Design Patterns Expressed in UML
Temps estimé :7 minutes 54 vues
Most developers learn design patterns as abstract concepts in textbooks. The real leap comes when you stop memorizing them and start *recognizing* their structure in code and diagrams. That moment—when a class diagram suddenly reveals a Singleton or a sequence diagram shows a Strategy pattern in motion—marks the shift from rote learning to true design fluency.
That recognition is built on one key insight: patterns aren’t just abstract blueprints. They are *visualizable*, and UML is the most powerful tool to make them tangible. This chapter shows how to represent GoF patterns UML using class and sequence diagrams—not to over-document, but to improve communication, detect flaws early, and ensure consistency across teams.
By the end of this section, you’ll be able to sketch, critique, and refine design patterns using UML as a shared language—exactly as professionals do in large-scale systems.
Why UML Makes Design Patterns Practical
Patterns exist to solve recurring problems. But without a shared visual language, translating “this class should be instantiated once” into a working system often leads to inconsistent implementations.
UML closes that gap. A well-drawn class diagram can instantly show whether a pattern is applied correctly—no code needed. A sequence diagram reveals how objects collaborate under different conditions, exposing hidden coupling or timing flaws.
Consider the Observer pattern. In code, it might be buried in event handlers. But in a UML sequence diagram, the flow of notifications becomes obvious. You can see if the subject correctly maintains a list of observers and whether they’re notified in the correct order.
UML as a Communication Layer
Teams often debate whether a class is a Factory, a Builder, or a Prototype. A simple UML class diagram with the right stereotypes and relationships resolves the debate in seconds.
Stakeholders like product owners and junior developers benefit from seeing the pattern’s structure. A single sequence diagram can illustrate a complex workflow like a payment gatekeeper handling retries, timeouts, and fallbacks—something that would take paragraphs to explain in text.
Visual clarity leads to fewer misunderstandings, faster onboarding, and stronger alignment between architects and implementers.
Mapping GoF Patterns to UML
There are 23 classic GoF patterns. Each has a distinct structure and purpose. UML provides a consistent way to model all of them—making them reusable across domains.
Here’s how a few key patterns appear in UML.
Singleton: A Single Instance, Clearly Modeled
Singleton ensures a class has only one instance. In UML, this is shown by:
  • A single instance of the class with a static attribute.
  • Private constructor (shown as “—” in UML).
  • A public static method, typically named getInstance(), returning the single instance.
The class diagram explicitly enforces the constraint. You can’t accidentally create multiple instances without breaking the model.
Factory Method: Delegating Construction
The Factory Method pattern lets subclasses decide which class to instantiate. In UML:
  • A base class declares an abstract method createProduct().
  • Concrete subclasses override it to return their own product type.
  • Relationships show inheritance (a solid line with a hollow arrow).
This makes it easy to see that the actual instantiation happens at runtime, based on the subclass. It’s not magic—it’s clear, structured, and testable.
Strategy: Encapsulating Behavior
Strategy lets you switch algorithms at runtime. In UML:
  • A context class holds a reference to a Strategy interface.
  • Concrete strategy classes implement the interface.
  • Dependency is shown as a dashed arrow from context to interface.
This structure makes it obvious how algorithms are decoupled. You can swap strategies without changing the context, improving maintainability.
Visualizing Behavior with Sequence Diagrams
Class diagrams show structure. Sequence diagrams show behavior. Together, they form a complete picture of how a pattern works in practice.
For example, the Command pattern is all about encapsulating requests as objects. A sequence diagram illustrates the flow:
  1. The client creates a Command object and assigns it a receiver.
  2. The Command is passed to an invoker (e.g., a button or timer).
  3. The invoker calls execute() on the command.
  4. The command invokes the receiver’s method.
This sequence is clear, repeatable, and easy to verify against the class model.
It also reveals hidden risks—like what happens if execute() fails and isn’t rolled back. That’s where state diagrams can help, but the sequence diagram is the first line of clarity.
Trade-offs in Modeling Patterns
Not every pattern needs a full UML sequence diagram. The key is *contextual relevance*.
For a simple Singleton, a class diagram is often enough. For a complex pattern like State or Template Method, a sequence diagram is essential to show how state transitions or method overrides affect behavior.
Don’t model for the sake of completeness. Model to clarify the *decision* the pattern enables.
Common Mistakes and How to Fix Them
Even experienced modelers make errors when applying patterns. Here are the most frequent issues—and how to avoid them.
Over-Modeling: The “Too Many Arrows” Problem
Some teams add every possible relationship: inheritance, dependency, association, aggregation. This creates visual noise.
Fix: Focus only on relationships that affect the pattern’s behavior. For Strategy, the key is the dependency from context to interface—not every related class.
Ignoring Stereotypes
Without stereotypes like «interface», «abstract», or «factory», the diagram loses its semantic meaning.
Fix: Use stereotypes consistently. They’re not decorative—they signal intent to the reader.
Modeling the Wrong Level of Abstraction
Some modelers show every method in a class, even when it’s irrelevant to the pattern.
Fix: Strip away implementation details. Show only the core elements: the pattern’s participants, their roles, and key operations.
Pattern Misapplication
Applying a pattern where it doesn’t belong wastes effort and increases complexity.
Fix: Ask: “Does this pattern solve a real problem in this context?” If not, reconsider. The Singleton, for instance, is often misused in multi-threaded environments. UML can help spot that risk by showing how the instance is created and accessed.
Best Practices for Modeling Design Patterns
Here’s a checklist to guide your modeling:
  • Start with intent: What problem does the pattern solve here?
  • Use standard notation: Follow UML conventions for classes, interfaces, relationships.
  • Keep diagrams focused: Show only what’s necessary for understanding the pattern.
  • Use stereotypes and notes: Clarify roles and constraints.
  • Validate with peers: Have someone unfamiliar with the pattern review the diagram.
  • Link to code: Use traceability to show how the model maps to actual implementation.
These aren’t strict rules. They’re guardrails to ensure your models serve their purpose: to communicate, verify, and evolve design.
Can I use UML design patterns in any programming language?
Yes. UML is language-agnostic. The structure of a Factory Method or Observer pattern is the same whether you’re using Java, Python, or C++. The implementation details differ, but the model remains consistent.
Should I model every GoF pattern in my project?
No. Apply patterns only when they solve a real problem. For example, use Singleton only when a single instance is truly required. Never force a pattern into your system just because it’s popular.
How do I know which UML diagram to use for a pattern?
Use class diagrams for structural patterns (Singleton, Factory, Adapter). Use sequence diagrams for behavioral patterns (Strategy, Observer, Command). Use state diagrams for patterns involving state transitions (State, Memento).
Do I need to draw every pattern by hand?
No. Tools like Visual Paradigm offer pattern templates, auto-layout, and code generation. Start with a template and refine it for your context.
How do I ensure my UML model stays in sync with code?
Use forward and reverse engineering. Model-first allows you to generate skeleton classes. Code-first lets you reverse-engineer a model from existing code. Keep both in sync through version control.
Is UML still relevant with modern tools like AI and code generation?
Yes. AI can generate code from natural language, but it can’t replace the architectural intent that UML captures. Use UML to guide AI, not replace it. A diagram helps you understand *why* a system is built a certain way—something code alone cannot convey.
