Adding Color and Icons for Better Visibility
Temps estimé :7 minutes 48 vues
Never sketch a Five Forces diagram without a clear visual hierarchy. A blank grid with five unmarked arrows may feel clean, but it’s a silent trap: it hides the core insights from anyone who needs them—your audience, your team, even your future self. The moment you fail to guide attention through visual signals, the most powerful part of your analysis becomes invisible. This isn’t about decoration. It’s about accuracy. The right colors and icons don’t just make diagrams look better—they make them work harder.
Over two decades of teaching strategy to students, startups, and business leaders has taught me one thing: clarity is not a design choice. It’s a requirement. When I first saw a student’s diagram where all forces were drawn in gray with no icons, the insights were buried. A simple color shift changed that. That’s why this chapter exists: to give you practical, low-friction tools to make your diagrams do the heavy lifting.
By the end of this section, you’ll know exactly how to use color coding analysis and icons to elevate your work from functional to impactful. You’ll create diagrams that speak clearly to beginners and impress professionals, all while keeping your process simple.
Why Visual Clarity Matters for Beginners
Beginners often struggle not with understanding the forces themselves—but with interpreting them in context. A crowded diagram with no visual cues becomes a cognitive maze. That’s why visual clarity for beginners isn’t just helpful—it’s essential.
Research shows that people process visuals 60,000 times faster than text. When applied to strategic analysis, this means a well-designed diagram can convey market dynamics in seconds, not minutes. But only if it’s built with intention.
Here’s the truth: even a small mistake in visual design—like using red for both high threat and high opportunity—can lead to misinterpretation. That’s why consistency matters. You’re not just drawing; you’re building a shared language.
Visual Design Principles for Clarity
Start with three foundational principles:
  • Contrast between forces improves recognition. Use bold lines for high-impact forces.
  • Color should signal meaning, not just style. Avoid rainbow palettes; use a limited, intentional set.
  • Icons act as visual anchors. They reduce cognitive load by replacing text with symbolic meaning.
These aren’t suggestions. They’re the difference between a diagram that works and one that confuses.
Assigning Meaning: Color Coding Analysis
Color coding analysis transforms abstract forces into actionable insights. But it’s not about picking your favorite colors. It’s about assigning meaning consistently across all diagrams.
Here’s a practical system I use with students:
Color Meaning When to Use
Red High Threat When a force strongly reduces profitability
Yellow Moderate Threat When a force has noticeable but not overwhelming impact
Green Low Threat When a force is weak or easily managed
Apply this consistently. For example, if buyer power is high, use red. If supplier power is low, use green. This way, your diagram becomes a visual threat map.
Here’s a real example: when analyzing a local coffee shop, I found that buyer power was moderate. The shop served a loyal local base, but competition was rising. I used yellow to reflect this—clear, neutral, and meaningful. It helped the student see not just what was happening, but how strong it was.
Color Coding Tips for Beginners
  • Use only 3–4 colors max per diagram. Too many distract.
  • Apply colors consistently across all exercises.
  • Always include a legend—even in your first draft.
  • Test your diagram with someone unfamiliar with the topic. Can they understand it in 10 seconds?
Icons That Speak: Simple Symbols for Complex Ideas
Icons are the silent teachers of your diagram. They reduce text clutter and speed up comprehension. You don’t need complex graphics—just simple, recognizable symbols.
Here’s a beginner-friendly icon set I recommend:
  • Competition: Two people facing off (⚔️) or two arrows crossing.
  • Supplier Power: A hand holding a wrench or a factory icon (🏭).
  • Buyer Power: A shopping cart (🛒) or a hand holding a bag.
  • New Entrants: A small person climbing a mountain (🧗).
  • Substitutes: A question mark inside a box (❓) or a switch icon (🔄).
Place these icons near the force label. For example:
Competitors: ⚔️ (High threat)
Now, the reader sees the threat level and the category at a glance. No need to reread.
How to Choose Icons
  • Stick to one style: all line icons or all filled icons.
  • Use consistent size and placement—no floating icons.
  • Test on a child or non-expert. Can they guess the meaning?
  • Use tools like Font Awesome or Icons8 for free, clean icons.
Putting It Together: A Step-by-Step Example
Let’s walk through a quick example using a local bike shop.
  1. Draw the standard Five Forces layout.
  2. Label each force clearly.
  3. Assign colors: competitors = red (high), suppliers = green (low), buyers = yellow (moderate).
  4. Add icons next to each label.
  5. Include a legend in the corner.
Now, anyone looking at your diagram sees the big picture in seconds. This is what visual clarity for beginners truly means: making insight visible.
Even with the best intentions, mistakes happen. Here are the top three issues beginners face—and how to fix them:
  • Overloading with colors: More than four colors confuses. Stick to threat level, not emotion.
  • Using icons without context: An icon means nothing without a legend. Always include one.
  • Changing styles mid-diagram: If you start with line icons, don’t switch to filled ones halfway through.
Remember: visual design is not about aesthetics. It’s about understanding. A diagram should be read faster than it’s drawn.
Visual Design Checklist for Your Five Forces Diagram
Before you finalize your diagram, ask yourself:
  • Does every force have a color? ✅
  • Is there a legend? ✅
  • Are icons used consistently? ✅
  • Can someone unfamiliar with the topic understand the main threats in under 10 seconds? ✅
  • Does color coding analysis reflect actual threat levels? ✅
Check all boxes. Your diagram is now ready for presentation—or peer review.
Can I use emojis in my Five Forces diagram?
Yes—but sparingly. Emojis can be effective for beginners, especially in digital notes. But for formal reports, use standardized icons from reputable libraries. Emojis vary by platform and may not print clearly.
How do I choose colors if my school or company has brand guidelines?
Follow the guidelines. But ensure the colors still signal threat levels. For example, if your brand uses blue, use darker blue for high threat, lighter for low. Let the shade communicate the message.
My diagram is too crowded. What should I do?
Don’t sacrifice clarity for space. Use icons to reduce text. Place the legend outside the main diagram. Prioritize the forces with the highest threat. You can add detailed notes in a side panel.
Should I use the same color scheme for every diagram?
Yes, for consistency. A uniform color system builds visual memory. You’ll recognize patterns faster and your audience will trust your analysis more.
Do I need to explain icons and colors in my report?
Yes—always include a legend. Even if your audience is familiar, a legend ensures clarity. It also shows you’ve thought through the design.
