Structuring Models for Maintainability
Время чтения: 7 мин. 50 просмотров
Good models don’t just work — they endure. The most powerful CMMN models are those that stay clear, reusable, and adaptable over time.
When I’m handed a tangled CMMN diagram with unclear naming and no structure, I don’t rush to fix it. I pause. That’s where the real work begins.
Adopting consistent CMMN best practices isn’t about bureaucracy. It’s about creating models that serve their users — not just today, but months from now when new people join the team or business rules shift.
This chapter walks you through how to build a maintainable CMMN model using clear naming, modular design, and thoughtful visual layout — all grounded in real experience from modeling across insurance, healthcare, and support operations.
Establishing Naming Conventions for Clarity
Name your elements like you’re explaining them to a colleague who’s never seen the case before.
Use verbs to describe actions. Keep names descriptive but concise. Avoid acronyms unless they’re universally understood, and never rely on placeholder labels like “Task 1” or “Step A”.
For example, instead of “Task 1”, use “Review Claim Documentation” or “Verify Medical Records”.
These names don’t just describe what happens — they imply intent, which helps clarify business purpose.
Key Naming Principles
  • Start with a verb — “Submit,” “Approve,” “Escalate,” “Verify.” It signals action.
  • Use consistent capitalization — Title Case is standard. Avoid ALL CAPS or mixed case.
  • Keep names short but unambiguous — Aim for 3–6 words. Too short = vague. Too long = clutter.
  • Reference business terms, not technical ones — “Case File” is better than “CF_01” or “InputData1”.
When you name tasks and stages this way, you reduce cognitive load. Team members can read the model and understand it without needing to decode a codebook.
Breaking Down Complexity with Modular CMMN Design
Large cases are rarely monolithic. They’re collections of interrelated sub-tasks, decisions, and review points — each potentially reusable across multiple case types.
Modular CMMN means structuring your model so that independent components can be reused, tested, and updated without affecting the whole system.
Think of it like Lego blocks: each block has a purpose, fits together logically, and can be swapped out without dismantling the entire structure.
How to Achieve Modularity in Practice
  • Use case plan fragments — Isolate reusable subroutines, such as “Document Verification” or “External Review Request,” into their own fragments.
  • Define clear boundaries — A modular task should have a single responsibility. If it does more than one thing, split it.
  • Use parameters for variation — Instead of duplicating logic, pass in variables like “claim type” or “customer tier” to adapt behavior.
  • Reference fragments via case plan items — Use dependency links to invoke reusable logic based on context.
At a financial services client, we reused a single “Fraud Detection Review” fragment across five different case types. When the rules changed, we updated one fragment — and all cases were instantly aligned.
This is the power of modular CMMN: one change, multiple impacts.
Visual Layout: The Unseen Backbone of Readability
Even a perfectly structured model can fail if it’s messy to read. A cluttered diagram forces the user to retrace paths, lose context, and misinterpret dependencies.
Visual clarity isn’t about aesthetics. It’s about minimizing mental effort. A clean layout helps modelers, reviewers, and stakeholders focus on logic, not navigation.
Layout Guidelines for Maintainable CMMN Models
  • Group related elements together — Tasks under the same stage should be visually clustered. Use consistent spacing and alignment.
  • Use stages as visual anchors — Design stages with clear horizontal or vertical flow. This creates a natural reading path.
  • Minimize crossing lines — Lines that intersect or crisscross create confusion. Route dependencies carefully, possibly using curved arrows or staggered placement.
  • Reserve space for annotations — Add brief notes near complex logic, but keep them concise. Avoid text-heavy boxes.
Some modeling tools (like Visual Paradigm) allow auto-layout algorithms. Use them — but never treat them as final. Always review and adjust.
Strategic Use of Case File Items
The case file isn’t just a data repository. It’s the central nervous system of the case.
When you define what data is needed and how it flows, you’re not just documenting — you’re building a reusable data model.
For a healthcare case, we modeled “Patient Consent Form,” “Diagnosis Code,” and “Referral Date” as case file items. Each was referenced in multiple tasks, ensuring consistency and traceability.
Best Practices for Case File Items
Item Type Use Case Best Practice
Document Reference Insurance claim forms, medical records Name with version or date: “Discharge Summary v2.1”
Boolean Flag “Is Verified?”, “Escalated?” Use clear labels: “Verification Complete”
Timeline Indicator “Next Review Date” Link to sentry triggers
Free-Text Note Team comments, audit trails Use structured format: [Analyst] [Date] [Comment]
By standardizing how case file items are defined and used, you ensure the model stays consistent across teams and case types.
Ensuring Long-Term Maintainability
A model is only as good as its ability to evolve. I’ve seen teams waste weeks reworking outdated diagrams because no one knew where to start or what had changed.
It’s not enough to build a model that works today. It must be designed to adapt — not just with new requirements, but with new people.
Checklist: Is Your CMMN Model Maintainable?
  1. Are all tasks and stages named with clear, verb-based, business-relevant terms?
  2. Can key sub-processes be reused across multiple case types?
  3. Is the visual layout clean, with minimal crossing lines and logical grouping?
  4. Are case file items well-defined and consistently referenced?
  5. Can a new modeler understand the model in under 10 minutes?
If you answered “no” to any, it’s not broken — it’s just due for a refactoring.
Refactoring isn’t deleting. It’s simplifying, organizing, and clarifying. And that’s when a model truly becomes a living artifact.
How do I avoid overcomplicating a CMMN model?
Start simple. Design for common scenarios first. Add complexity only when justified. Ask: “Would this change make the model harder to understand?” If yes, reconsider. Use fragments and reuse to manage complexity without bloating the diagram.
Can I reuse the same task in multiple cases?
Absolutely. That’s a core principle of modular CMMN. Use shared task definitions and pass context via case file items. Just ensure the task’s logic is independent of the case type.
What’s the difference between a stage and a task in CMMN?
A stage is a grouping of related tasks and milestones. A task is an individual executable activity. Stages define progress and structure; tasks represent work. You can have a stage with no tasks, but a task must belong to at least one stage.
Should I use color coding in my CMMN model?
Use color sparingly. It can help highlight critical paths or ownership, but don’t rely on it alone. Ensure the model is understandable in black and white. Use color only to support, not substitute, clear labeling and layout.
How do I handle model versioning in practice?
Use versioning at the model level — e.g., “ClaimReview_v2.1”. Always document changes: “Added fraud check sentry.” Store versions in a shared repository with clear naming. Avoid renaming models unless necessary.
Why should I care about maintainable CMMN model design?
Because a model that’s hard to maintain becomes obsolete fast. A well-structured, reusable CMMN model reduces onboarding time, prevents errors, supports audits, and enables faster adaptation to change. It’s not a side benefit — it’s the foundation of effective case management.
