Anatomy of a BPMN Diagram
Geschätzte Lektüre: 7 Minuten 95 Ansichten
Most people think BPMN is about making pretty pictures. The truth? It’s about structure. The moment you abandon consistent layout and flow rules, your diagrams become confusing, even if they look correct. That’s why the first rule of BPMN isn’t “draw it neatly”—it’s “understand how it holds together.” Every BPMN diagram follows a grammar, just like a sentence. Events, activities, gateways—they’re not random shapes. They’re pieces of a system that must connect logically, unambiguously, and with purpose.
I’ve seen diagrams where the flow jumps between lanes without reason, or where gateways have no clear exit. These aren’t mistakes—they’re symptoms of a deeper issue: not understanding the BPMN model structure. Once you learn how the diagram is built from the ground up, you’ll stop guessing and start modeling with confidence.
This chapter teaches you how to read and build BPMN diagrams that work—not just look good. You’ll understand process diagram anatomy, see how BPMN components interact, and recognize what makes a model valid. By the end, you’ll be able to create diagrams that communicate clearly across teams, regardless of technical background.
Core Elements of a BPMN Diagram
BPMN diagrams are built from a small set of essential elements. They may seem simple, but their combinations form the foundation of every process map. Let’s break them down.
Events: Triggers and Outcomes
Events mark the start, end, or interruption of a process. They’re shown as circles and come in three types:
  • Start Event – Represents the beginning of a process. It can be a message, timer, or error trigger.
  • Intermediate Event – Occurs during the process. It may signal an exception, a time delay, or a message.
  • End Event – Marks the completion of the process. It can be a normal end, an error, or a cancellation.
Each event has a symbol. For example, a start event with a circle and a clock means “start on a timer,” while a circle with a bell means “start on message receipt.” These distinctions are vital—misidentifying a start event can break the entire logic.
Activities: Work to Be Done
Activities represent tasks or work items. They’re shown as rounded rectangles and are the backbone of any process.
There are three main types:
  1. Task – A single work item, like “Verify customer ID.”
  2. Sub-Process – A group of tasks that can be collapsed or expanded. Use this to manage complexity.
  3. Transaction – A special type of sub-process that can be interrupted by events.
When modeling, always ask: Is this a single action, or a sequence of steps? If it’s multiple steps, consider using a sub-process. This keeps the top-level diagram clean and readable.
Gateways: Decision Points
Gateways control the flow. They are diamond-shaped and determine how the process continues based on conditions.
Three main types:
  • Exclusive (XOR) – Only one path is taken.
  • Parallel (AND) – All outgoing paths are taken.
  • Inclusive (OR) – One or more paths can be taken.
Use XOR for choices like “Is the customer a new user?” Use AND when multiple approvals are required. OR is ideal when some conditions may apply, but not all.
Structural Layout: The Grammar of BPMN
Just like a sentence has subject, verb, and object, a BPMN diagram has a structure that must follow rules. These aren’t arbitrary—they’re designed to prevent ambiguity.
Process Flow: From Start to End
Every BPMN diagram must begin with a start event and end with an end event. Sequence flows—solid lines with arrows—connect elements in the order they occur.
Start with one element: the start event. Then add activities and gateways in logical order. Only when the flow reaches an end event is the process complete. If you see a process with no end event, or multiple start events, it’s invalid.
Swimlanes: Assigning Responsibility
Swimlanes (or lanes) divide the diagram by role, department, or participant. They’re essential when modeling interactions across teams.
Each lane contains activities assigned to a specific actor. For example, one lane might say “Customer,” another “Support Team.” This makes responsibility clear, especially in collaborative processes like order fulfillment or loan approvals.
Always label lanes clearly. A swimlane without a label is like a department without a name—useless.
Message Flow: Communication Across Diagrams
Message flows represent communication between participants in a collaboration diagram. They’re dashed lines with an open arrow.
Use message flow when a process sends a message to another process. For example, “Send order confirmation” from sales to delivery. This shows external communication, not internal flow.
Remember: use sequence flow for internal process steps. Use message flow for inter-process communication.
Key Rules for Valid BPMN Model Structure
Even with the right elements, a diagram isn’t valid without proper structure. These rules are non-negotiable.
  • One start event per process – A process can only start once.
  • At least one end event – Every process must end.
  • Sequence flows must connect – Every activity or event must be reachable from a sequence flow.
  • Gateways must have at least two outgoing flows – A gateway with only one output breaks logic.
  • No unconnected elements – Everything must be part of the flow.
These aren’t suggestions. They’re the foundation of BPMN. Break them, and your model becomes ambiguous or impossible to execute.
How to Read a BPMN Diagram: A Step-by-Step Guide
Reading a BPMN diagram isn’t about memorizing symbols—it’s about following the logic. Here’s how to approach any diagram:
  1. Identify the start event – Find the beginning. What triggers the process?
  2. Follow the sequence flow – Trace each step. What must happen next?
  3. Check gateways – At every diamond, ask: “What determines which path to take?”
  4. Locate end events – Where does the process conclude? Is it a normal end, error, or cancellation?
  5. Review swimlanes – Who is responsible for each step?
Apply this checklist to any diagram, and you’ll avoid misreading workflows. It’s the same method I use when reviewing client models—no exceptions.
BPMN Components: A Summary Table
Here’s a quick reference for the core BPMN components.
Component Visual Use Case Key Rule
Start Event Circle with symbol Begin process Only one per process
Activity Round rectangle Work to be done Can be a task or sub-process
Gateway Diamond Decision or branching Must have ≥2 outgoing flows
End Event Circle with outline End of process Must exist
Sequence Flow Black solid line Internal process flow Connects events, activities, gateways
Message Flow Dashed line with arrow Inter-process communication Used in collaboration diagrams
Can I use multiple start events in a BPMN diagram?
No. A BPMN process can only have one start event. If you need multiple entry points, model them as separate processes or use gateways with message events.
What’s the difference between sequence flow and message flow?
Sequence flow shows internal process logic—what happens next. Message flow shows communication between processes. Use sequence flow for steps within a process. Use message flow when one process sends a message to another.
How do I handle exceptions in BPMN?
Use boundary events. These are attached to activities and trigger when an error occurs. For example, a boundary event on “Process payment” can trigger if the payment fails. This is part of the BPMN standard for exception handling.
Why do my gateways look different in different tools?
Some tools use different symbols to represent the same gateway type. Always check the label or icon. For example, an XOR gateway may be a plain diamond, while an AND gateway has a “+” inside. The label should clarify the type.
Do I need to use swimlanes in every diagram?
No. Swimlanes are only needed when modeling roles or responsibilities. For simple processes, you can omit them. But if you’re modeling a cross-functional workflow, swimlanes are essential.
Can I model a loop in BPMN?
Yes. Use a loop marker on an activity. This indicates the step repeats until a condition is met. For example, “Review document” might loop until approved. Always pair it with a condition to avoid infinite loops.
