The Grammar of BPMN: Rules and Constraints
Geschätzte Lektüre: 7 Minuten 81 Ansichten
Over 80% of beginner models I’ve reviewed contain at least one structural violation—usually in sequence flow logic or event usage. These aren’t mistakes due to ignorance, but stem from one common gap: not understanding the underlying rules that govern valid BPMN diagrams.
Every diagram must follow a consistent syntax. Think of it like grammar in language: you can be creative, but only if you respect the rules. Without them, even the most detailed flow becomes ambiguous or uninterpretable.
These rules aren’t arbitrary. They exist to ensure clarity, prevent logic errors, and allow tools to validate and execute workflows. This chapter covers the core BPMN syntax, constraints, and modeling best practices you must master to create reliable process maps.
The Core of Valid BPMN: Sequence Flow Logic
Sequence flows are the spine of any BPMN diagram. They define the order in which activities execute. But not every connection counts.
Each sequence flow must start from a node and end at another node—never from a text annotation or a data object.
Here are the essential constraints for sequence flows:
  • They must connect from an outgoing flow of one element to an incoming flow of another.
  • They can only connect events, activities, or gateways—not artifacts or text annotations.
  • They must not cross other sequence flows unless explicitly allowed by the modeler (e.g., in complex diagrams).
  • Only one flow can originate from a single activity unless it’s an exclusive, parallel, or inclusive gateway.
Why This Matters in Practice
I once worked with a team that used a single sequence flow to connect two activities, then added a second flow from the same activity without a gateway. The result? A model that looked correct at a glance but failed validation in the process engine. The tool flagged it instantly—because two outgoing flows from a single activity without a gateway break BPMN syntax.
Always ask: Does every flow have a clear start and end? Does the connecting element support the number of outgoing flows?
Start and End Events: The Must-Be-Correct Pair
Every BPMN process must begin with a start event and end with an end event. This is non-negotiable.
Start events can be:
  • Message start event
  • Timer start event
  • Conditional start event
  • None start event (default)
End events can be:
  • Normal end event (circle with a border)
  • Escalation end event
  • Compensation end event
  • Termination end event
But here’s a common trap: placing multiple end events in the same path without a decision gateway. That breaks the uniqueness rule. A process can only have one valid end point unless controlled by a gateway.
BPMN Constraint: One End Event Per Path
If your model includes multiple end events, they must be reachable through different decision paths. This avoids ambiguity and ensures process execution has a clear termination point.
Use this simple checklist:
Check Must Be True
Start event present? Yes — at least one
End event present? Yes — at least one
Only one end event per path? Yes — unless separated by a gateway
Start event has no incoming flows? Yes — it’s the entry point
Event Consistency: Matching Triggers and Types
Events define what triggers or responds to a state in the process. A misused event type can make your model ambiguous or invalid.
For example: using a timer start event to represent a manual user trigger is incorrect. The timer event only fires at a scheduled time. If you need a user-initiated start, use a message start event or none start event with a user task.
Similarly, boundary events must be attached to an activity. They’re not standalone—they respond to an interrupting or non-interrupting trigger during execution.
Common Mistakes in Event Usage
  • Placing a boundary event on an activity but connecting it to another activity instead of the parent.
  • Using a message start event but not defining a corresponding message flow.
  • Applying a signal end event without a corresponding signal throw event.
These break event consistency and cause issues during process execution or validation.
BPMN Best Practices: Building for Clarity and Compliance
Following syntax rules isn’t enough. The goal is to build models that are understandable, maintainable, and error-free.
Here are five key BPMN best practices:
  1. Use gateways to control branching—never rely on multiple sequence flows from a single task without a gateway.
  2. Label every sequence flow—especially in complex models. Use clear, action-based labels like “Approve” or “Reject”.
  3. Keep swimlanes consistent—assign one role per lane, and avoid splitting a role across multiple lanes.
  4. Limit decision points—more than three outgoing flows from a single gateway can overwhelm readers.
  5. Validate early—use tools like Visual Paradigm’s built-in validator to catch syntax issues before final review.
When to Use Each Gateway Type
Gateway Type Use Case Example
XOR (Exclusive) Only one option can be true “Is the order over $1000?” → Yes/No
OR (Inclusive) One or more options can be true “Does the customer have a discount or premium account?”
AND (Parallel) All branches must execute “Send email and update CRM”
Choosing the right gateway ensures your process logic reflects reality. Misusing one can lead to incorrect execution or missed outcomes.
Final Checklist: Validating Your BPMN Model
Before finalizing any model, run through this checklist to ensure compliance with BPMN syntax and best practices:
  • ✅ Every process has exactly one start event.
  • ✅ Every process has at least one end event.
  • ✅ No two sequence flows originate from the same node without a gateway.
  • ✅ All gateways have at least two outgoing flows.
  • ✅ Events are used correctly based on their trigger type.
  • ✅ All sequence flows are labeled with clear, concise actions.
  • ✅ Swimlanes are used consistently and represent roles or departments.
  • ✅ No dangling flows or unconnected elements.
Running this checklist once during drafting and once before final review can save hours of rework.
Can I have multiple start events in a BPMN diagram?
Yes—but only if they are triggered by different conditions and are part of separate threads. For example, one start event for „Payment received“ and one for „Order placed.“ They must be in separate processes or connected via collaboration (pools).
What happens if I connect a sequence flow directly to a data object?
This violates BPMN syntax. Sequence flows must connect to events, activities, or gateways. Data objects can be referenced within an activity, but they cannot be a flow endpoint.
Is it okay to have a gateway with only one outgoing flow?
No. A gateway must have at least two outgoing flows. If you have only one path, use a simple sequence flow instead. Gateways are for decision-making, not routing.
Can I use a message flow to connect two tasks in the same lane?
Yes, but only if it represents a message between two different participants (e.g., different departments or systems). Within the same lane, use sequence flows for internal logic. Message flows should show communication between roles.
Why does my BPMN tool flag a sequence flow as invalid?
Most likely because it violates one of the rules: starting or ending on a non-connectable element, crossing another flow without a bridge, or having multiple flows from a node without a gateway. Check the validation report for the exact rule broken.
Do I need to use a gateway for every decision point?
Yes. Every decision—whether based on a condition, user input, or system check—must be represented with a gateway. The type depends on the logic: XOR for exclusive choice, AND for parallel execution, OR for inclusive conditions.
