Milestones and Stages: Structuring Case Progress
Время чтения: 7 мин. 51 просмотров
One of the most common missteps I see in early CMMN modeling is treating a case as a linear sequence of tasks—when in reality, the power lies in controlling progress through meaningful checkpoints. Many teams struggle to answer simple questions like “Where are we in this case?” or “What has actually been completed?” because their models lack clear, visible milestones. This isn’t about adding more steps—it’s about defining where the real business value is captured.
As someone who’s modeled over 80+ adaptive cases across legal, insurance, and healthcare, I’ve learned that milestones are not just visual flourishes—they’re functional signals that a case has reached a meaningful state. When properly applied, CMMN milestones clarify progress, trigger governance reviews, and allow for better decision-making, even in highly unpredictable environments.
This chapter walks you through how to implement CMMN milestones effectively. You’ll learn how to structure stages, assign milestones, and use them to reflect real business outcomes. You’ll also get a practical CMMN stage example to follow, with real modeling decisions based on actual case workflows.
Understanding CMMN Milestones and Their Purpose
Milestones in CMMN are not just status markers—they’re strategic check-in points that define critical transitions in a case’s life. They signal that a meaningful phase of work has concluded, often tied to a business outcome, not just task completion.
Unlike BPMN, where milestones are often implicit, in CMMN, they’re explicitly modeled—either as events within stages or as standalone elements. This visibility is what makes CMMN ideal for knowledge-intensive, adaptive work.
Think of a CMMN milestone as a “business handshake” between the case and the organization. It says: “This part of the process is complete, and we’re ready to move forward with the next phase—whether that’s approval, review, or escalation.”
Key Functions of CMMN Milestones
  • Progress visibility – Provides a clear, auditable view of where the case stands.
  • Decision triggers – Can activate next stages, alerts, or data updates.
  • Governance checkpoints – Useful for compliance, audits, or regulatory reporting.
  • Performance measurement – Enables cycle time tracking and process analysis.
Implementing CMMN Milestones in Practice
There’s a critical distinction between task completion and milestone completion. Just because a task is done doesn’t mean a milestone is reached. A milestone represents a business outcome—not a technical step.
For example, in a healthcare intake case, completing a patient form is a task. But the milestone “Patient Eligibility Assessed” only triggers when the form is reviewed, data validated, and a decision made. That’s where the real value lies.
Step-by-Step: Adding a CMMN Milestone
  1. Identify the business outcome – Ask: “What is the key result that signals progress?”
  2. Define the preconditions – What tasks, data, or decisions must be in place?
  3. Position the milestone in a stage – Place it at the end of a stage or as a standalone event.
  4. Link to sentry conditions – Use entry criteria to ensure the milestone is only reached when all conditions are met.
  5. Trigger actions – Set up notifications, data updates, or stage transitions when the milestone is achieved.
CMMN Stage Example: Insurance Claim Assessment
Let’s walk through a realistic CMMN stage example from the insurance domain:
  • Stage: Claim Review
  • Tasks: Document verification, fraud check, adjuster assessment, medical review
  • Milestone: Claim Assessment Completed
  • Preconditions: All documents verified, fraud risk low, adjuster report approved
  • Trigger: When the milestone is reached, the case automatically moves to “Approval and Payout” stage.
This example shows how a single milestone—rooted in actual business logic—can govern transitions, improve accountability, and support audit trails.
When to Use Milestones vs. Tasks
One of the most frequent modeling decisions I’ve helped teams settle is: should this be a task or a milestone?
Use a task when the focus is on what work needs to be done. Use a milestone when the focus is on when the work has been meaningfully completed.
Here’s a quick decision guide:
Use Case Best Practice
Work requiring human judgment Use milestone to capture outcome
Repeating or automated steps Use task; milestone adds no value
Regulatory or compliance checkpoints Use milestone with audit trail
Internal coordination between teams Use milestone to signal handoff
Never add milestones for the sake of formality. Every milestone should answer a real business question: What does completion mean here?
Aligning Milestones with Case Stages
Milestones are most powerful when they’re integrated into stages. A stage represents a major phase of work—like “Investigation,” “Review,” or “Approval.” A milestone within that stage acts as the closing event.
For example, in a legal case management scenario:
  • Stage: Evidence Gathering
  • Milestone: Evidence Collected and Verified
  • Consequence: Triggers next stage: “Case Preparation”
This structure gives clarity to case workers, managers, and auditors. It’s not just about “what’s been done”—it’s about what has been decided.
Common Pitfalls to Avoid
Even experienced modelers make mistakes with CMMN milestones. Here are the most frequent ones I’ve observed, along with how to fix them:
  • Mistake: Using milestones for every task or small step.
  • Fix: Limit milestones to 2–4 per case. Focus on outcomes, not actions.
  • Mistake: Not defining clear preconditions for milestone triggers.
  • Fix: Always specify exactly what must be true before the milestone is reached.
  • Mistake: Overloading milestones with multiple outcomes.
  • Fix: Split milestones when needed. One milestone = one business result.
  • Mistake: Using milestones without any downstream effects.
  • Fix: Ensure each milestone triggers a meaningful transition, action, or notification.
Best Practices for CMMN Modeling
Based on over 20 years of modeling experience, here are my top recommendations for CMMN milestones:
  1. Anchor milestones to business outcomes — Never model a milestone unless it corresponds to a real decision or event.
  2. Use consistent naming — Follow a pattern like “[Activity] Completed” or “[Outcome] Assessed” for clarity.
  3. Limit to 3–5 milestones per case — Too many dilute the signal and reduce impact.
  4. Integrate with case file items — Link milestone achievement to data updates (e.g., status = “assessed”).
  5. Document rationale — Add a note explaining why the milestone matters and who decides it.
What is the difference between a CMMN milestone and a stage?
A stage represents a phase of work—like “Claim Review” or “Patient Intake.” A milestone is a specific event that signals the completion of that phase. You can have multiple tasks within a stage, but only one milestone per outcome.
Can I have more than one milestone in a single stage?
Yes, but only if they represent distinct outcomes. For example, a stage might include “Evidence Collected” and “Witness Statements Verified” as two separate milestones. However, avoid redundancy—each milestone should represent a unique business decision.
How do I model a milestone that depends on multiple conditions?
Use a compound sentry condition. In Visual Paradigm, combine conditions with AND/OR logic. For example: “Documents submitted AND fraud check passed AND adjuster sign-off received.”
Are CMMN milestones mandatory in every case model?
No. Only include them when they serve a functional purpose—such as triggering a next stage, enabling a review, or supporting audit compliance. If there’s no business reason, skip it.
Can a milestone be reached without completing all tasks in a stage?
No—milestones should only be triggered when all required tasks and conditions are met. If you need a milestone that doesn’t require full completion, consider using a conditional gate or a note instead.
How do milestones integrate with DMN or BPMN in a hybrid model?
Milestones can be linked to decision tables in DMN—e.g., “If risk score ≥ 80, then activate the high-risk milestone.” They can also trigger BPMN subprocesses, such as “When Claim Assessment Completed, start Payment Processing BPMN flow.”
Understanding CMMN milestones is not about adding more elements to your model. It’s about making your case models intentional, traceable, and meaningful. When applied correctly, they transform case models from diagrams into dynamic coordination tools.
As you continue your journey with CMMN, remember: the best models don’t just show what’s happening—they tell you why it matters. Use milestones to reflect that truth.
