Defining DFD Balancing in Simple Terms
Temps estimé :7 minutes 67 vues
When you’re building a data flow diagram, it’s not enough to just draw processes and flows. The real test comes when you move from one level to the next: consistency matters. I’ve seen dozens of models fail not because of poor design, but because the data flows didn’t match between levels.
What is DFD balancing? It’s the practice of ensuring that every data flow entering or leaving a process at one level has a corresponding flow in the child diagram—no more, no less. It’s not optional. It’s foundational.
Imagine a system where data disappears between levels. Or worse, appears out of nowhere. These are classic DFD error examples, and they break trust in your model from the very first review.
This chapter demystifies DFD balancing using plain language and real scenarios. You’ll learn how to spot inconsistencies, understand the rules, and apply a proven method to verify balance—no jargon, no confusion.
Why DFD Balancing Matters in Real Modeling
At its core, DFD balancing enforces logical integrity. If you break it, your diagram becomes a collection of disconnected ideas, not a coherent system model.
Let’s be honest: many analysts rush through decomposition without verifying inputs and outputs. This leads to gaps, duplication, and confusion—especially in team environments.
Here’s what happens when balancing fails:
  • A process in Level 1 shows “Customer Order” as input.
  • The child Level 2 diagram for that process shows no input at all.
  • Or, worse, it shows “Order Received” and “Payment Verified” as inputs—neither of which correspond to the parent.
This is a clear DFD error example. It breaks the principle that the child diagram must preserve the data flows of its parent.
What Really Happens When You Ignore Balance?
When data flows don’t align across levels, your model loses its predictive power. Reviewers will question your understanding. Stakeholders will lose confidence. And during audits, you’ll be asked: “Where did this data come from?”
More importantly, no automated tool can fix a broken model. If the flows don’t match, even Visual Paradigm or similar software will flag inconsistencies—but it can’t tell you why, only that something’s wrong.
So what is DFD balancing, really? Think of it as a validation rule: every input and output in a parent process must be accounted for in its child diagram.
Definition of Balancing: A Simple Rule with Real Impact
The definition of balancing is straightforward:
For every data flow in a parent process, there must be a matching flow in the corresponding child diagram—either as input, output, or both.
It’s not about copying flows. It’s about ensuring continuity. The child diagram must break down the parent process, not invent new ones.
Let’s walk through a simple example:
  1. Level 1 process: “Process Order” has two inputs: “Customer Order” and “Inventory Check.”
  2. Level 2 must include both input flows.
  3. It can have additional flows (like “Payment Confirmation”) as long as they’re justified by the process logic.
  4. But it cannot omit either input flow.
That’s what balanced data flow looks like. No exceptions.
Common Misconceptions About DFD Balancing
Let’s clear up a few myths:
  • Myth: If I add more flows in the child diagram, I’m just being more detailed.
  • Fact: You can add flows, but only if they’re derived from the parent process. Adding a flow that wasn’t in the parent is a red flag.
  • Myth: If the data is stored in a data store, it doesn’t count as a flow.
  • Fact: Data in a data store is still a flow. If data flows into a store, it must appear as an output in the parent process.
So what is DFD balancing, really? It’s not about matching symbols or shapes. It’s about tracking data movement with precision.
Step-by-Step: How to Check for Balanced Data Flow
Here’s how I’ve taught hundreds of analysts to audit their own models:
  1. List all data flows in the parent process.
  2. Go to the child diagram and verify that each flow appears.
  3. Check for flows in the child that don’t exist in the parent—these are errors.
  4. Ensure every flow is either an input, output, or both. No new data sources or sinks.
This checklist is your first line of defense. It’s simple, but powerful.
Example: The Customer Registration Flow
Let’s say you have a Level 1 process: “Register Customer.” Inputs: “Customer Data.” Output: “Customer ID.”
The Level 2 breakdown must include:
  • Input: “Customer Data” (from external entity)
  • Output: “Customer ID” (to external entity)
  • Any internal flows (like “Validate Data”) are allowed—but they must be part of the process, not standalone.
Now suppose the child diagram shows “Verify Credit Score” as an input. That wasn’t in the parent. That’s a DFD error example. You’ve introduced a new data flow without justification.
Why does it matter? Because it implies the customer registration process depends on credit data—but that wasn’t stated in the original model.
The Two Golden Rules of DFD Balancing
After years of modeling, reviewing, and mentoring, I’ve distilled the practice into two rules:
  1. Every flow in the parent must appear in the child, either as input or output.
  2. No flow can appear in the child that isn’t logically derived from the parent process.
These rules are not suggestions. They are the foundation of professional DFD modeling.
If you can’t justify a flow, you don’t need it. And if a parent flow is missing in the child, you’ve made an error.
When You Can Add Flows (And Why)
Yes, you can add flows in the child—just not arbitrarily. They must be internal to the process. For example:
  • “Validate Data” (internal flow)
  • “Store Customer Record” (output to data store)
  • “Send Confirmation Email” (output to external entity)
These are allowed because they’re part of the process’s logic. But they don’t replace the parent’s input or output.
Visual Comparison: Balanced vs. Unbalanced DFDs
Here’s a quick visual breakdown:
Feature Unbalanced DFD Balanced DFD
Parent Input “Order Data” “Order Data”
Child Input “Order Data” + “Payment Data” (extra) “Order Data” only
Child Output “Order Confirmed” (missing) “Order Confirmed”
Verdict ❌ Error: extra input, missing output ✅ Correct: all flows preserved
This table shows a typical DFD error example: adding flows not present in the parent, and omitting ones that were.
Final Thoughts: Balancing as a Quality Standard
What is DFD balancing? It’s not a tool. It’s a mindset. It’s the practice of saying: “I will not let data vanish or appear without explanation.”
It’s the difference between a model that guides change and one that confuses it.
Every time you create a new level, ask: “Does every flow from the parent appear here?” If not, you’ve made a mistake. Fix it before anyone else sees it.
And remember: balanced data flow isn’t about perfection. It’s about consistency. It’s about trust. It’s about professionalism.
What is DFD balancing in simple terms?
DFD balancing means the data flows in a parent process must match those in its child diagram. No new flows can appear without justification, and no parent flows can be missing.
How do I check if a DFD is balanced?
Compare every input and output in the parent process with the child. If all flows are accounted for and no new ones appear, it’s balanced. Use a checklist to ensure nothing is missed.
What is a DFD error example?
A common DFD error example is when a child diagram adds a new input flow not present in the parent, or omits an output flow required by the parent process.
Why is balanced data flow important?
It ensures logical consistency across levels. Without balance, your model becomes unreliable for analysis, documentation, and system design.
Can I add flows in a child diagram that aren’t in the parent?
Only if they’re internal to the process (like validation or data storage). You cannot add flows that represent new data sources or sinks.
Does every data store need to be linked to a process?
Yes—every data store must have at least one input or output flow from a process. If a data store has no flows, it’s not part of the system.
