Customer Onboarding: Flow vs Case Design
Temps estimé :8 minutes 50 vues
Most businesses assume they can model any onboarding process with a single flowchart. That’s a myth. The truth is: most customer onboarding isn’t a fixed sequence — it’s a dynamic, human-led journey where each step depends on context, risk, and data. Rigid flowcharts fail here, not because they’re wrong, but because they’re built for predictability. When you force adaptive work into a BPMN flow, you end up with cluttered diagrams, endless exceptions, and frustrated users. That’s why the real insight isn’t choosing between BPMN and CMMN — it’s understanding when each shines.
This chapter walks you through the same customer onboarding scenario modeled first in BPMN, then in CMMN. You’ll see the structural differences, how responsibilities are assigned, and where flexibility becomes a necessity. Along the way, you’ll learn how to spot the right tool for the job — not just by what’s popular, but by what reflects reality.
By the end, you’ll know exactly when to use a flow-based BPMN model and when to switch to a case-driven CMMN approach. And you’ll see how both can coexist in a hybrid model — a must-have capability for modern business analysts.
BPMN Modeling: A Predictable Flow
Start with a standard customer onboarding process using BPMN. This approach works well when the steps are repeatable and outcomes are deterministic. The goal is to automate routine tasks with minimal human intervention.
Here’s how a typical BPMN onboarding flow might begin:
  1. Customer submits application via web form.
  2. System validates data and routes to underwriting.
  3. Underwriter reviews documents.
  4. If documents are complete, proceed to KYC (Know Your Customer) verification.
  5. If incomplete, send back for corrections.
  6. After KYC, assign account manager.
  7. Onboarded — process complete.
Each step is represented as an activity, connected by sequence flows. Gateways handle decision points: Is data valid? Is the document set complete?
BPMN excels when the path is linear and rules are clear. But in practice, real onboarding rarely follows this script. A customer might have a unique risk profile. A document might be valid but require manual review. A compliance rule might change mid-process.
When these exceptions emerge, you’re forced to add multiple branches — leading to complex, tangled flows. The model becomes hard to maintain, and business rules are buried in the diagram instead of being explicitly defined.
When BPMN Fails: The Onboarding Edge Cases
Consider these real-world variations:
  • Customer is high-risk — triggers additional due diligence.
  • Document is in a foreign language — requires translation and notarization.
  • Underwriter is on vacation — task must be reassigned.
  • Customer requests a delay due to personal circumstances.
Each of these requires a new path. In BPMN, those pathways must be explicitly modeled. The more variants, the more complex the diagram becomes. Eventually, you have a flowchart that no one can read — not even the analyst who built it.
BPMN is not wrong — it’s just the wrong tool for adaptive, knowledge-intensive work. That’s where CMMN steps in.
CMMN Modeling: Adaptive Case Design
Now, model the same onboarding process using CMMN. The core idea is to shift from a fixed sequence to a flexible case plan. Instead of defining every step in advance, you define the case stage and allow conditions to trigger actions.
Here’s how it looks in practice:
  • Stage: Onboarding Initiation — Customer submits application. Case file is created and populated with initial data.
  • Stage: Document Collection — A task is created to gather required documents. The task doesn’t start until the case file has basic data.
  • Stage: Risk Assessment — A milestone triggers when documents are received. A sentry evaluates risk level based on customer profile and data.
  • Stage: Compliance Review — If risk is high, an additional task is activated. If low, proceed to onboarding.
  • Stage: Finalization — Once all conditions are met, the case completes.
Key differences:
  • No fixed sequence — tasks are triggered by conditions, not flow.
  • Tasks are not automatically executed — they are activated by sentries or manual user actions.
  • Case file stores all data — decisions are based on real-time information.
  • Stages represent phases of work, not rigid steps.
This model is not about flow. It’s about control through constraints. The case plan defines what must be done — but not when, or in what order. That’s the power of adaptive modeling.
Why CMMN Excels for Onboarding
Onboarding is inherently adaptive. No two customers are the same. The risk level, documentation needs, and regulatory context vary dramatically. Yet, many still force this into a BPMN flow — creating models that are technically correct but practically useless.
