State Machine Diagrams: Tracking Object States
Время чтения: 7 мин. 113 просмотров
A state machine diagram captures how an object changes over time in response to events. It’s not just a flowchart — it models behavior across the full lifespan of an object, from initial state to final completion.
When I teach UML state machine basics, I start with one truth: objects don’t exist in a vacuum. They evolve. A simple order can begin as «created,» then move to «confirmed,» «shipped,» and finally «delivered.» The state machine diagram makes that journey visible and unambiguous.
This chapter gives you a practical, experience-based guide to drawing and reading UML state machine diagrams. You’ll learn the core components — states, transitions, events, and guards — with clear examples that mirror real systems, especially those you’ll encounter in e-commerce, workflow engines, or user-facing applications.
You’ll walk away knowing how to identify meaningful states, avoid overcomplicating transitions, and use guards to prevent invalid state changes — all critical for robust, maintainable software.
Understanding States and Transitions
Every object has a lifecycle. A state is a condition during which the object satisfies certain criteria. Think of it as a snapshot: the object is “in” that state, and it only changes when an event triggers a transition.
Transitions are the changes between states. They are not random — they occur in response to specific events, like a user clicking a button or a system receiving a signal.
For example, in a payment system, an order might be in the state “Pending.” When the payment confirmation event arrives, a transition occurs to “Confirmed.”
Key Elements in a State Machine Diagram
  • State: A condition where an object is active. Represented as a rounded rectangle.
  • Transition: An arrow from one state to another, showing movement due to an event.
  • Event: A signal or condition that triggers a change (e.g., «Payment Received»).
  • Guard: A condition that must be true for a transition to occur. Written in square brackets.
  • Initial State: A filled circle with an arrow pointing to the first state.
  • Final State: A bullseye (filled circle inside an outline) signaling the end of behavior.
These elements work together to model behavior with precision and clarity.
Modeling Real-World Object States in UML
Let’s walk through a simple but realistic example: an online order system.
Here’s how the states might evolve:
  1. Created – The order is placed but not yet paid.
  2. Pending Payment – The user is in the checkout process.
  3. Confirmed – Payment received, order is valid.
  4. Shipped – The product has been dispatched.
  5. Delivered – The customer has received the package.
  6. Cancelled – The order was terminated before delivery.
Each of these states represents a meaningful condition in the order’s life. Transitions between them are driven by events like “Payment Received,” “Shipment Confirmed,” or “User Cancels.”
Now, consider this: what if a user tries to cancel an order that’s already “Shipped”? That’s where guards come in.
Using Guards to Prevent Invalid Transitions
Guards are conditions that must be true for a transition to occur. They act as a safety net.
For example:
Cancel → Cancelled [status == "Created" OR status == "Pending Payment"]
This means the “Cancel” transition only happens if the order is still in an early state. If the order is already “Shipped,” the guard fails, and the transition is blocked — preventing logic errors and miscommunication.
Using guards is a best practice in UML state machine basics. It keeps your model aligned with actual business rules.
When to Use a State Machine Diagram
Not every object needs a full state machine. But when behavior depends heavily on a sequence of conditions, it’s time to model it.
State machine diagrams shine in scenarios like:
  • Workflow engines (e.g., approval processes)
  • Device states (e.g., printer: Idle, Printing, Out of Paper)
  • User session management (e.g., Logged Out, Logged In, Locked)
  • Payment processing (e.g., Pending, Verified, Failed, Refunded)
When you find yourself asking “What happens next?” in a step-by-step way, and the answer depends on previous states, a UML state machine diagram is your tool.
Decision Tree: Should You Use a State Diagram?
Question Yes No
Does the object have multiple distinct conditions?
Do transitions depend on events or data?
Is the behavior sequential or conditional?
Are there more than 3 states?
If you answered «Yes» to most, a state diagram is likely the right choice.
As someone who’s reviewed hundreds of UML diagrams, I’ve seen recurring mistakes. Here’s what to watch for:
  • Too many states: A complex system shouldn’t become a spaghetti diagram. Use composite states if needed — group related states under a parent.
  • Missing guards: Transitions without conditions can lead to invalid behavior. Always ask: “Could this happen at the wrong time?”
  • Overusing events: Not every action needs an event. Use events only for external triggers — not for internal state checks.
  • Confusing state with activity: A state is a condition; an activity is an action. Don’t conflate “waiting for payment” (state) with “processing payment” (activity).
These mistakes aren’t just confusing — they sabotage maintainability. Simplicity is your ally.
Best Practices for Beginners
  1. Start with a minimal set of states — only include what’s essential.
  2. Use clear, plain-English labels (e.g., «Pending» instead of «STATE_01»).
  3. Always name transitions with the event, optionally followed by a guard in brackets.
  4. Group related states under composite states when behavior is shared.
  5. Validate your model with a colleague: “Can this object get stuck?”
These tips are drawn from real projects — and they work.
Practical Example: Order Lifecycle in UML
Let’s diagram the order lifecycle from start to finish.
Initial State → Created
Transition:
Click "Pay" → Pending Payment [payment_method_selected]
Then:
Payment Received → Confirmed [payment_verified]
Later:
Shipment Confirmed → Shipped
Finally:
Delivery Confirmation → Delivered
And:
Cancel Button → Cancelled [status == "Created" OR status == "Pending Payment"]
Notice how the guard prevents cancellation after shipping. This isn’t just theory — it’s how real systems avoid revenue loss.
With just a few states and transitions, you now have a complete, executable model of the order lifecycle.
What is a state diagram for beginners?
A state diagram is a visual way to model how an object changes over time. It shows states, transitions, and the events that cause changes — perfect for understanding object behavior in software systems.
How do I start drawing a UML state machine diagram?
Start by identifying the object’s lifecycle. List its main states (e.g., Created, Confirmed, Delivered). Add initial and final states. Then connect them with transitions triggered by events. Use guards where needed to enforce business rules.
Can a state have multiple incoming transitions?
Yes. A state can have multiple incoming transitions from different events. This is normal and often necessary. For example, an “Order” can go to “Confirmed” from “Payment Received” or “Manual Approval.”
What’s the difference between a state and an activity?
A state is a condition (e.g., “Waiting for Payment”). An activity is an action (e.g., “Process Payment”). In a state machine diagram, you model states and transitions. Activities are usually part of activity diagrams or sequence diagrams, not state diagrams.
When should I use a state machine over a sequence diagram?
Use a state machine diagram when you care about the lifecycle of a single object. Use a sequence diagram when you need to model interactions between multiple objects over time. They’re complementary, not interchangeable.
How do I avoid infinite loops in a state machine?
Ensure every loop has a clear exit condition. Use guards to prevent cycling indefinitely. For example, a “Pending” state should only allow transition to “Confirmed” when a valid event occurs — not on every request. Always test transitions manually or with a tool.
