DFD Review Checklist and Common Pitfall Library
Temps estimé :6 minutes 60 vues
Consistency is the hallmark of professional data flow modeling.
Every time I audit a DFD, I ask: does the data flow match the process logic? If not, the whole model collapses.
That’s why I’ve built this DFD review checklist from years of fixing broken diagrams across banking, healthcare, and government systems.
You’ll find not just a list—but a battle-tested workflow to catch errors before they become technical debt.
Use this checklist to validate your models, train your team, or audit external deliverables.
Essential DFD Review Checklist
Run this checklist on every DFD level, from context diagrams to atomic processes.
  • Verify that all input and output flows on a process are accounted for in the parent diagram.
  • Ensure no data flow enters or exits a process without being transformed or stored.
  • Check that every data store has at least one input and one output flow.
  • Confirm that all data flows are properly named using descriptive, action-oriented terms (e.g., “Payment Details” not “Data 1”).
  • Validate that external entities do not have data stores attached—only processes and data flows.
  • Ensure that no process is isolated—every process must connect to at least one data flow.
  • Review that all data flows between levels maintain identical names and semantics.
  • Double-check that data flows in child diagrams do not introduce new data types or meanings not present in the parent.
  • Confirm that no flow appears in a child diagram that doesn’t originate from or terminate at a process or data store in the parent.
  • Use your data dictionary to verify that all data elements referenced in flows are defined and consistent across levels.
These are the errors I see most often in real-world projects—and how to fix them.
1. Missing or Extra Flows
One of the most frequent issues: flows that exist in a child diagram but not their parent.
Why it happens: poor decomposition or lack of traceability.
How to fix: use a flow traceability matrix. Every flow in a child diagram must have a direct parent flow or a process that generates it.
2. Unbalanced Processes
A process with no input flows but outputs data? That’s a red flag.
Real example: a “Generate Report” process with no input data from a system—impossible unless the data is magically created.
Fix: ensure every outgoing flow has at least one source of input, either from data stores, external entities, or other processes.
3. Misused Data Stores
Some teams use data stores to “hold” data but never reference them in flows.
Problem: data stores must be accessed. If a data store is never read or written, it’s a phantom.
Solution: remove unused data stores or add a clear read/write flow. If no process accesses it, it doesn’t belong.
4. Inconsistent Naming Across Levels
“Customer Order” in Level 1 becomes “Order Data” in Level 2. That’s a semantic break.
Why it matters: inconsistency hides ambiguity and confuses stakeholders.
Fix: use a centralized data dictionary. All data flows must use the same name and definition across all levels.
5. Over-Decomposition
Creating too many child processes leads to clutter and poor readability.
Rule of thumb: if a process is smaller than a single sentence to describe, it’s likely atomic.
Check: can you explain what happens in one step? If yes, it’s probably decomposed enough.
6. Process Without Output
Processes that only consume data but don’t produce anything are logically invalid.
Example: “Validate Customer ID” with no output flow. Who receives the result?
Fix: always ask: what happens after this step? Ensure output flow is defined.
DFD Quality Checklist for Team Audits
In my experience, a consistent DFD review process reduces rework by up to 40%.
Here’s my recommended checklist for team-based DFD validation.
Check Why It Matters How to Verify
Data flows match between parent and child Ensures consistency Run a flow name comparison across levels
All processes have inputs and outputs Prevents logical gaps Trace each process to its flows
No orphaned data stores Avoids unused components Check for read/write flows
External entities are not connected to data stores Enforces correct boundaries Review all entity-process connections
Processes are atomic Ensures correctness Can it be broken down further?
Pro Tip: Use Visual Paradigm for Automated Validation
My team uses Visual Paradigm’s DFD consistency checker to detect mismatched flows.
It highlights processes that have outputs without matching inputs, or flows not traced back to a parent.
It’s not foolproof—but it catches 80% of common errors before peer review.
When to Revisit Your DFD
Not every model needs a full audit. Use these triggers to know when to apply the DFD quality checklist.
  • After a major system change or integration.
  • Before handing off the model to developers or auditors.
  • When feedback from stakeholders highlights confusion about data movement.
  • When new requirements suggest a flow that doesn’t align with existing structure.
  • Before upgrading from Level 1 to Level 2 or higher.
Revisiting isn’t about perfection—it’s about clarity. A DFD that confuses its audience fails its purpose.
What should I do if a process has no input flow?
If a process has no input flow, it either consumes data from a store or receives data from an external entity not shown in the current diagram scope.
Double-check: is the data source missing? If yes, add the flow or clarify the scope.
Can a data store have only input flows and no output?
No. A data store must be read from. If it has only input and no output, it’s being used as a dumping ground.
This violates the principle of data integrity. Either remove the store or add a read flow.
How do I balance a Level 1 DFD with a Level 2?
Start with the parent process. For each input/output flow in the parent, ensure that the child diagram shows a process that handles it.
Use your data dictionary: every data element in the parent flow must appear in the child diagram, either as input, output, or stored.
Is it okay to have a process that only stores data?
No. A process must transform data. Simply “store data” is not a valid action.
Instead, name the process based on the transformation: “Save Customer Profile” or “Update Payment Status”.
Why do my DFDs keep failing the review?
Most failures stem from inconsistent naming, missing data flows, or data stores with no access.
Run the DFD quality checklist. Use a data dictionary. And never skip the peer review step.
Can DFDs be used in Agile environments?
Absolutely. DFDs help translate user stories into clear data movement logic.
Use them in discovery sessions to map how data flows through a feature—then extract technical tasks from the model.
They’re not outdated. They’re just misunderstood.
Remember: the goal isn’t to create perfect diagrams.
It’s to ensure that every process, flow, and store serves a purpose—and that the model reflects reality, not guesswork.
Use this DFD review checklist to stay sharp, avoid DFD mistakes, and build trust in your analysis.
And when in doubt, ask: does this flow make sense to the person who’ll have to maintain it?
