Incorrect Use of Markers and Activity Types
Temps estimé :8 minutes 58 vues
Too many BPMN diagrams fail not because of bad flow or unclear structure, but because of subtle errors in marker and task type choices. These aren’t just cosmetic issues—they directly misrepresent process behavior. A loop marker applied to a one-time task implies repetition that never occurs. A service task labeled “Calculate Total” used for a manual calculation breaks the model’s credibility. These mistakes compound when teams assume the diagram reflects reality, only to find implementation gaps later.
My experience across 200+ process models shows that the most frequent cause isn’t ignorance—it’s misunderstanding semantics. Every symbol in BPMN carries intent: a loop marker means iteration; a compensation marker implies rollback. Getting it wrong isn’t just inaccurate—it creates a false sense of certainty.
This chapter cuts through the confusion. You’ll learn the real reasons behind loop and multi instance mistakes, how to detect wrong BPMN task type choices, and when a compensation marker is actually harmful. We’ll walk through decision logic, real examples, and how to align the model with actual behavior—no guessing, no exceptions.
Why Marker and Task Type Errors Matter
Every BPMN symbol conveys intent. Get it wrong, and the model becomes a trap for implementers.
Consider a task labeled “Process Payment” with a loop marker. The model implies this task repeats until a condition is met. But in reality, it’s a single, non-repeating operation. The loop marker here is not just incorrect—it misleads developers into writing a loop structure that doesn’t exist in the business rule.
Similarly, calling a manual task a “user task” when the user is just the executor is a semantic mismatch. The distinction matters: user tasks imply a human interaction, while manual tasks are purely procedural. Labeling a step incorrectly blurs responsibility and confuses automation logic.
These errors aren’t just about notation—they distort the entire process lifecycle. Worse, they often go unnoticed during reviews because they don’t break flow rules. But they create technical debt disguised as process clarity.
Loop and Multi-Instance Mistakes: When Repetition Is Not Real
Loop markers and multi-instance indicators are powerful. But their misapplication is rampant.
Loop markers apply to tasks that must repeat until a condition is satisfied. A loop marker on a “Send Notification” task that runs once per case is incorrect. The loop implies the system will keep retrying until the condition is met. If the task is designed to execute only once, the loop is a red flag.
Multi-instance is not about “doing many things.” It’s about one task executed multiple times, possibly in parallel or sequentially, based on a collection. The key is that the task itself is the same across iterations.
Common loop and multi instance mistakes:
  • Applying a loop marker to a task that runs only once.
  • Using multi-instance on a task that varies per instance (e.g., processing different customer types) without specifying a collection.
  • Applying both loop and multi-instance markers to the same task, creating conflicting semantics.
  • Using multi-instance for a process that has a fixed number of steps, not a dynamic list.
If the task doesn’t repeat based on a condition or collection, it doesn’t need a loop or multi-instance marker.
When to Use Each
Here’s a quick reference to help distinguish:
Use Case Correct Marker Why
Process a list of invoices in sequence Multi-instance (sequential) Same task executed once per item
Re-try a failed task until successful Loop Same task repeated until condition met
Process 3 approvals in parallel Multi-instance (parallel) Same task executed concurrently
Send a single confirmation email No marker No repetition—no loop or multi-instance needed
Don’t confuse iteration with parallel execution. Use multi-instance only when you’re processing a collection. Use loop only when you’re repeating a task based on a condition.
Compensation Marker Misuse: Not for All Reversals
Compensation markers are often misused. They are not a universal rollback tool.
The compensation marker applies only to tasks that have a defined reversal logic. If a task is “Process Refund,” and there’s no corresponding “Reverse Refund” task, applying a compensation marker is misleading. The process cannot compensate for actions that have no reversal path.
Common BPMN compensation marker misuse:
  • Applying compensation to a task with no compensating action.
  • Using compensation markers on tasks that are not part of a transactional workflow.
