Defining the Problem Visually within the Fishbone
Время чтения: 7 мин. 66 просмотров
When I walk into a room where a Fishbone diagram is being built, the first thing I check is not the branches, but the head: the effect written on the right. That single line can determine whether the session becomes a productive investigation or a drift toward speculation. A well-defined fishbone problem turns ambiguity into focus. It turns a vague complaint like “Our customer service is bad” into a measurable, unambiguous statement such as “Customer complaint resolution time exceeds 48 hours.” This clarity is the foundation of real improvement.
Over two decades of leading RCA workshops taught me one truth: the quality of your problem statement directly shapes the quality of your findings. A poor effect definition leads to unfocused causes, wasted time, and decisions based on assumption. The goal isn’t to solve everything — it’s to solve the right thing. This chapter guides you through how to define the fishbone problem with precision, using a structured, evidence-based approach.
Why the Effect Must Be Specific and Measurable
A strong problem statement answers: What is the deviation? From what benchmark? When and where did it occur?
Consider these two examples:
  • “Our team is late on deliveries” — too vague.
  • “Delivery order completion rate dropped below 85% in Q3 2024, with 12% of orders delayed by more than 48 hours.” — measurable and specific.
The second statement allows you to define boundaries, set data collection goals, and anchor the Fishbone to facts, not feelings.
Ask yourself: Can I measure this? Can I verify it with logs, data, or observations? If not, you’ve not defined the fishbone problem correctly. The effect must be a clear, objective deviation from expected performance.
Checklist: Is Your Effect Statement Ready?
  • ✅ It describes a real, observable deviation (e.g., dropped conversion rate, increased downtime)
  • ✅ It includes a timeframe or context (e.g., “during peak load”, “in August 2024”)
  • ✅ It’s quantifiable — can you track it with data?
  • ✅ It avoids blaming individuals or departments
  • ✅ It’s concise — one sentence, no jargon
When I review a Fishbone, I use this checklist. If the effect fails even one item, I pause the session to clarify.
Creating the Ishikawa Diagram Head: The Cause-Effect Definition
The Ishikawa diagram head is not just a place to write a problem — it’s the invitation to investigate. It must reflect a clear cause-effect relationship.
Think of it this way: the effect is the outcome. The causes are the variables that contributed to it. If you can’t name the cause, you can’t fix it. If you can’t measure the effect, you can’t prove the fix worked.
Common mistakes when writing the effect include:
  • Using emotional language: “The process is broken.”
  • Assigning blame: “The warehouse team caused the delay.”
  • Being too broad: “We’re not doing well.”
Instead, write effects using a simple structure:
“[Outcome] has [deviation] in [context] during [timeframe].”
This format forces objectivity. It removes emotion and positions the investigation as a system check, not a blame game.
Examples of Strong Fishbone Problem Statements
Weak Effect Strong Effect (Cause-Effect Definition)
“Customers are unhappy.” “Customer satisfaction score dropped to 3.2/5 in Q2, down from 4.1 in Q1.”
“We keep missing deadlines.” “Project delivery deadlines were missed in 15 out of 20 tasks in June 2024.”
“The system crashes.” “The order processing system crashed 12 times in the last 72 hours during peak load.”
Each strong effect allows you to define the scope of your investigation — and that scope is critical. A problem that’s too broad leads to a fishbone with too many causes. A problem too narrow may miss systemic links.
Aligning the Scope: What You Include (and Exclude)
Defining the fishbone problem isn’t just about wording — it’s about setting boundaries. I once facilitated a session where the team tried to analyze “all quality issues in production.” That spanned six departments, five systems, and three product lines. We couldn’t even finish the first category before the meeting ended.
Instead, I asked: “For this investigation, what are we really trying to fix?” After discussion, we narrowed it to: “Why did 22% of orders shipped late in the central warehouse last week?” That scope was manageable, data-rich, and actionable.
Use these filters to clarify scope:
  1. Timeframe: Limit to a clear window (e.g., “July 1–10, 2024”).
  2. Location or system: Specify the process, line, department, or software module.
  3. Impact: Define the measurable outcome (e.g., delay, defect rate, cost overrun).
  4. Exclusions: State what’s not in scope to prevent scope creep.
When I run sessions, I write the problem statement on a whiteboard and ask: “If this were a newspaper headline, would it make sense to someone outside the team?” If not, we revise.
Even with good intentions, teams fall into traps when defining the fishbone problem.
Trap 1: Confusing Symptoms with Causes
Example: “We have too many support tickets.” This is a symptom — not the effect.
Root cause: “Support ticket volume increased by 60% in July 2024 compared to June.” That’s the effect.
Now, you can investigate what caused the spike — maybe a new feature rollout, a bug, or training gap.
Trap 2: Using Passive or Vague Verbs
“The system isn’t working.” “The process is off.” These are not measurable.
Replace with active, observable verbs: “Failed to process orders”, “Rejection rate increased to 14%”, “Response time exceeded 10 seconds.”
Trap 3: Including Too Many Effects
Don’t try to solve “delays, poor quality, and customer complaints” in one diagram. Pick one primary effect. If you have multiple problems, run multiple Fishbones.
Remember: each fishbone is a focused investigation, not a catch-all.
What’s the best way to write a fishbone problem statement?
Use a clear, measurable format: “[Outcome] deviated from expected [benchmark] in [context] during [timeframe].” Avoid emotion, blame, and ambiguity. Example: “Call center first-call resolution dropped to 62% in Q3, down from 80% in Q2.”
Can I use the same fishbone problem statement for multiple RCA sessions?
Only if the issue is identical. If you’re analyzing different timeframes, locations, or product lines, revise the statement. Two different effects require two separate diagrams, even if they seem similar.
How do I handle a problem that has multiple effects?
Start with the most severe or impactful effect. If you need to analyze multiple outcomes, create separate Fishbones. You can later map relationships across diagrams using cause-effect chains or matrix analysis.
Is it okay to change the problem statement mid-process?
Yes — but only after review. If data shows the original effect was misidentified, adjust it with team agreement. Document the change and justify it. Never force a mismatch between problem and causes.
What if the team disagrees on the problem definition?
Use data to resolve conflict. Bring in logs, metrics, or customer feedback. Ask: “What does the evidence say?” Focus on facts, not opinions. This is where the fishbone problem statement becomes your anchor.
How does defining the fishbone problem affect the rest of the RCA process?
A precise problem statement ensures that brainstorming stays focused, cause validation is data-driven, and corrective actions are relevant. It prevents wasted effort, misaligned solutions, and recurring issues. The quality of your outcome is a direct function of the quality of your problem definition.
When I started using the fishbone method, I thought the branches were the hard part. I’ve learned that getting the head right — the effect — is where real power begins. A well-defined fishbone problem doesn’t just guide your analysis — it shapes your team’s thinking, ensures alignment, and builds trust in the process.
Go back to your last RCA meeting. Look at the effect. Ask: Is it measurable? Is it specific? Can someone else verify it? If not, revise it. That small step will save you hours of misdirected effort and bring you one step closer to lasting improvement.
