How CMMN and BPMN Complement Each Other
Estimated reading: 7 minutes 61 views
When I see a process model that tries to force every possible exception into a rigid flow, I know the right tool isn’t being used. This happens when a BPMN diagram becomes overloaded with gateways, branches, and exceptions—trying to manage unpredictability with a structure built for repetition. It’s not wrong per se, but it’s fundamentally mismatched. The real issue isn’t the notation—it’s the failure to recognize that not all work is the same.
Over two decades of modeling with business analysts and technical architects has taught me one thing: the most effective process landscapes don’t rely on a single standard. They use BPMN for predictability and automation, and CMMN for adaptability and human judgment. The real power lies not in choosing one over the other, but in understanding how they work together.
This chapter demystifies the relationship between CMMN and BPMN. You’ll learn why they are not competitors but complementary forces—each designed for different types of business work. You’ll see how leading organizations integrate both within the same system, using BPMN for routine workflows and CMMN for complex, knowledge-intensive cases.
By the end, you’ll have a clear framework for deciding when to use each notation, how to structure hybrid models, and how to avoid the common pitfall of over-structuring or under-defining. This is practical wisdom from the field—no theory, no jargon, just real decisions grounded in experience.
Why Structure and Flexibility Must Coexist
Business processes aren’t monolithic. Some run like clockwork—bank account verification, purchase order approvals, employee onboarding. Others unfold unpredictably—incident investigations, claim disputes, medical diagnoses. These require different modeling approaches.
BPMN excels where the path is known, the rules are clear, and automation is desired. It’s built on control flow, sequence, and event-driven transitions. But when the sequence isn’t predefined—when decisions depend on expert judgment, external data, or evolving circumstances—BPMN becomes brittle.
CMMN, by contrast, is designed for adaptive, knowledge-centric work. It doesn’t dictate the flow. Instead, it defines the elements of a case: stages, tasks, milestones, and conditions for progression. The case plan can evolve based on events, decisions, and data—exactly what’s needed for work that’s not fully knowable at the start.
Think of BPMN as a highway with defined exits and speed limits. CMMN is more like a mountain trail—there’s a general direction, but the path changes based on terrain, weather, and the hiker’s judgment.
Real-World Example: Insurance Claim Handling
Consider an insurance claim. The initial validation steps—checking policy coverage, verifying claimant identity, assessing damages—follow a fixed sequence. That’s BPMN.
But if the claim involves a complex accident, a disputed liability, or third-party claims, the process becomes dynamic. The adjuster may need to gather new evidence, consult legal teams, or initiate a fraud investigation. These decisions depend on contextual information, not a fixed path.
This is where CMMN shines. A CMMN case plan manages the entire investigation lifecycle. Tasks appear based on triggers, criteria change as evidence emerges, and milestones reflect evolving progress. The model doesn’t force a fixed path—it supports discovery.
The Synergy of Integration: BPMN Controls, CMMN Adapts
Many mature organizations don’t choose between BPMN and CMMN—they use both. The key is to understand their roles in a hybrid model.
You’ll often see BPMN at the orchestration level, managing the high-level workflow, while CMMN handles sub-processes where flexibility is required. In insurance, for example:
  • BPMN: Manages the claim lifecycle—submission, validation, assignment, approval.
  • CMMN: Handles the investigation subprocess, where tasks like “request expert review” or “gather police report” appear conditionally.
This isn’t redundancy. It’s division of labor. BPMN provides structure. CMMN provides adaptability.
Common Integration Patterns
Here are the most effective ways to integrate BPMN and CMMN in real systems:
  1. BPMN Controls CMMN Subcase: A BPMN process calls a CMMN case as a subprocess. The case handles adaptive work while the parent process maintains overall control.
  2. Event-Driven Case Launch: A BPMN gateway triggers a CMMN case based on a condition—e.g., “If claim exceeds $100,000, launch investigation case.”
