A Consolidated Checklist: Avoiding Common BPMN Mistakes
Temps estimé :7 minutes 54 vues
Most of us write BPMN diagrams under pressure, with little time to pause and reflect. The result? A model that looks correct at a glance but hides structural flaws, ambiguous logic, or communication gaps. You might not notice them until implementation fails, or stakeholders walk away confused.
The truth is, a flawed BPMN diagram is worse than no diagram at all—especially when it misleads developers, distracts business users, or gets reused as a template for future processes. This checklist is the final sanity check before any model goes live.
It’s based on over 20 years of fieldwork, peer reviews, and audit findings. Every item here has been tested in real-world environments—from insurance underwriting to fintech onboarding. No theory. No fluff. Just practical, repeatable quality gates you can apply instantly.
Notation & Semantics: Are the Symbols Correct?
Start and End Events
Ensure every process has exactly one start event. Use none start events only for subprocesses or event-driven processes.
End events must be present and unambiguous. Never use a plain end event for cancellation or error conditions—use terminate or error end events instead.
Use message start events only when the process is triggered by an incoming message. For time-based triggers, use timer start events.
Gateways: Correct Type, Correct Logic
Use XOR (exclusive) gateways when only one path should be taken. Confirm the condition labels are mutually exclusive and exhaustive.
Use AND (parallel) gateways only for simultaneous branches. If you’re splitting a decision into two parallel actions, this is correct. If not, reconsider.
Use OR (inclusive) gateways with caution. Only if more than one path might be taken simultaneously—and you’ve documented the logic clearly.
Never leave gateways unpaired. Every split must have a corresponding join. Unpaired gateways create undefined behavior.
Sequence Flows vs. Message Flows
Use sequence flows to show control flow within a single pool or process.
Use message flows to show communication between pools or participants. Message flows are not for internal control flow.
Never use sequence flows between pools. It’s a violation of BPMN semantics and confuses the reader.
Task Types and Markers
Use user tasks when a person performs the work. Use service tasks for system-to-system interactions.
Use sub-processes only when grouping multiple activities into a logical block. Avoid using them as a container for a few simple steps.
Use loop markers only when an activity repeats exactly. If it repeats conditionally, use a loop with a condition, not a loop marker.
Use multi-instance only when the same activity is performed multiple times, possibly in parallel. Never use it as a catch-all for loops.
Structure & Flow: Is the Logic Sound?
Complete Flow Path
Every activity must lead to another activity or an end event. No orphaned tasks or dead ends.
Every path from start to end must be valid. Use a simple “walkthrough” from start to end: can you trace the logic without detours or loops?
Check for infinite loops. If a gateway sends flow back to a previous task without a clear exit condition, it’s dangerous.
Clear Process Scope
Define clear preconditions at the start and postconditions at the end.
Ask: What triggers this process? What data is required? What is produced? If these aren’t clear, the scope is ambiguous.
Do not mix multiple scenarios in one model. If you’re modeling both “standard” and “urgent” cases, split them into separate diagrams or use a sub-process with a condition.
Responsibility Clarity
Every task must have a clear owner. Check that every lane has at least one task assigned.
If multiple lanes are involved, ensure message flows align with handoffs. A message flow should start from a task that produces the message and end at a task that consumes it.
Use separate pools for customers, partners, and internal departments. Never assume shared ownership.
Naming & Communication: Are You Speaking the Same Language?
Activity and Event Names
Use verb–object format: “Review Application,” “Send Confirmation Email,” “Approve Invoice.”
Avoid vague labels like “Process,” “Do Task,” “Handle Request.” These add no value.
Use consistent naming across related diagrams. If “Submit Application” appears in one, don’t switch to “Send Form” in another.
Gateway Conditions
Conditions on gateways must be clear, testable, and business-acceptable.
Avoid complex logic like “if the application status is not rejected and the user is not a minor and the income is greater than 50K.”
Instead, label the condition: “Eligible for Standard Approval.” Then document the rule in an external decision table or in annotations.
Annotations and Context
Every complex decision, exception path, or business rule must have a short annotation explaining the intent.
Use the annotation to reference documentation, policies, or external rules—don’t embed the full rule in the diagram.
Don’t rely on color, size, or font style. Use annotations to explain edge cases that aren’t obvious from the flow.
Layout & Readability: Is It Easy to Follow?
Flow Direction and Consistency
Choose a single direction—either left-to-right or top-to-bottom—and stick to it.
Never mix directions in the same diagram. It creates visual noise and confuses interpretation.
Use consistent spacing. Elements should be evenly spaced, not crammed or floating.
Minimize Crossing Flows
Redraw paths to avoid criss-crossing flows. Use “push” or “pull” techniques: move tasks to create clean lanes.
If flows cross more than three times, consider splitting the diagram or using a sub-process.
Visual Hierarchy
Use sub-processes to group related steps. Collapse them when the detail isn’t needed.
Use color or font style only to emphasize purpose—never to hide mistakes.
Keep the visual center of the diagram uncluttered. Avoid placing critical logic in the middle of a web of lines.
Tool & Team Practices: Are You Using the Right Checks?
Validation Before Review
Always run the tool’s validation engine before sharing. Fix all warnings and errors.
Common issues: missing end events, unpaired gateways, invalid event types, dangling flows.
Don’t assume the tool catches everything. Use it as a starting point, not a guarantee.
Reuse and Versioning
Use a shared library of reusable tasks, subprocesses, and templates. Avoid copying and pasting.
When reusing a process, verify it still applies. Old models may be outdated or incompatible.
Use versioning: v1.0, v1.1, v2.0. Avoid “Final,” “Updated,” or “Final Final” labels.
Team Standards and Checklists
Adopt a simple lightweight BPMN standard for your team:
  • Start events: only one per process, always none or message
  • End events: must be terminate, error, or compensation if applicable
  • Gateways: use XOR for decisions, AND for parallelism
  • Tasks: user, service, manual, script
  • Naming: verb–object, consistent across models
Review this checklist before any diagram goes to peer review or stakeholder walkthrough.
Why do I need a BPMN quick review checklist if I use a modeling tool?
Tools catch technical errors—like missing end events or invalid gateways—but they can’t judge business logic, clarity, or stakeholder alignment. A checklist ensures you’re not just compliant, but actually understandable.
How often should I run this BPMN quality control list?
Run it once per diagram, before sharing with others. If your team is mature, apply it during peer review. For high-risk processes, run it again after stakeholder feedback.
Can I use this checklist for any BPMN diagram, even in complex systems?
Yes. Whether modeling a customer onboarding flow or a multi-organizational collaboration, the principles of clarity, correctness, and consistency apply. The checklist adapts to context.
What if my team doesn’t agree on naming or layout?
Start small. Pick one rule—like “use verb–object for tasks”—and enforce it. Build consensus incrementally. A checklist makes the rules visible and repeatable.
Do I need to follow every item in the checklist?
Yes—unless you have a documented reason to deviate. If a business rule is too complex to fit on a gateway, document it externally. Don’t skip the rule just because it’s hard.
Is it okay to reuse a diagram from another project?
Only after auditing it with this checklist. Reused diagrams often carry over hidden errors. Always validate, even when copying.