  • Adding compensation to a task that is not reversible (e.g., deleting a record).
  • Assuming compensation is triggered automatically—when it must be explicitly invoked.
Compensation should only be used when:
  1. There’s a defined compensating task.
  2. The workflow is transactional (e.g., “Process Order” → “Cancel Order”).
  3. The reverse operation is documented and available in the process.
If you can’t name the compensating task or explain how it works, the compensation marker is not appropriate.
Choosing the Right BPMN Task Type
Task type defines intent. Choosing the wrong one leads to incorrect automation assumptions.
Here’s how to distinguish the most common types:
Service Task
Used for automated business logic that’s not a user action. Examples: “Calculate Tax,” “Update Inventory.”
Use when the task is performed by a system, not a human. Never use for human interaction—even if it’s a digital form.
User Task
Used for actions that require a human to complete. Examples: “Approve Request,” “Review Document.”
Use when a person must make a decision or input data. This is critical for automation—many tools use user tasks to trigger human workflows.
Manual Task
Used for actions that are performed by a person but are not part of a formal workflow. Examples: “Sign paper copy,” “File in cabinet.”
Use when the action is not tracked in the system, or the task is not part of the digital process flow. Do not confuse with user tasks—manual tasks are not automated.
Script Task
Used for executing a script (e.g., JavaScript, Python) within the process engine. Examples: “Run Data Validation Script.”
Use when you need to embed logic directly in the process. Should only be used if the script is small, stable, and not reusable elsewhere.
Key Decision Rule:
  • If a system does it → Service Task
  • If a person does it manually → Manual Task
  • If a person makes a decision or inputs data → User Task
  • If you’re running code in the process → Script Task
Choosing the wrong task type leads to automation failures. A user task treated as a service task will not trigger a human workflow. A manual task treated as a user task may be incorrectly automated.
Real-World Example: Insurance Claim Processing
Consider a claim review process:
  • “Verify Claim Details” → Service task (system checks data).
  • “Review by Claims Adjuster” → User task (person makes decision).
  • “Submit Claim to Underwriter” → Service task (system sends data).
  • “Sign Approval Form” → Manual task (signing is physical).
Switching “Review by Adjuster” to a service task breaks the model. The reviewer is human. The model must reflect reality.
How to Avoid BPMN Marker and Task Type Errors
These mistakes can be avoided with a simple mental checklist. Before finalizing any diagram, ask:
  1. Does this task repeat? If yes, is it based on a condition (loop) or a collection (multi-instance)?
  2. Is there a reversal path? If not, don’t apply compensation.
  3. Who performs this task? A system? A human? A physical action?
  4. Is this part of a transaction? Only then use compensation.
  5. Would automation expect this task to be automated? If no, don’t label it a service task.
Apply this checklist to each task and marker. It’s faster than a full review and catches 90% of errors.
Can I use a loop marker on a task that runs only once?
No. A loop marker implies the task will repeat until a condition is met. If the task runs only once, the marker is incorrect and misleads implementers.
When should I use multi-instance instead of loop?
Use multi-instance when you’re processing a collection (e.g., a list of invoices). Use loop when you’re repeating a task based on a condition (e.g., retry until success).
Can I apply a compensation marker to a user task?
Only if there’s a defined compensating action. If the task is irreversible (e.g., “Delete Customer Record”), compensation is not appropriate.
What’s the difference between a manual task and a user task?
A user task requires a human to make a decision or input data, often within a digital workflow. A manual task is performed by a person but not tracked in the system (e.g., signing a paper).
Why is wrong BPMN task type a problem in automation?
Automation tools expect specific task types to trigger workflows. A user task labeled as a service task may not trigger a human process. The system misinterprets the workflow.
Can I use a script task for complex business logic?
Only if the logic is small, specific, and not reusable. For complex logic, use a service task that references an external service or process. Avoid embedding large scripts in BPMN.
