Avoiding Common Fishbone Diagram Mistakes
Temps estimé :7 minutes 49 vues
One rule I’ve learned over 20 years of guiding teams through root cause analysis: a fishbone diagram isn’t a checklist—it’s a thinking tool. If your team rushes through it, you’re not solving problems—you’re reinforcing habits that mask deeper issues.
Common errors in fishbone analysis often start before the first line is drawn. A vague problem statement, rigid categories, or premature judgment can derail even the most well-intentioned sessions. These aren’t just minor oversights—they’re traps that prevent true understanding.
Here, you’ll learn how to spot and correct these fishbone diagram mistakes with actionable techniques. You’ll walk away with a sharper eye for validation, a clearer process for facilitation, and the confidence to challenge assumptions. This isn’t about perfection—it’s about consistency, clarity, and progress.
Identifying the Root Cause of Poor Analysis
Too often, teams treat the fishbone diagram as a fill-in-the-blank exercise. The problem isn’t the tool—it’s how it’s used.
When the problem is poorly defined, every cause becomes a symptom of something else. This leads to circular reasoning, where the team bounces between causes and effects without ever landing on a true driver.
Let me be clear: a fishbone diagram is only as strong as its foundation—the problem statement. If it’s vague, like “Our customers are unhappy,” the analysis will drift into irrelevance. Instead, a measurable and specific statement like “Customer service response time exceeds 48 hours in 35% of cases” sets a clear target.
That’s why the first rule of fishbone analysis is: Define the problem before you draw the spine.
Why Problem Statements Fail
Several red flags signal a weak problem statement:
  • It uses emotional language (e.g., “The system is terrible”)
  • It’s too broad (e.g., “We have quality issues”)
  • It blames individuals or departments (“John didn’t update the file”)
  • It’s not measurable (e.g., “Customer satisfaction is low”)
These aren’t just poor phrasing—they’re symptoms of deeper thinking flaws. The team hasn’t yet separated the symptom from the systemic cause.
My advice? Never start a session until the problem statement is specific, measurable, and agreed upon by all participants. If you can’t agree on the problem, you can’t solve it.
Overcoming Misuse of Categories
One of the most frequent fishbone diagram mistakes is relying on standard categories—people, process, equipment, environment, methods—without adapting them to the context.
For example, in software development, “people” might mean developers, testers, or product owners, but if the issue is about deployment delays, “people” becomes too abstract. Instead, break it down: “deployment team communication,” “lack of CI/CD pipeline visibility,” or “unclear handoff protocols.”
These are actionable, diagnosable, and measurable—exactly what a root cause analysis needs.
Customizing Categories for Your Context
Here’s a simple framework for adapting categories based on industry:
Industry Relevant Categories
Manufacturing Materials, Machine calibration, Operator training, Maintenance schedule
IT & Software Code quality, Testing coverage, Deployment automation, Incident response time
Healthcare Patient intake process, EHR system usability, Staff rotation, Shift handover
Service Industry Customer onboarding, Wait time, Team workload, Feedback collection
Using generic categories without tailoring them is a shortcut that leads to shallow analysis. The goal isn’t to fit the problem into a box—it’s to let the problem shape the box.
Avoiding Premature Judgment and Bias
Another common error in fishbone analysis is jumping to conclusions too soon. I’ve seen teams spend 30 minutes on a brainstorming session, only to spend the next 10 deciding which cause is “most likely.” That’s not analysis—that’s assumption.
At this stage, you’re not looking for “the” root cause. You’re generating possibilities. Premature evaluation kills creativity and steers the group toward familiar, but often incorrect, explanations.
Here’s what I do in my sessions: after brainstorming, I ask, “What evidence would prove this cause is real?” That simple question shifts focus from belief to data.
How to Challenge Assumptions
Use this checklist to test each potential cause:
  1. Is it measurable? Can you track it over time?
  2. Is it specific? Does it describe a process, not a person?
  3. Does it explain the problem? Can it account for the observed variation?
  4. Can it be tested? Can you run a small experiment or gather data?
If a cause fails any of these, it’s not ready to be labeled a root cause. It’s still a hypothesis.
How to Improve Fishbone Quality: A Step-by-Step Fix
Here’s a proven workflow I use with teams to ensure high-quality fishbone analysis:
  1. Start with a sharp problem statement. Use measurable, observable, and time-bound language.
  2. Customize your categories to reflect your process—don’t default to the five M’s.
  3. Facilitate a silent brainstorming phase. Have each person write down causes independently, then share aloud.
  4. Cluster related ideas. Group similar causes to avoid repetition and identify patterns.
  5. Apply the 5 Whys to each top candidate cause. Don’t stop at the first “why”—keep asking until you hit a systemic failure point.
  6. Validate with data. Cross-check your top 1–3 causes against historical performance metrics.
This method is not flashy. It doesn’t rely on flashy software or AI. But it works because it forces rigor over guesswork.
Real-World Example: A Software Deployment Failure
At a client, a team was stuck with “frequent deployment failures.” The initial fishbone used standard categories: people, process, environment.
After applying the improved workflow:
  • The revised problem statement became: “70% of deployments fail due to configuration errors in staging environment.”
  • Categories were updated: CI/CD pipeline, configuration management, environment parity, pre-deployment testing.
  • After 5 Whys on “config management”: why was it inconsistent? Because no standard template existed. Why? No policy was enforced.
The root cause was not a “people” issue—it was a lack of documented configuration standards. A simple fix: create a shared template and enforce it via code review.
Result: deployment success rate jumped from 30% to 95% in four weeks.
What are the most common errors in fishbone analysis?
Teams often pick vague problem statements, default to generic categories, and rush to judge causes before gathering evidence. These mistakes lead to surface-level fixes that repeat the same failures.
How do I improve fishbone quality in my team’s analysis?
Start with a clear, measurable problem statement. Adapt categories to your context. Use silent brainstorming and the 5 Whys technique. Always validate causes with data before acting.
Why do beginners make root cause mistakes in fishbone diagrams?
They treat the fishbone as a form to fill out, not a thinking process. Without proper facilitation, they default to familiar explanations (e.g., “human error”) without probing deeper.
Can fishbone analysis be used in service or customer experience?
Yes. In fact, it’s highly effective for identifying systemic causes behind customer complaints, delays, or support bottlenecks. Use categories like “communication flow,” “ticket routing system,” or “team workload management.”
Is it okay to use more than five categories in a fishbone diagram?
Yes—only if they’re meaningful. The traditional five M’s are a starting point, not a rule. Use categories that reflect your process and help separate causes from symptoms.
How often should I revisit a fishbone diagram after fixing a root cause?
Revisit within 30–60 days. Measure whether the fix reduced the issue. If not, the root cause was misidentified. Use this as feedback to refine your process and improve future analysis.
