Scoping a Journey: From Trigger to Outcome
Temps estimé :7 minutes 50 vues
Imagine a customer trying to resolve a billing discrepancy. They call support, get transferred between agents, receive conflicting information, and end up frustrated. The team tries to fix the issue, but no one knows the full sequence of steps or who’s responsible. This isn’t just a support issue—it’s a design failure in process scope.
Too often, teams start modeling customer journeys from a vague point like “when the customer contacts us,” without clarifying what triggers that interaction or where the journey truly ends. This leads to models that are either too broad—covering every possible action across departments—or too narrow, missing critical handoffs that impact experience.
Scoping a journey in BPMN isn’t about capturing everything. It’s about choosing a clear, meaningful start and end that reflect a real customer goal. The goal is to create a model that reveals responsibility, identifies delays, and uncovers pain points—without drowning in complexity.
Defining the Right Start and End Events
Every journey begins with a trigger and ends with a clear outcome. The start event must be something that signals the customer’s intent to act. A common mistake is starting at « Customer contacts support, » which is a channel, not a trigger.
Instead, anchor the journey to a specific customer action: “Customer submits a dispute form for an incorrect charge”. That’s a valid start event—actionable, observable, and linked to a clear goal.
The end event should reflect a resolved state: “Dispute is resolved and customer confirms satisfaction”. This avoids the trap of ending at « support ticket closed, » which may not reflect the customer’s experience.
Here’s a simple rule: if the journey ends before the customer feels the outcome, it’s incomplete.
Start Event Types That Work
  • Message Start Event – for external triggers like “Customer sends a support request.”
  • Timer Start Event – for scheduled actions, such as “Renewal reminder email sent.”
  • Conditional Start Event – when a specific condition is met, like “Customer exceeds 30 days of inactivity.”
End Event Types That Deliver Value
  • End Event with Success Outcome – “Customer receives refund and confirms resolution.”
  • End Event with Exception Outcome – “Customer abandons the process due to unclear next steps.”
  • End Event with Feedback Loop – “Customer completes a satisfaction survey after issue resolution.”
Each end state reveals insight. A journey ending in abandonment highlights a failure in communication. One ending in satisfaction shows where the process worked.
Choosing the Right Journey Scope and BPMN Boundaries
Defining the journey scope in BPMN means agreeing on what’s inside the model and what’s not. I’ve seen teams include entire departments—marketing, finance, legal—just because they touch the customer. That’s not a journey. It’s a system.
Focus on one goal. For example, the journey from purchasing a product to receiving a delivery confirmation is a valid scope. It includes shipping, tracking, delivery, and verification—but not the customer’s initial research or post-delivery feedback.
Common Pitfalls in Journey Scope and BPMN
Problem Why It Fails Better Approach
Starting at “Customer visits website” Covers too many unrelated paths (research, purchase, support) Start at “Customer adds item to cart”
Ending at “Support ticket closed” Customer may still be frustrated, even if the ticket is resolved End at “Customer confirms resolution” or “Satisfaction survey submitted”
Modeling all channels in one flow Creates confusion and hidden assumptions Use lanes to separate channels; model path variations separately
When modeling in BPMN, treat the journey as a single path focused on the customer’s intent. Use lanes to represent different roles—customer, agent, system—but keep the flow centered on the customer’s experience.
Step-by-Step Approach to Agreeing on Journey Scope with Stakeholders
Aligning stakeholders on journey scope isn’t about consensus—it’s about clarity. Here’s how I guide teams:
  1. Start with the customer’s goal. Ask: “What does the customer want to achieve?” Use simple language. Example: “I want to return this damaged item.”
  2. Define the trigger event. What action initiates the journey? Is it a form submission? A message? A timer? Be specific.
  3. Identify the outcome. What does “success” look like? Not “ticket closed,” but “refund issued and customer notified.”
  4. Draw the first draft. Use a simple BPMN flow: Start → Activity → Decision → End. Keep it high-level.
  5. Run the “Is this the customer’s focus?” test. If you can’t explain it in one sentence to a non-technical stakeholder, it’s too broad.
  6. Validate scope with stakeholders. Show the flow and ask: “Does this reflect the experience the customer has?” If yes, you’re on track.
When stakeholders can see a clear, focused journey, they stop arguing about what to include and start focusing on what to improve.
Why Journey Scope and BPMN Matter Together
Defining the start and end of journeys isn’t just a modeling detail—it shapes how teams think. A well-scoped journey in BPMN forces clarity on responsibilities, handoffs, and timing. It turns vague ideas like “support is slow” into measurable questions: “Why does the dispatch step take 48 hours? Who owns it?”
When you model with clear boundaries, you create a shared language. The customer service agent understands the flow. The IT team sees automation opportunities. The CX leader sees where delays hurt satisfaction.
Remember: a BPMN model isn’t a process map for systems. It’s a blueprint for experience.
What’s the difference between a customer journey and a BPMN process?
A customer journey describes the experience from the customer’s perspective—emotions, touchpoints, expectations. A BPMN process maps the actual steps, responsibilities, and flows behind the scenes. They’re complementary: the journey defines the « why, » BPMN explains the « how. »
How do I decide whether to model a self-service or assisted journey?
Start with the customer’s choice. If they use help docs, chatbots, or forms, model the self-service path. If they call support or visit a branch, model the assisted path. Use gateways to show how the customer switches between paths. Keep both visible to show the full experience.
Can I model multiple journeys in one BPMN diagram?
Yes, but only if they share a common goal or flow. For example, a purchase journey might include payment, shipping, and delivery. You can model them together. But avoid combining unrelated journeys—like onboarding and refund processing—into one diagram. Each should be a separate BPMN model.
How do I handle exceptions like abandonment or long waits in BPMN?
Use Boundary Events attached to key activities. For example, attach a boundary event to “Wait for delivery confirmation” with a timer: “If no confirmation after 7 days, escalate to support.” This keeps the main flow clean while showing how the system responds to delays.
Should the customer be in their own pool in BPMN?
Yes—especially in complex journeys. A dedicated customer pool (or lane) makes their experience visible. It helps avoid confusion between customer actions and internal processes. Use message flows to show communication between the customer and service teams.
How do I ensure the journey scope stays aligned with business goals?
Anchor every journey to a business metric—like NPS, CSAT, or conversion rate. Ask: “Does this journey directly impact that metric?” If not, reconsider the scope. Keep the model focused on what matters to both the customer and the business.
