Tools like Visual Paradigm support hybrid modeling by enabling:
  • Embedding CMMN case plans inside BPMN subprocesses.
  • Connecting BPMN events to CMMN sentries and triggers.
  • Simulating both models together to test exception scenarios.
Without proper tooling, hybrid models become fragile. But with support, they become the most realistic way to represent real business work.
Can I use BPMN with CMMN in the same model?
Yes. Modern modeling tools allow embedding CMMN case plans within BPMN subprocesses. This is not a workaround—it’s a best practice for handling adaptive logic in otherwise structured workflows.
How do I decide when to use CMMN in a BPMN process?
Use CMMN when the workflow involves unpredictable decision-making, multiple knowledge workers, or requires human judgment to resolve. If the path isn’t clear from the start, CMMN is the right container.
What’s the risk of overusing CMMN in BPMN?
Overusing CMMN reduces automation potential. It also increases complexity without benefit. Use CMMN only when necessary—when the process is inherently adaptive.
Do I need to model both BPMN and CMMN for the same case?
Not always. Use BPMN for the predictable core, and CMMN only for the adaptive branches. The key is to keep the main flow clean. Use CMMN only when the case logic is too complex for BPMN.
How do I ensure consistency between BPMN and CMMN models?
Define a shared event language (e.g., “case completed,” “investigation started”) and use common data elements. Visual Paradigm supports traceability between models, ensuring both views stay in sync.
Is hybrid modeling suitable for regulated industries?
Yes. In healthcare, finance, and insurance, hybrid models are preferred for compliance. BPMN ensures auditability for standard flows; CMMN captures adaptive decisions that can be reviewed and justified when needed.
