How to Define a Focused Problem Statement
Temps estimé :7 minutes 47 vues
Never start a fishbone session without a clear problem statement. A vague or overly broad goal will scatter your team’s focus and lead straight to surface-level fixes.
One of the most common mistakes I’ve observed in over two decades of guiding teams is treating a problem like a headline: “Our customer support is slow.” That’s not an issue—it’s a symptom. You can’t diagnose a symptom. You need to diagnose the cause.
The real value of a fishbone diagram lies not in the drawing, but in how precisely it’s anchored. A strong problem statement cuts through noise and sets boundaries for real analysis. It tells your team: “We’re not solving everything. We’re solving this.”
By the end of this chapter, you’ll know how to write a problem statement that’s measurable, specific, and grounded in data—so you’re not just chasing symptoms, but uncovering real root causes.
Why Your Problem Statement Matters More Than You Think
Most root cause failures don’t stem from poor diagrams. They begin with a bad problem statement.
If your problem is “Our system keeps crashing,” the team will start listing factors under “People,” “Process,” or “Technology” without knowing what’s actually happening. Is it daily? Hourly? Only during peak load? The lack of clarity invites assumptions.
Let’s be clear: a well-defined problem statement isn’t just helpful—it’s the difference between a productive session and wasted time. It ensures every discussion stays on track and every cause is evaluated within the right scope.
The One-Liner Rule for Clarity
Every strong problem statement should pass the “one-liner test.” It must be concise enough to fit in a single sentence, yet complete enough to define the who, what, when, and where.
Here’s the formula:
  • What is happening (the observable issue)
  • When it occurs (frequency, time, or trigger)
  • Where it occurs (process, system, location)
  • How much (a measurable impact)
Use this to guide your thinking. Don’t skip any element—each one helps limit ambiguity.
Problem Statement Examples That Work
Let’s look at how to apply this in real scenarios. These are actual examples from manufacturing, software, and customer service teams.
Example 1: Manufacturing
Weak: “We’re making defective parts.”
Strong: “The welding defect rate in Line 3 rose from 0.2% to 1.8% over the past two weeks, affecting 12% of units delivered to Customer X.”
This version includes: the defect (welding), the location (Line 3), the timeframe (two weeks), and the measurable impact (1.8% defect rate, customer delivery impact).
Example 2: Software Development
Weak: “The app crashes too often.”
Strong: “Mobile app crashes increased by 60% over the last 48 hours, affecting 1,200 users per day, mostly during login and payment processing.”
Now you’re not just chasing “crashes” — you’re focused on specific user actions and timing. That narrows the fishbone categories and fuels deeper thinking.
Example 3: Customer Service
Weak: “Customers are unhappy.”
Strong: “Customer satisfaction scores dropped from 88% to 72% over the past month, primarily due to delayed responses on support tickets with unresolved technical issues.”
Now your team knows exactly what to analyze: response time, ticket resolution quality, and agent workload—not vague “happiness”.
Common Phrasing Mistakes to Avoid
Even experienced teams slip into poor phrasing. Here are the top five pitfalls—and how to fix them.
  • Using vague verbs: “We have problems with quality” → Replace with “Defects in final inspection increased by 40% over the last quarter.”
  • Blaming people too early: “The operator made a mistake” → Shift to “Operator errors in calibration led to 15% of units failing calibration checks.”
  • Overloading the statement: “Our production line is failing due to machines, staff, and poor planning” → Split into two distinct statements: one for machine downtime, one for training gaps.
  • Focusing on solutions: “We need better software” → Reframe to “Software errors during data export rose from 2 to 12 incidents per day.”
  • Using “and” to connect unrelated issues: “Customers are angry and support is slow” → Split into two focused problems: one on customer sentiment, one on response time.
These mistakes may seem minor, but they’re the invisible traps that derail entire analysis sessions.
How to Refine Your Problem Statement
Once you draft a statement, test it with three questions:
  1. Can it be measured? If you can’t track change over time, it’s not actionable.
  2. Could someone else reproduce the problem? If two people can’t understand your goal, your statement is too vague.
  3. Does it fit the fishbone scope? If the issue spans multiple unrelated areas (e.g., customer complaints and data breaches), it’s too broad.
If you answer “no” to any, revise.
Pro tip: Always write the problem statement on a whiteboard before the meeting. If the team can’t agree on it in under 60 seconds, you’re not ready to draw the fishbone.
Problem Statement Checklist
Use this checklist before starting your fishbone session:
Check Yes/No
Is the problem specific to one process, system, or location?
Is there a measurable metric (e.g., defect rate, response time, error count)?
Does it include a time frame (e.g., past 7 days, since the update)?
Is it phrased as an observable issue, not a solution?
Can the team agree on it in under 60 seconds?
If you can’t check all boxes, go back. A flawed problem statement ruins the entire analysis.
Why Scope Matters: The Fishbone Problem Definition
Every fishbone diagram has a scope. If your problem statement drifts beyond that scope, the causes you find may be irrelevant.
Think of scope like a sandbox. The diagram only works if you stay inside the boundaries. If your problem is “Our customer service is bad,” you might end up analyzing marketing, delivery, and billing—none of which are part of the support process.
But if your problem is “Average response time in the support portal increased from 2 hours to 6 hours since the new system launch,” you’re focused on a single channel, a known trigger, and a clear metric. That’s fishbone-ready.
When in doubt, ask: “Is this cause related to the specific issue I defined?” If not, remove it.
What’s the difference between a problem statement and a goal?
A problem statement describes the current issue—what’s broken. A goal describes what you want to achieve—e.g., “Reduce response time to under 2 hours.” The statement focuses on diagnosis. The goal focuses on improvement.
Can a problem statement be a question?
No. While questions can guide exploration, the fishbone process requires a declarative statement. A question like “Why is customer satisfaction dropping?” invites interpretation. A statement like “Customer satisfaction dropped from 90% to 76% in three weeks” is objective and measurable.
Should I involve the entire team in writing the problem statement?
Yes—but only after a short discussion. Let participants bring in data, but let one person draft the statement first. This avoids agreement fatigue and keeps the focus tight.
How do I handle multiple problems in one session?
Don’t. Each problem needs its own fishbone. If you’re analyzing both response time and resolution quality, run two separate sessions. Trying to combine them leads to confusion and diluted insights.
What if my team disagrees on the problem statement?
Disagreement is normal. Use data to resolve it. Pull up the metrics. Ask: “Where does this data show the issue?” Often, the numbers clarify what opinions can’t.
Can I adjust the problem statement mid-session?
Yes—but only if you revisit the scope. If new evidence emerges, revise the statement and re-clarify with the team. Never allow the session to drift without re-anchoring.
