Maintaining Momentum: Continuous Monitoring After Re-Engineering
Estimated reading: 6 minutes 49 views
One of the most underappreciated truths in business process re-engineering is this: the real work begins the day the new process goes live. I’ve seen teams celebrate a successful rollout—only to watch performance degrade within weeks. The root cause? No system to track actual outcomes against the intended goals.
After years of leading BPR initiatives across finance, logistics, and public sector operations, I’ve learned: continuous process monitoring isn’t a phase—it’s the foundation of sustainable transformation. It’s what separates a one-time fix from lasting innovation.
Here’s what you’ll gain from this chapter: a clear, step-by-step framework to embed performance tracking into your organization’s core operations. You’ll learn how to set up feedback loops, design actionable KPI dashboards, and institutionalize BPR follow-up without adding bureaucratic overhead.
Why Continuous Monitoring Is the Lifeline of BPR
Re-engineering is not a project with a start and end. It’s a commitment to continuous improvement.
When you redesign a process, you’re not just changing steps—you’re altering behavior, expectations, and system dependencies. Without ongoing visibility, drift happens. Teams revert to old habits. Automation lags. KPIs stagnate.
That’s why continuous process monitoring must begin the moment you implement the new workflow. It’s not a luxury. It’s the mechanism that keeps your innovation alive.
Common Pitfalls in Post-Implementation Oversight
  • Teams stop tracking metrics after the initial rollout.
  • KPIs are defined only at the design stage and never reviewed.
  • Data collection is siloed—no one connects performance back to process owners.
  • Feedback loops are reactive, not proactive.
These aren’t just oversights. They’re preventable failures that erase months of re-engineering work.
Embedding Monitoring into Your Organizational Rhythm
Monitoring must become part of your operational cadence—not a side task. Here’s how to do it right.
Step 1: Define the Right KPIs—Beyond Speed and Cost
Too many teams only measure time and cost. That’s a start, but it’s incomplete. You need KPIs that reflect real business value.
Ask: What does success actually look like?
  • Customer satisfaction score (CSAT) after process change
  • First-time fix rate (for service processes)
  • Process compliance rate (how often the new workflow is followed)
  • Defect density per 100 transactions (quality indicator)
These aren’t just metrics. They’re signals. They tell you whether the process is working—or where it’s breaking down.
Step 2: Create a Real-Time KPI Dashboard
Don’t hand over a static spreadsheet. Design a live dashboard that updates daily or weekly.
Use tools like Power BI, Tableau, or even Excel with dynamic data feeds. The key is accessibility and clarity.
Here’s a simple structure:
Process Target KPI Current Value Variance Status
Invoice Processing < 2 days 2.4 days +0.4 days 🔴
Customer Onboarding < 1.5 days 1.2 days -0.3 days 🟢
Color-coding (green, yellow, red) provides instant visual feedback. This is how you sustain process innovation—by making performance impossible to ignore.
Step 3: Set Up Feedback Loops with Ownership
Monitoring only works if someone acts on it.
Assign process owners—individuals accountable for the outcome, not just the execution.
Set up a monthly review meeting where the process owner presents:
  1. Current KPI performance
  2. Root causes of variance (if any)
  3. Proposed adjustments to the process
These aren’t performance reviews. They’re operational checkpoints to ensure the process stays aligned with business goals.
Integrating BPR Follow-Up into Your Culture
Without culture, even the best tools fail. Here’s how to institutionalize BPR follow-up.
Make It Routine, Not Exceptional
Don’t wait for a problem. Build monitoring into your standard operating procedures.
For example:
  • Every Monday morning: Review KPI dashboard for all re-engineered processes.
  • Every month: Process owners submit a brief performance report.
  • Every quarter: Cross-functional team reviews to assess whether the process still aligns with strategy.
This turns monitoring from a compliance task into a leadership habit.
Foster Transparency and Accountability
Share results company-wide—without shame, without blame.
Highlight success stories: “The customer onboarding process hit 98% compliance and reduced turnaround by 17% in Q1.”
When people see progress, they engage. When they engage, innovation continues.
Real-World Example: The Healthcare Claims Process
We worked with a regional health insurer that re-engineered its claims adjudication process. After implementation, the team set up a KPI dashboard tracking:
  • Time to process claim
  • Claims rejected due to errors
  • Customer complaints related to delays
Within two months, the rejection rate spiked. The dashboard flagged it. The process owner initiated a review and discovered a new data entry field wasn’t being validated in the system.
They fixed it in 72 hours. The next month, error rate dropped 42%.
This wasn’t luck. It was continuous process monitoring in action—catching a small flaw before it became a systemic failure.
Key Takeaways: Sustain Process Innovation
Re-engineering is not a single event. It’s a cycle of design, implement, monitor, and improve.
Here’s what to remember:
  • Set up KPIs that reflect business value, not just operational speed.
  • Build a real-time dashboard with clear visual indicators.
  • Assign ownership and schedule regular reviews.
  • Turn monitoring into a cultural habit—part of the new normal.
  • Use data to drive action, not just report status.
When you embed continuous process monitoring into your operations, you don’t just maintain momentum—you amplify it.
How often should we review KPIs after BPR implementation?
Start with weekly monitoring for the first 30 days post-implementation. Then shift to a monthly review cycle. If a KPI shows variance, trigger an urgent review within 48 hours.
Can continuous monitoring work without a dashboard?
Technically yes—but it’s inefficient and error-prone. A dashboard centralizes data, enables trend analysis, and supports quick decision-making. Even a simple Excel tracker with automatic updates is better than no system at all.
Who should own the monitoring process?
Assign a process owner—someone with authority, accountability, and access to the data. It’s not a role for a junior analyst. It should be a mid-to-senior leader who understands both the process and business goals.
What if KPIs don’t improve after re-engineering?
Don’t assume the process is flawed. First, check if the KPIs are correctly defined and data is accurate. Then, investigate whether the change was fully adopted. People often follow old ways unless trained and incentivized to change.
How do we sustain process innovation over time?
By treating every monitoring cycle as an opportunity to improve. Use feedback to refine the process. Celebrate small wins. Make innovation part of the rhythm, not a one-off project.
What’s the difference between continuous monitoring and continuous improvement?
Continuous monitoring is about measuring performance. Continuous improvement is about acting on that measurement. You can monitor without improving—but you can’t sustain innovation without both. Use monitoring to fuel improvement.
