Data and Artifacts in BPMN
Geschätzte Lektüre: 7 Minuten 84 Ansichten
Many beginners assume that BPMN diagrams must focus solely on tasks, events, and decisions—anything else is extra. But that’s a common misstep. In reality, data elements are not mere decorations. They are part of the core logic. BPMN data objects give context to actions, define input and output requirements, and help bridge the gap between process flow and real-world data handling. Without them, a diagram may be visually correct but semantically incomplete.
As someone who’s guided over 50 teams through their first BPMN modeling projects, I’ve seen how omitting data objects leads to confusion, especially when analysts hand off diagrams to developers or auditors. The absence of data representation often means the process can’t be validated, automated, or even understood outside the original team.
This chapter shows you how to use BPMN data modeling effectively. You’ll learn to distinguish between data objects, data stores, and artifacts—how to place them properly, when to use each, and how they contribute to a complete, professional diagram. You’ll also see how BPMN documentation elements like annotations add clarity without disrupting flow.
Understanding BPMN Data Objects
BPMN data objects represent information that a process acts upon. They’re not just labels—they are tangible inputs and outputs tied to activities.
Think of a data object as a document, file, or dataset that a task reads, modifies, or creates. Every time a task starts or ends with data, that data should be shown.
For example, in an invoice approval process, the “Review Invoice” task might consume an invoice document and produce a signed copy. That’s where data objects come in.
How BPMN Data Objects Work
Use the data object symbol: a rectangle with a folded corner. It’s attached to activities via a dotted line.
You attach a data object to a task to indicate what information is involved. The line connects the object to the task, but doesn’t imply flow—just relationship.
For example:
  • Input: The “Generate Report” task requires a “Monthly Sales Data” object.
  • Output: The same task produces a “Finalized Report” object.
This simple addition tells developers where data comes from and what’s expected at the output.
Key Data Elements in BPMN
Data Objects vs. Data Stores
While data objects represent data used within a process, data stores represent persistent repositories—like databases or file systems—where data resides across multiple processes.
Use a data store to show where data is stored long-term. It’s a rectangle with a small circle in the corner, often labeled with a name like “Customer Database” or “Sales Ledger”.
Here’s when to use each:
Use Case Data Object Data Store
Temporary data used in a single task ✔️ Yes ❌ No
Data persisted across multiple processes ❌ No ✔️ Yes
Document created or consumed in workflow ✔️ Yes ❌ No
Master record stored in a system ❌ No ✔️ Yes
Artifacts: Enhancing Clarity Without Disruption
BPMN artifacts are visual aids. They’re not part of the flow but provide context.
Three main types:
  • Annotations: Text boxes that explain a task or condition.
  • Groupings: Rectangles that group related tasks, useful for highlighting subprocesses or phases.
  • Data objects: As described above, they’re both artifacts and core elements.
Use annotations to clarify complex logic, like “Only if customer has premium status” or “Pending IT approval.” They’re not required, but they dramatically improve readability—especially in diagrams with multiple decision points.
Best Practices for BPMN Data Modeling
Modeling data correctly isn’t about adding everything. It’s about choosing what’s necessary.
Start with the essentials: Inputs and outputs
Ask: “What data does this task need to start?” and “What data does it leave behind?”
Only include data objects that are actually involved in the task’s execution.
For example, in a “Validate ID” task, you’d include “ID Document” as input. But if the validation is automated, you might not need to show output unless a new document (like a validation result) is generated.
Keep names consistent and meaningful
Don’t use vague names like “Data1” or “File.” Instead, use descriptive, clear labels:
  • “Customer Application Form”
  • “Payment Confirmation Receipt”
  • “Updated Inventory List”
Consistent naming prevents confusion during handover to developers or auditors.
Use data stores for external systems
When a process reads or writes to a database, don’t duplicate the data flow. Instead, link the activity to the data store.
Example: The “Update Customer Record” task connects to the “Customer Database” data store. This signals to stakeholders that this action affects persistent data.
Don’t overuse artifacts
Annotations are helpful, but too many clutter the diagram. Limit them to critical context—like business rules, exceptions, or ownership notes.
For instance, instead of annotating every task, focus only on complex decisions, high-risk steps, or steps requiring approval.
Real-World Example: Loan Approval Process
Let’s walk through a simple but practical example using BPMN data objects and artifacts.
Consider a loan approval workflow:
  1. Application Received: Input: “Loan Application Form”
  2. Verify Credit History: Input: “Customer Credit Report”, Output: “Credit Summary”
  3. Review by Manager: Input: “Credit Summary”, Output: “Approval Decision”
  4. Notify Applicant: Input: “Approval Decision”
Each task interacts with a data object. The “Customer Credit Report” is fetched from the “Credit Bureau Database” data store.
Annotate the “Review by Manager” task with: “Requires sign-off from regional manager if loan > $50,000.”
This model is clear, traceable, and audit-ready—exactly what BPMN documentation elements should achieve.
Overloading the diagram with data objects
Don’t add every piece of data involved. Focus on the ones that directly affect the task’s inputs or outputs. For example, a “Send Email” task only needs “Email Template” and “Recipient List” — not the entire customer database.
Confusing data objects with messages
Data objects are not message flows. Messages represent communication between participants. Data objects are about data handling within a single process.
Use message flows only when one pool sends a message to another (e.g., “Approve Loan” from one system to another).
Ignoring data store labeling
Always label your data stores. “Customer Database” is better than just “Database.” This clarity prevents ambiguity during process audits or system integration.
How to Validate Your BPMN Data Modeling
After modeling, check your work using this quick checklist:
  • Every task has a clear data input and output if applicable.
  • Data objects are named meaningfully and consistently.
  • Data stores are used only for persistent, external data.
  • Annotations are used only for critical context, not every task.
  • There’s no redundant data connection—only meaningful relationships.
Run this checklist before sharing your diagram with developers, auditors, or clients. It ensures your model isn’t just visually correct but operationally sound.
What is the purpose of BPMN data objects?
BPMN data objects represent information that a task uses or produces. They clarify what data is involved in a process step, helping to validate logic, support automation, and improve communication across teams.
When should I use a data store instead of a data object?
Use a data store when data is stored long-term and accessed across multiple processes—like a database or file system. Use a data object when the data is temporary and used within a single task or subprocess.
Can BPMN artifacts affect process execution?
No—artifacts like annotations and groupings are purely visual. They don’t affect execution. But they enhance readability and support stakeholder understanding, especially in complex diagrams.
Do all BPMN tools support data objects and data stores?
Yes—BPMN 2.0 standard includes them. Most modern modeling tools like Visual Paradigm support these elements. Always verify your tool’s version and ensure it complies with BPMN 2.0.2.
How do data objects improve BPMN documentation elements?
Data objects add traceability. They show exactly what data is being processed at each step. This is crucial for compliance, automation planning, and stakeholder alignment—making BPMN documentation more actionable and professional.
What happens if I omit data objects in a process that handles documents?
Omitting data objects leads to ambiguity. Stakeholders may not know what information is being acted upon. This causes delays in handover, errors in automation, and audit failures. Always include data objects when data is involved.
