Retention Journey: Renewals, Upgrades, and Churn Risk
Temps estimé :7 minutes 229 vues
Retention isn’t just about reacting to cancellations—it’s about anticipating them. A well-modeled retention journey BPMN gives you visibility into when a customer is at risk, what triggers intervention, and how to route each outcome—renewal, upgrade, or churn—through a structured, measurable flow.
When I started modeling retention workflows, I quickly realized most teams were treating renewals as a simple “send email, wait for reply” loop. But customer behavior is far more nuanced. A real retention journey BPMN captures not just actions, but conditions: usage patterns, inactivity duration, support ticket volume, and even sentiment in feedback.
Here, you’ll learn how to translate those signals into a BPMN model that reflects the full lifecycle—from monitoring churn risk to triggering personalized outreach—and then capturing the outcome with precision.
Designing the Proactive Retention Journey
Most renewal processes are reactive. Customers get a reminder at the last minute. But the most effective retention journey BPMN begins long before the renewal date.
Start by identifying the trigger events that signal a customer’s attention—or disengagement. These could be:
  • Service usage dropping below a threshold
  • No login in 45 days
  • Multiple failed support interactions
  • Positive feedback followed by silence
These aren’t just data points—they’re signals embedded in the process flow. In BPMN, use message events or timer events to represent these triggers, linked to a decision gateway that determines the response.
Modeling the Three Key Paths
A retention journey BPMN must capture three distinct outcomes. The structure should reflect this from the start:
  1. Renewal – The customer renews without friction.
  2. Upgrade – The customer is offered a better plan.
  3. Churn Risk – The customer shows signs of leaving, requiring intervention.
Use a data-based gateway after your monitoring phase. For example:
Customer Usage < 30% of plan? → Yes → Churn Risk Path
         → No → Evaluate Upgrade Potential
Each branch leads to a different set of activities—some automated, some requiring human touch.
Key BPMN Elements for Retention
Here’s how to use BPMN constructs to model retention with precision and clarity.
Timer Events to Automate Timing
Renewal reminders aren’t just “send email.” They must occur at the right time. Use timer events to schedule actions:
  • Timer: 30 days before renewal → Send renewal reminder
  • Timer: 7 days before renewal → Send final notice
  • Timer: 1 day after renewal → Send confirmation + welcome pack
This ensures your timing is predictable and repeatable—no more missed emails or last-minute panic.
Message Events for External Data Triggers
Retention isn’t isolated. It integrates with CRM, support systems, and product analytics. Use message events to import signals:
  • Message from CRM: “Customer has 3+ support tickets in 30 days”
  • Message from analytics: “User engagement dropped by 60%”
  • Message from feedback tool: “Negative sentiment detected in NPS survey”
These messages can trigger a subprocess labeled “Churn Risk Assessment” or “Retention Outreach.”
Boundary Events for Exception Handling
What if the renewal email fails? What if the customer clicks but doesn’t complete the form?
Use boundary events on send tasks to model failures:
  • Boundary event: “Email failed to send” → Retry or escalate to agent
  • Boundary event: “User abandoned form” → Trigger re-engagement email
This keeps your main flow clean while capturing where things go wrong.
Mapping the Three Pathways
Each outcome—renewal, upgrade, churn—should follow its own logical path. Here’s how to structure them in your BPMN diagram.
Path 1: Renewal (Automatic)
When usage is stable and no churn signals are detected, the system can auto-renew. This path includes:
  • Payment processing (automated)
  • Confirmation email (send)
  • Update CRM status to “Renewed”
  • Close retention case
Use a default flow for this path. It requires no decision—just execution.
Path 2: Upgrade (Opportunity)
When usage is high, but license isn’t maxed, that’s a chance for an upgrade. This path includes:
  • Trigger: “Usage > 80% of current plan”
  • Send tailored upgrade offer (email or in-app)
  • Wait 48 hours for response
  • If accepted → Process upgrade
  • If ignored → Escalate to sales rep
Use a parallel gateway to handle both the offer and the follow-up.
