Typical Anti-Patterns in BPMN Adoption
Leitura estimada: 7 minutos 51 vistas
Too many teams treat BPMN like a fancy flowchart. That’s the root of most adoption failures. A BPMN diagram isn’t just a visual aid—it’s a living, executable specification. When you shortcut the method, you risk creating confusion, misalignment, and technical debt. I’ve reviewed hundreds of BPMN diagrams over the past two decades, and the same patterns keep reappearing: jumping straight into tools, overloading diagrams, and modeling from the wrong perspective. These aren’t minor oversights. They’re BPMN adoption pitfalls that make models unusable for automation, audit, or training.
Here’s what you’ll learn: the five most damaging bad BPMN habits that plague teams, why they happen, and how to correct them with real-world examples. This isn’t theory—it’s what I’ve seen break processes in live environments. By the end of this chapter, you’ll know how to spot these common BPMN anti patterns before they cost you time, budget, and credibility.
1. Treating BPMN as a Prettier Flowchart
Many modelers start by sketching a process flow on paper or in a tool, then apply BPMN symbols as if they were decorative. The result? A diagram that looks professional but lacks semantics.
That’s not BPMN. That’s a flowchart with a badge.
Every symbol in BPMN carries meaning. A start event isn’t just a circle; it defines a trigger. A parallel gateway isn’t just a cross—it signals a split in control flow. Mistaking them for visual embellishments leads to ambiguity and misinterpretation.
When you model without a method, you’re not documenting a process—you’re documenting a guess.
Why It Happens
  • Team members are used to simple flowcharts from school or past projects.
  • Leaders expect “a diagram” without clarifying the purpose.
  • Tool vendors promote drag-and-drop ease, reinforcing the idea that design is incidental.
How to Fix It
Start with a modeling purpose. Ask: Who is this for? What decision will it enable? Does it need to be executable?
Use the three-stage approach:
  1. Define scope: What process are you modeling? Where does it start and end?
  2. Define audience: Is this for IT, business, or external auditors?
  3. Choose the right notation: Only then do you assign symbols based on semantics, not aesthetics.
When you treat BPMN as a language—not a painting—you build models that mean something.
2. Jumping Straight into a Tool Without a Method
It’s tempting. Open the tool, click “New Process,” and start dragging shapes. You’ll have a diagram in minutes. But you’ll also have a mess.
Tools don’t teach you BPMN—they enable it. If you skip the method, you’re not modeling; you’re guessing.
I once reviewed a BPMN diagram generated from a spreadsheet. The modeler had no idea what a message flow was. The process had 37 activities, 12 gateways, and no clear ownership. It was a technical nightmare—and completely unusable for automation.
The Hidden Cost of Tool-First Modeling
  • Design decisions are made on the fly, not through intention.
  • Validation features are ignored because the modeler doesn’t know they exist.
  • Patterns from previous models aren’t reused—repetition creeps in.
Best Practice: Model on Paper First
Before touching a tool, sketch the process on paper. Use sticky notes for activities, arrows for flow. This forces clarity.
Ask yourself:
  • Does every activity have a clear owner?
  • Is the flow unambiguous?
  • Do gateways represent decisions, not just branches?
Once the logic is sound, only then bring it into the tool. That way, the tool becomes a precision instrument—not a crutch.
3. Creating One Giant All-in-One Diagram
“We need to see the whole customer journey.” Sure. But “whole” doesn’t mean “all at once.”
Overloading a single diagram with every possible path, exception, and role creates a visual labyrinth. It’s not a model—it’s a memory test.
I once worked with a team that tried to model a loan approval process in one diagram. It included credit checks, underwriting, legal review, stakeholder sign-offs, and multiple retry paths. The flow crossed itself 14 times. No one could read it.
Why It’s a Trap
  • Too many elements → too much visual noise.
  • Too many decision points → hard to validate.
  • Too many lanes → unclear ownership.
How to Break It Down
Use the level-of-detail rule: One diagram should serve one purpose.
Split complex processes using:
  • Sub-processes: Group related steps under a collapsible container.
  • Call activities: Reference reusable templates (e.g., “Credit Check”).
  • Linked diagrams: Use a diagram index or callout to reference other models.
For example:
  • Diagram 1: High-level customer onboarding
  • Diagram 2: Detailed credit check (as a sub-process)
  • Diagram 3: Legal review (external process)
Now the model is readable, maintainable, and scalable.
4. Modeling from a Technical Perspective
Too many models start with “the system” instead of “the business.” This leads to diagrams that look like technical workflows, not process blueprints.
Instead of “User submits form,” you see “POST /api/submit.” Instead of “Approve application,” you see “Call ApprovalService.” These aren’t models—they’re API specs.
Don’t confuse BPMN with system design. BPMN is a business process model. It’s about what happens, not how it’s implemented.
Red Flags of Technical Modeling
  • Activity names include system IDs or URLs.
  • Gateways depend on API response codes.
  • Messages are named after headers or status codes.
Fix: Shift to Business Language
Replace technical jargon with business verbs and objects:
Technical Business
POST /api/submit Submit application form
Call ApprovalService Initiate approval workflow
Handle error 401 Request user re-authentication
Now your model speaks to both business and IT.
5. Ignoring Stakeholder Alignment
A model is only as good as the agreement behind it. When you build a process in isolation, you risk misrepresenting reality.
I once saw a “verified” BPMN diagram where the business said “we review the contract,” but the IT team said “we send it to legal.” The model showed a single “Review” task—but no one could say who did what.
That’s a classic case of unclear responsibility. It leads to handoff delays, rework, and frustration.
How to Align Stakeholders
Use the stakeholder walkthrough technique:
  1. Invite business, IT, and operations to a session.
  2. Walk through the process step by step.
  3. Ask: “Who owns this step? What do they do?”
  4. Use sticky notes to assign ownership in lanes.
  5. Document assumptions and edge cases.
When everyone sees themselves in the model, trust builds—and errors are caught early.
What’s the biggest mistake in BPMN adoption?
Treating BPMN as a flowchart instead of a structured language. Without proper semantics, models become ambiguous, unexecutable, and unreliable.
How do I avoid overload in a BPMN diagram?
Apply the one-model, one-purpose rule. Split complex processes into sub-processes, call activities, or separate diagrams. Use levels of detail to control complexity.
Can I use BPMN for technical workflows?
BPMN is designed for business processes. Use it to model decision logic, handoffs, and responsibilities. For technical workflows, consider UML activity diagrams or sequence diagrams.
How do I handle conflicting stakeholder views in BPMN?
Document differences. Use annotations or alternative paths. Prioritize clarity over consensus. If two stakeholders disagree, label both paths and note the uncertainty.
Should I reuse BPMN elements across teams?
Yes. Build a small library of reusable components (e.g., “Approval,” “Error Handling”). Use a shared repository to ensure consistency and reduce errors.
What should I check in a peer review of a BPMN diagram?
Check for: valid start/end events, correct gateway types, unbroken flow, clear ownership, consistent naming, and stakeholder alignment. Use a checklist to stay systematic.
