Mixing Business Scope and Technical Scope in One DFD
Lectura estimada: 6 minutos 224 vistas
Every time I review a DFD, I see the same failure: a single diagram attempts to show both how a customer places an order and how the backend API validates it. That’s the single biggest source of confusion in real-world data modeling. It’s exhausting to explain why a process like “Validate Order” includes cloud function deployments, and why a business stakeholder can’t understand a field named “payload.” The fix isn’t more detail—it’s a simple shift: separate the business flow from the technical implementation.
This chapter shows you how to stop mixing business and technical DFD scope. You’ll learn to build two complementary views: one focused on what happens to data from the user’s perspective, and another that reveals how it moves through servers, queues, and services. The result? A clear, traceable, and stakeholder-friendly model that avoids rework and miscommunication.
Why Mixing Business and Technical Flows is a Trap
When business analysts blend high-level logic with low-level system actions, they create a “black box” that serves no one well.
Business stakeholders see technical jargon and give up. Engineers see business processes without sufficient engineering context. The diagram becomes a liability, not a tool.
I’ve seen this in healthcare systems where a “Process Patient Referral” node includes Kafka topics, retry mechanisms, and microservice endpoints. That’s not a data flow—those are deployment artifacts.
Common Symptoms of Mixed Scope
  • Processes named after technical tools: “Invoke AWS Lambda Function” or “Call Kafka Producer”
  • Data flows with technical attributes: “JSON payload (serialised, 10KB)”
  • External entities that are internal systems: “Database Layer” or “API Gateway”
  • Flow labels with deployment names: “POST /api/v1/orders”
These aren’t mistakes in logic—they’re symptoms of a deeper problem: lack of scope separation.
How to Separate Business and Technical Views
The key is to treat the business DFD and technical DFD as two views of the same system, not competing models.
Step 1: Define Your Business Scope
Build a Level 0 DFD focused on the user’s journey, not the system’s architecture.
Use real business events: “Customer submits order”, “Payment confirmed”, “Shipment dispatched”.
Keep it simple. No mention of servers, queues, or APIs. The goal is to answer: “What does the customer care about?”
Step 2: Build a Parallel Technical DFD
Create a separate Level 0 (or Level 1) DFD using the same processes but from a system perspective.
Replace “Customer submits order” with “Validate order payload via API gateway”.
Now you can show how that input moves through: authentication, validation, message queue, and persistence.
Step 3: Link with Traceability
Use a simple traceability table to show how business events map to technical processes.
Business Event Technical Process Source
Customer submits order API Gateway receives POST /orders Order Service
Payment confirmed Process payment via Stripe webhook Payment Microservice
Shipment dispatched Trigger logistics notification via RabbitMQ Shipping Service
This isn’t just documentation—it’s a living map. When requirements change, both views stay aligned.
Patterns for Clear Separation
Use these patterns to ensure your diagrams are mutually reinforcing, not redundant.
Pattern 1: Business DFD = Customer Journey
Model only what the user or business actor sees.
Examples:
  • “Customer fills out order form”
  • “Order is verified by clerk”
  • “Invoice is sent to client”
These are the flows that matter to business decisions.
Pattern 2: Technical DFD = System Behavior
Show how the system processes data—what happens inside.
Examples:
  • “Validate input schema against JSON schema”
  • “Store order in PostgreSQL with transaction lock”
  • “Publish event to message queue with retry policy”
These are the details developers need to implement.
Pattern 3: Use Shared Process IDs
Assign the same ID to related business and technical processes.
Example:
  • Business DFD: P100 — Process Order
  • Technical DFD: P100 — Validate and persist order
This allows cross-referencing without confusion.
When to Use Which DFD
Understanding when to show which view is critical.
For Business Stakeholders
Show the business DFD. It’s about outcomes, not infrastructure.
Use plain language. Avoid technical terms. Focus on who does what and what data moves.
For Developers and DevOps
Show the technical DFD. It’s about execution, scalability, and integration.
Include relevant systems, protocols, and error handling.
For Joint Reviews
Use both diagrams side by side. The goal is alignment, not duplication.
Ask: “Does the technical process actually support the business goal?”
Real-World Example: Order Processing
Let’s say a retail system processes orders.
Business DFD (Level 0)
  • External Entity: Customer
  • Process: Submit order
  • Process: Confirm order status
  • Process: Dispatch shipment
  • Data Store: Order records
Simple, focused, accessible.
Technical DFD (Level 1)
  • External Entity: API Gateway (external)
  • Process: Validate request (JWT, schema)
  • Process: Store order in database (with lock)
  • Process: Publish “order_created” event to Kafka
  • Data Store: Orders (PostgreSQL)
  • Data Store: Events (Kafka topic)
Technical but coherent.
Now, when a stakeholder asks, “Why did the order fail?” you can say: “The business process was completed. But at the technical level, the database lock failed due to contention.” That answer only works because the scopes are separated.
  • Mistake: Using technical names in business diagrams. Solution: Replace “API Gateway” with “Receive order request”.
  • Mistake: Hiding technical complexity too early. Solution: Show technical DFDs in design reviews, not in stakeholder presentations.
  • Mistake: Forgetting to link the two views. Solution: Always include a traceability matrix or cross-reference list.
Can I use the same DFD for both business and technical teams?
No. A single diagram that tries to serve both audiences becomes too cluttered and ambiguous. The business team will miss technical details, and engineers will feel overwhelmed by abstract terms. Use separate views with clear traceability.
Is it acceptable to have technical details in a high-level DFD?
Only if they are essential to business logic. For example, “Encrypt PII before storage” may be a business rule. But “Use AWS S3 bucket ‘orders-backup’” is technical detail. Keep only rules that affect data handling, not infrastructure.
How do I convince stakeholders to accept two DFDs instead of one?
Show them the cost of confusion: miscommunication, rework, and delays. A clear business DFD improves decision-making. A precise technical DFD reduces bugs. Two views are better than one ambiguous diagram.
What if the business doesn’t understand technical DFDs?
That’s fine. The technical DFD isn’t for them. It’s for the team building the system. The business DFD is the shared language. Use the technical DFD only in engineering design sessions or code reviews.
How can I ensure consistency between business and technical DFDs?
Use shared process IDs, a common data dictionary, and a traceability matrix. Review both diagrams together during design walkthroughs. Use modeling tools that support linking views.
Should I ever mix business and technical flows in a single diagram?
Only in rare cases—like a technical architecture overview where the audience needs both perspectives. Even then, use visual separation: color coding, legend, or split layouts. Never blend them as if they’re the same level.
Scroll al inicio
