Processes That Transform Data Without Clear Inputs or Outputs
Temps estimé :7 minutes 63 vues
A process that doesn’t show what it takes in and what it gives out is a black hole in your data flow.
When a process transforms data but hides its inputs and outputs, you’re not modeling a system—you’re hiding one.
I’ve seen teams spend weeks building software based on a DFD where a key process said only “Process Payment.” No input? No output? That’s not a process. It’s a placeholder.
These ambiguous interfaces sabotage testing, confuse developers, and lead to rework. But they’re avoidable.
Here’s how to define real contracts for every process—so your DFD becomes a reliable blueprint, not a guessing game.
Why Black Box Processes Break Systems
When a process lacks clear inputs or outputs, no one can validate it.
Imagine a process labeled “Calculate Risk Score.” Does it take a customer profile? A transaction history? A credit bureau report? And what does it return? A number? A flag? A report?
If these aren’t defined, the next team to implement it must guess. And guessing leads to errors.
More critically, you can’t test a process that doesn’t have a known input-output contract.
Even if the logic is correct, you can’t verify it without knowing what should go in and what should come out.
Real-World Consequences
  • Testers can’t write meaningful test cases without a clear expectation of input and output.
  • Developers waste time clarifying vague requirements.
  • Integration fails because data shapes don’t match between connected processes.
  • Stakeholders lose trust when the model doesn’t match reality.
How to Define a Real DFD Process Contract
Every process should have a visible, unambiguous interface. This is your contract with the system.
Use this three-part framework to define every process:
  1. Input List: What data must be present before the process can run?
  2. Output List: What data does the process produce after transformation?
  3. Transformation Description: A concise explanation of how inputs become outputs.
When you apply this, the process stops being a black box.
It becomes a testable, implementable, and reviewable unit of logic.
Example: Before and After
Before (Unclear):
Process: « Validate Customer »
Input: [none shown]
Output: [none shown]
This is a red flag. No input? No output? Impossible to validate.
After (Clear Contract):
Process: « Validate Customer Identity »
Inputs:
  • Customer Profile (Name, DOB, SSN)
  • Government ID Scan (PDF or image)
Outputs:
  • Validated ID Result (Boolean: true/false)
  • Validation Log (timestamp, mismatched fields)
Transformation: Cross-references name, DOB, and SSN from the profile against the ID document. Flags discrepancies and returns a pass/fail result.
Now the process is testable, traceable, and implementable.
Patterns for Clear Process Interfaces
1. Use Active Verbs and Specific Objects
Replace vague names like “Handle Data” or “Process Info” with precise language.
Instead of:
  • “Process Data”
  • “Handle Input”
Use:
  • “Validate Credit Application”
  • “Generate Monthly Statement”
  • “Calculate Risk Score from Transaction History”
Stronger names reflect the data involved and the action taken.
2. Embed the Interface in the Diagram
Don’t hide inputs and outputs in footnotes or side notes.
Display them directly next to the process, using a simple list or a small box:
│ 3. Validate Customer ID       │
│ Inputs:                      │
│ - Customer Profile           │
│ - Government ID Scan         │
│ Outputs:                     │
│ - Validated ID Result       │
│ - Validation Log            │
Most modeling tools support this via comments or embedded annotations. Use them.
3. Apply the “Input-Output Self-Consistency” Rule
Every data flow into a process must be accounted for in its inputs.
Every data flow out must be explainable by its outputs.
If a flow appears to come from nowhere—or vanishes into nothing—your process contract is incomplete.
4. Check for Missing Process Inputs Outputs
Use this checklist every time you review a process:
  • Does the process have at least one input?
  • Does it produce at least one output?
  • Are the inputs and outputs clearly named and consistent with other diagrams?
  • Does the transformation description explain how inputs become outputs, without referencing external logic?
  • Can you write a test case based on this contract?
If any answer is “no,” the process is a black box.
When to Refactor a Black Box Process
Not all processes need to be fully detailed upfront. But if a process is a bottleneck, a high-risk area, or the subject of frequent questions, make it explicit.
Ideally, refactor these in stages:
  1. Identify processes with no visible input or output.
  2. Ask stakeholders: “What data do you expect to enter this step?” and “What comes out?”
  3. Document the contract.
  4. Update the DFD with clear labels.
  5. Verify with peers: Does it still make sense? Is it testable?
Small improvements compound. Fix one black box, and you reduce ambiguity across the entire system.
Table: Black Box vs. Clear Process Contracts
Feature Black Box Process DFD Clear Process Contract
Name “Process Data” “Validate Customer Identity”
Input Not listed Customer Profile, ID Scan
Output Not listed Validation Result, Log
Transformation None Cross-checks profile vs. ID
Testable? No Yes
This table isn’t just for comparison—it’s a diagnostic tool. Run it on your own DFDs.
What if a process has no inputs but still produces output?
If a process generates data without input—that’s a red flag. It implies data appears from nowhere.
Check: Is the output derived from a data store? If so, update the process to show input from the store.
Even if the data is generated (e.g., timestamp), the source should be explicit: “Generate Timestamp”.
Can a process have multiple outputs but only one input?
Yes. That’s normal. A process can take one input and produce multiple results (e.g., validation pass/fail, log, status).
Just ensure every output is explained in the transformation description.
Don’t leave outputs unexplained—each must follow logically from inputs.
How do I handle processes that depend on external systems?
External systems are not inputs or outputs. They are sources or sinks.
Instead, the process should show input from an external entity (e.g., “Receive Customer Data from Bank API”) and output to another system (e.g., “Send Validation Result to Compliance System”).
Make sure the data flows are clearly labeled and traceable.
Is it okay to have a process that only outputs?
Only if it’s generating data from a known source—like a data store or a timer event.
Example: “Generate Daily Report” — input: none (but generates from data store), output: report file.
Even then, the source of the data must be documented. Never assume.
How do I define inputs/outputs for a process with no clear data?
Revisit the process. If there’s no data involved, it’s not a data transformation process. It might be a control action or a system event.
Reclassify it as a control flow or event (e.g., “Trigger Audit Log”) and use a different notation—like BPMN or an event-driven model.
DFD is for data movement. If there’s no data, DFD may not be the right tool.
What if the transformation is too complex to describe in one sentence?
That’s okay. Use a bullet list or a simple algorithm outline.
Example:
Transformation:
  • 1. Extract DOB and SSN from the profile.
  • 2. Extract text from ID scan using OCR.
  • 3. Compare extracted data with profile.
  • 4. Flag mismatches.
  • 5. Return pass/fail and log of issues.
Break down complex logic. The goal is clarity, not brevity.
