Leveling and Decomposition Errors
Lectura estimada: 3 minutos 74 vistas
Have you ever stared at a DFD where the child diagrams don’t quite match their parent, or where a single process seems to do everything while another is broken into ten tiny steps? These are classic signs of flawed DFD decomposition—mistakes that erode clarity, trip up reviews, and make it impossible to trust the model as a reliable blueprint.
This section is here to help you recognize and correct these issues with precision. I’ve spent years reviewing DFDs from real-world systems, and I’ve seen how inconsistent hierarchy, poor numbering, and uneven detail depth can derail even the most promising designs. The good news? These problems are fixable with the right approach.
By the end of this section, you’ll understand how to build DFDs that evolve logically from Level 0 to deeper levels, avoid the extremes of over- and under-decomposition, and maintain a clean, consistent hierarchy. You’ll learn not just what to fix, but how to prevent these errors from arising in the first place.
What This Section Covers
Each chapter tackles a specific problem in DFD decomposition, with practical examples and clear guidelines to help you rebuild your diagrams with confidence.
  • No Logical Progression Between DFD Levels: Learn how to ensure every process in a parent diagram has a proper, meaningful child diagram—no orphaned or unrelated processes.
  • Over-Decomposition: When Every Step Becomes a Process: Discover how to spot overly detailed diagrams and apply criteria to group minor actions into cohesive processes.
  • Under-Decomposition: Monolithic Processes That Hide Risk: Break down large, ambiguous processes into manageable, testable components that reveal hidden flows and responsibilities.
  • Incorrect Process Numbering and Broken Hierarchies: Adopt consistent numbering schemes that reflect hierarchy and make navigation intuitive—no more guessing which process is which.
  • Too Many Processes on One Diagram Without Decomposition: Learn when to split a diagram and how to do it effectively, using practical heuristics for better readability and reviewability.
  • Inconsistent Decomposition Depth Across the Model: Understand why uneven detail levels create blind spots and how to balance depth based on risk and stakeholder needs.
By the End, You Should Be Able To…
  • Identify DFD leveling errors and ensure alignment between parent and child diagrams.
  • Recognize when a process is over-decomposed and refactor it for better clarity and maintainability.
  • Break down monolithic DFD processes to expose hidden data flows and improve communication.
  • Apply consistent numbering conventions to maintain a clear DFD hierarchy.
  • Decide when a DFD diagram is too crowded and split it effectively using sound decomposition principles.
  • Balance decomposition depth across the model to avoid confusion and missed detail.
These aren’t just theory—they’re lessons from real projects where poor decomposition led to misunderstandings, scope creep, and rework. I’ll guide you through each one with practical examples, so you can build diagrams that don’t just look right, but actually work.
Tools like Visual Paradigm can help enforce consistent numbering and structure, but even on paper, these principles hold. Let’s build better DFDs—together.