  3. Shared Case File: Both BPMN and CMMN models reference the same case file data, ensuring consistency and avoiding data silos.
  4. CMMN as Exception Handler: When BPMN encounters an unhandled exception, it delegates to a CMMN case to resolve the issue.
These patterns are not theoretical. I’ve seen them implemented in financial services, healthcare, and digital transformation projects. The result? Models that are both automatable and intelligent.
When to Use Which: A Decision Framework
There’s no universal rule. The decision depends on four key factors:
  • Predictability: Is the workflow known in advance? If yes, BPMN. If no, CMMN.
  • Frequency: Is this a repeatable, high-volume task? BPMN. If it happens rarely and uniquely, CMMN.
  • Control Authority: Is the sequence dictated by business rules or by human judgment? BPMN for rule-based, CMMN for judgment-based.
  • Data Dependencies: Does progress depend on external data or decisions? CMMN is better at handling uncertain data triggers.
Ask yourself: “Would this process be the same tomorrow, or would an expert need to decide the next step based on new context?” If the answer is the latter, you’re in CMMN territory.
Decision Matrix: BPMN vs CMMN
Factor BPMN CMMN
Best for Repeatable, rule-based workflows Adaptive, knowledge-driven cases
Flow control Explicit, pre-defined sequence Constraint-based, dynamic progression
Automation potential High (scriptable, executable) Medium (driven by events and conditions)
Human decision weight Low (rules-driven) High (judgment, discovery)
This table isn’t a rulebook. It’s a guide. In practice, the best models blend both—using BPMN to manage the predictable and CMMN to manage the uncertain.
Practical Steps to Integrate CMMN and BPMN
Integrating BPMN and CMMN isn’t about learning two tools—it’s about mastering a mindset. Here’s how to start:
  1. Map your processes first. Identify where the workflow is predictable and where it’s adaptive. Group them by function, not notation.
  2. Define case boundaries. Where does a case begin and end? What data is shared between BPMN and CMMN?
  3. Use CMMN for investigation, BPMN for routing. In claims, use CMMN for the investigation phase, BPMN for escalation, approval, and payment.
  4. Ensure shared data context. Use a common case file or data model so both BPMN and CMMN can access the same information.
  5. Validate with real users. Have analysts and subject matter experts review both models. Does it reflect how work actually happens?
When teams start modeling this way, they stop asking “Which one should I use?” and start asking “How can I use both?”
Can I use both BPMN and CMMN in the same system?
Yes—this is not just possible, it’s common in mature organizations. BPMN handles structured processes, while CMMN manages adaptive cases. They can be linked through subprocesses, events, or shared data files.
What’s the difference between structured vs adaptive process modeling?
Structured process modeling (BPMN) assumes a predictable path, governed by rules and conditions. Adaptive process modeling (CMMN) assumes the path evolves based on events, decisions, and data. The former is for automation. The latter is for discovery.
How do I integrate BPMN and CMMN in Visual Paradigm?
Visual Paradigm supports both notations in the same project. You can embed a CMMN case as a subprocess within a BPMN process. The tool allows you to link case files, define triggers, and simulate execution across both models.
Is CMMN more complex than BPMN?
Not inherently. CMMN has a different kind of complexity—it’s built around flexibility, not sequence. It’s simpler in structure but more nuanced in behavior. The learning curve is steeper for those used to flowcharts, but the payoff in real-world adaptability is significant.
Can I convert a BPMN diagram into a CMMN case?
Not automatically. But you can refactor a BPMN subprocess into a CMMN case if it involves uncertainty, expert judgment, or evolving tasks. The conversion isn’t literal—it’s about rethinking the model’s purpose.
Why should I care about integrating BPMN and CMMN?
Because most real-world business work isn’t purely structured or purely adaptive. It’s a blend. Using both notations allows you to model reality accurately—avoiding over-structuring or under-defining. The result is models that are both executable and realistic.