Path 3: Churn Risk (Intervention)
This is where empathy and strategy meet. When signals suggest churn, the journey shifts to intervention:
  • Trigger: “No login in 45 days + 2 support complaints”
  • Send personalized email: “We miss you”
  • Wait 72 hours
  • If no response → Call agent
  • If response → Schedule call + offer retention incentive
  • After call: Update case status and re-evaluate
Use a subprocess to model the retention call flow—keeping the main diagram clean.
Best Practices for Retention Journey BPMN
Modeling retention isn’t just about creating a flow. It’s about building a system that learns, adapts, and improves over time.
Use a Standardized Workflow Pattern
Adopt a consistent structure across all retention journeys. Define a reusable template with:
  • A monitoring phase (timer/events)
  • A decision point (data gateway)
  • Three outcome branches
  • Clear ownership (lanes for CRM, Sales, Support)
Reusing this pattern reduces cognitive load and improves stakeholder alignment.
Link to KPIs and Metrics
Every activity should connect to a metric. For example:
Activity Target KPI Measurement Method
Send renewal email Open rate ≥ 70% Email tracking
Send upgrade offer Conversion rate ≥ 15% Click & purchase tracking
Intervention call Retention rate ≥ 60% Post-call status in CRM
Attach these to your model using annotations or metadata fields. This turns BPMN into a performance dashboard.
Keep the Customer in the Lane
Always place the customer in their own lane or pool. It’s tempting to merge them with the “Support” or “Sales” lane, but that obscures ownership and experience.
Use a customer pool with lanes for “Customer View,” “CRM System,” “Sales Agent,” and “Finance.” This makes it clear who sees what—and when.
Even with solid design, retention journey BPMN can go off track. Here are the most frequent missteps and fixes.
  • Pitfall: Using a single “send email” task for all outreach.
  • Solution: Split into “Send Reminder,” “Send Upgrade Offer,” and “Send Churn Intervention.” Each has different triggers, content, and outcomes.
  • Pitfall: Ignoring the “no response” state.
  • Solution: Use timers to define wait periods. After 72 hours, escalate to a human.
  • Pitfall: Failing to track the outcome.
  • Solution: Every decision point must have a clear “return to customer” state: “Renewed,” “Upgraded,” “Churned,” “Intervention Pending.”
What is the best way to model renewal process BPMN?
Use a time-triggered flow: a timer event 30 days before renewal starts the process. Then use a data-based gateway to check usage and engagement. If no churn signals, proceed to auto-renew. Otherwise, trigger a retention outreach flow.
How do I model churn prevention journey with BPMN?
Start with a monitoring phase using timer events and message events. Link those to a decision gateway that evaluates risk signals (inactivity, support volume, sentiment). Branch to “Intervention,” “Renewal,” or “Upgrade” based on data. Use boundary events to handle failures.
Can upgrade and cross sell BPMN be part of the same flow?
Absolutely. After detecting high usage, use a gateway to determine if the customer is a candidate for an upgrade or cross-sell. Use parallel paths: one for upgrade offer, another for cross-sell product. Both lead to a single outcome: “Offer Sent.”
How do I handle multiple customer touchpoints in retention journey BPMN?
Use separate lanes for each channel: “Web,” “Mobile App,” “Email,” “Call Center.” Map interactions to their respective lanes. Use message flows to show handoffs between channels and the customer.
Should I use a subprocess for retention interventions?
Yes. A subprocess like “Retention Outreach” keeps your main flow clean. Define the steps—email, wait, call, offer—inside the subprocess. This allows reuse across different customer segments.
How do I prove the impact of my retention journey BPMN?
Link each activity to a KPI—e.g., email open rate, conversion rate, retention rate. Use the BPMN model to trace how process changes affect outcomes. Run simulations or track actual performance over time to validate improvements.
Retour en haut