CMMN allows you to capture the real world: not a single path, but a dynamic system where the next task depends on data, rules, and human judgment. You’re not modeling a flow — you’re modeling a case.
Here’s what makes CMMN ideal for onboarding:
  • Flexibility — New tasks appear when needed, based on data or triggers.
  • Scalability — Adding new risk categories doesn’t require reworking the entire flow.
  • Transparency — The case file shows what’s been done, what’s pending, and what’s required.
  • Human-centered design — The worker controls progress, not the diagram.
It’s not about automation. It’s about empowerment.
Comparing the Two: BPMN vs CMMN onboarding example
Let’s contrast both models side-by-side:
Aspect BPMN (Flow) CMMN (Case)
Model Type Control flow-driven Constraint-driven
Sequence Fixed, predefined Dynamic, condition-based
Decision Logic Embedded in gateways Defined in sentries
Task Activation By flow transition By condition or user action
Best For Repeatable, rule-based processes Adaptive, knowledge-intensive cases
Onboarding Fit Low (when variation increases) High (especially for complex or high-risk cases)
Notice the pattern: BPMN wins when the process is routine. CMMN wins when the work is unpredictable.
Don’t fall for the “just use BPMN” trap. If you’re modeling customer onboarding and your flow includes more than 5 decision points, you’re likely in case territory.
And here’s a key truth: you don’t have to choose one. In practice, many organizations use both — embedding CMMN cases within BPMN subprocesses.
Hybrid Modeling: Best of Both Worlds
Real-world onboarding often combines both: a structured flow with adaptive sub-processes.
For example:
  1. BPMN flow: Customer submits application.
  2. BPMN triggers a CMMN case: “Onboarding Investigation”.
  3. CMMN manages: document verification, risk assessment, compliance review.
  4. Once CMMN case completes, BPMN continues to account activation.
This is the ideal pattern: BPMN for control, CMMN for execution.
It’s not about replacing one with the other. It’s about using the right tool at the right level.
Here’s how to decide:
  • If the process has few than 3 clear decision points and high repetition — use BPMN.
  • If the process has multiple unknowns, varied data, or high human judgment — use CMMN.
  • If a subprocess involves unpredictable work — embed a CMMN case inside a BPMN flow.
  • If the case has standard steps but variable flow — use CMMN with stages and sentries.
Don’t over-model. Don’t under-model. Model for reality.
When should I use BPMN instead of CMMN for customer onboarding?
Use BPMN when onboarding is standardized — for example, onboarding low-risk customers via a digital form with automated checks. The path is predictable, and automation is the goal. CMMN is better when risk varies, documents are complex, or multiple teams are involved.
Can I use both CMMN and BPMN in the same process?
Yes — and you should. Use BPMN to manage the overall workflow, and embed CMMN as a subprocess for adaptive, case-based work. This allows you to maintain structure while preserving flexibility.
What’s the biggest mistake analysts make when modeling customer onboarding?
Assuming onboarding is a single, fixed flow. In reality, it’s a case — not a process. Modeling it as a flow leads to rigidity, poor usability, and maintenance hell. Always ask: “Is this work adaptive?” If yes, CMMN is likely the right choice.
How do I know if my onboarding case model is well-designed?
A good onboarding case model has clear stages, well-defined sentries, and a consistent case file. Tasks activate based on conditions, not flow. The worker should be able to see what’s done, what’s missing, and what to do next — all without reading the entire diagram.
Can CMMN be automated?
Yes, but not like BPMN. CMMN is not about automating steps. It’s about automating decisions — when to activate a task, when to trigger a milestone. Tools like Visual Paradigm support CMMN execution via rule engines and case management systems.
Is CMMN harder to learn than BPMN?
Not inherently. CMMN is different — but not more complex. It requires a shift in mindset: from “what happens next?” to “what’s required now?” Once you grasp the case plan concept, it’s often easier to model unpredictable work than to force it into a rigid flow.
Remember: The best model isn’t the cleanest. It’s the one that reflects reality — whether that’s a flow or a case.
