Understanding Events, Activities, and Gateways
预计阅读时间7 分钟 121 浏览
When you start drawing your first BPMN diagram, the temptation is to jump straight into boxes and arrows. But here’s the truth: every solid process model begins with a deep understanding of just three building blocks. These aren’t just shapes—they’re logic carriers. Mistakes happen early when we treat them as decoration instead of decision points.
Over two decades of guiding teams through their first process maps taught me this: beginners often confuse activities with events, or misapply gateways, leading to diagrams that look correct but don’t reflect real workflow logic. You don’t need to master every rule on day one. But you do need to know how events, activities, and gateways work together to form the backbone of any process.
This chapter will walk you through each element with actual examples from real-world processes. You’ll learn how to identify the right event type, choose the proper activity, and place gateways that make sense—not just look right. By the end, you’ll have the confidence to build diagrams that communicate clearly to developers, managers, and clients alike.
Core BPMN Elements Explained
BPMN is built on three fundamental components: events, activities, and gateways. They’re the grammar of business process diagrams—each with a role, a syntax, and real-world meaning.
Events: Triggers and Outcomes
Events are the start and end points of a process. They mark a moment when something happens—a signal, a condition, or a state change.
There are three main types: start, intermediate, and end events. Each has subtypes that define their behavior.
  • Start events initiate a process. They can be triggered by time, messages, or conditions.
  • Intermediate events occur during a process and don’t end it. They can be used to catch errors, timers, or messages.
  • End events mark the completion of a process. They can signal success, failure, or cancellation.
Think of a loan approval process: the start event might be “Loan application received.” The end event could be “Approval granted” or “Application rejected.” An intermediate event might be “Credit check completed” or “Fraud alert triggered.”
Activities: Work to Be Done
Activities represent the work that happens within a process. They’re the action steps—something that takes time and resources.
There are three types:
  1. Task: A single piece of work with no internal steps.
  2. Sub-process: A group of tasks that can be collapsed or expanded.
  3. Transaction: A special type of sub-process that must complete fully or not at all.
For example, in a customer onboarding workflow, “Verify identity” and “Collect address details” are tasks. “Complete onboarding” might be a sub-process containing multiple steps: document upload, background check, and contract signing.
No matter how simple or complex, every activity must have a clear name and purpose. Avoid vague labels like “Do something” or “Process data.” Instead, use verbs: “Verify documents,” “Send notification,” “Update database.”
Gateways: Decision Points That Shape Flow
Gateways control the flow of a process. They’re the logic switches—where choices are made.
There are four main gateways:
  • Exclusive (XOR): Only one path fires. Use for decisions: “Is the customer in good standing?”
  • Parallel (AND): All outgoing paths must be taken. Use for concurrent tasks: “Notify team and log incident.”
  • Inclusive (OR): One or more paths can fire. Use when multiple conditions may apply.
  • Complex: A combination of logic, used in advanced flows.
Consider a support ticket workflow: after “Receive request,” a gateway decides whether to “Escalate” or “Assign to agent.” That’s XOR. If “Assign to agent” and “Send acknowledgment” both happen, that’s AND.
Remember: gateways don’t cause work—they direct it. The path you choose depends on conditions, not tasks.
How BPMN Elements Work Together
Understanding each element in isolation is only half the battle. The real magic happens when they interact.
Let’s walk through a realistic example: a BPMN activity example for an employee vacation request.
  1. Start event: “Vacation request submitted”
  2. Activity: “Verify leave balance”
  3. Gateway: “Is balance sufficient?”
  4. If YES: Activity “Approve vacation” → End event “Request approved”
  5. If NO: Activity “Notify employee of insufficient leave” → End event “Request denied”
Now, suppose the HR manager can also reject the request without checking balance. That’s where BPMN gateways explained come in. You’d use an inclusive gateway: “Is balance sufficient OR manager rejects?”
This is how you build logic that reflects real decisions, not just flow. The gateway determines the path, but the activity defines the work.
I’ve reviewed hundreds of beginner diagrams. Here are the most frequent mistakes—and how to fix them.
1. Using Events Where Activities Belong
Don’t label a task as “Send email.” Instead, use “Send approval email.” If you need a message event, mark it with a circle and a message icon.
Start events should be triggers—like “Payment received” or “System alert.” They’re not actions.
2. Overusing Parallel Gateways
Parallel flows are powerful—but they can overwhelm a process. Use them only when multiple tasks must happen independently and simultaneously.
Ask: “Could this step happen before or after the others?” If not, XOR is better.
3. Confusing Intermediate Events
Intermediate events are often misused. They’re not for steps. They’re for catching conditions: “Timer expires,” “Error occurs,” or “Message received.”
Use intermediate events only when the flow must pause to respond to something external or conditional.
4. Ignoring Sequence Flow Rules
Sequence flows connect elements. But their direction matters. Always flow from source to target. Never cross flows unless absolutely necessary.
Ensure every activity has a clear path forward. A task with no outgoing flow is invalid.
Decision Tables: A Practical Application
When modeling complex logic, decision tables are your friend. They help you map conditions and outcomes clearly—without cluttering the diagram.
For example, in a loan approval process, a decision table can define: “If credit score > 700 AND income > $50K → Approve.”
Instead of drawing multiple gateways, you can summarize the logic in a table and link it to a decision activity.
This keeps your diagram clean and makes validation easier. It also aligns with how business rules are often documented.
Best Practices for Clear, Effective Diagrams
Here’s what I’ve found works consistently in real teams:
  • Use consistent naming: “Submit form” not “Do it.”
  • Keep flows top-to-bottom unless direction improves readability.
  • Use swimlanes to assign responsibilities—don’t assume one person handles all tasks.
  • Limit gateways per task. More than two per decision point gets hard to read.
  • Always validate your model: does the flow make logical sense? Can it be executed?
When in doubt, ask: “Would someone not on the team understand this?” If not, simplify.
What are the main BPMN events types?
Start events (e.g., message start), intermediate events (e.g., timer, message catch), and end events (e.g., success, error). Each has specific triggers and behaviors.
Can you give a BPMN activity example?
Yes. “Verify identity documents” is a clear task. “Process customer application” is a sub-process. “Complete payment processing” is a transaction. These are all valid activities.
How do BPMN gateways explained in simple terms?
Gateways decide which path to take. XOR = choose one. AND = take all. OR = one or more. They’re logic switches, not action points.
What’s the difference between a task and a sub-process?
A task is a single work unit. A sub-process is a group of tasks that can be collapsed. Use sub-processes to manage complexity.
Why is my BPMN diagram not flowing correctly?
Check for missing sequence flows, invalid gateways, or missing start/end events. Ensure all paths are connected and decisions are clear.
How do I model a complex decision without clutter?
Use decision tables or a decision activity linked to a DMN model. This keeps the BPMN diagram clean while preserving logic.
With these fundamentals, you’re not just drawing a picture—you’re building a map of logic. The more clearly you model events, activities, and gateways, the more powerful your process will become. And the best part? You don’t need to be a developer or analyst to start.
Every modeler begins where you are now: with a blank canvas, a few elements, and the courage to connect the dots. You’ve got the tools. Now go build something meaningful.
