Integrating CRC Design into Agile Sprints
Estimated reading: 7 minutes 47 views
Many teams assume that agile means skipping formal design—focusing only on coding and user stories. But that’s a misconception. The real power of agile lies in its ability to integrate lightweight, collaborative design practices like CRC modeling directly into sprint cycles. CRC cards aren’t just for brainstorming; they are a living design artifact that informs sprint planning, refines backlog items, and grounds technical decisions in shared understanding. When done right, CRC in agile development becomes a bridge between business needs and technical implementation—keeping teams aligned and architecture sound.
I’ve worked with dozens of teams across startups and enterprise systems, and the most successful ones don’t wait for full UML diagrams. Instead, they use CRC cards during refinement sessions to explore domain behavior, identify key actors, and define responsibilities—before writing a single line of code. This isn’t theory. It’s a practice I’ve refined over two decades: CRC design sprint sessions aren’t just about sketching—they’re about building consensus, validating assumptions, and making design visible early.
By the end of this chapter, you’ll understand how to use CRC modeling as a core part of your agile workflow, transform user stories into actionable domain models, and ensure your sprints are not just about delivery—but about intelligent, sustainable design.
Why CRC Belongs in Agile Sprints
Agile isn’t about abandoning design—it’s about making it adaptive, collaborative, and just-in-time. CRC cards are the perfect tool for this. They’re lightweight, easy to modify, and encourage team discussion.
Unlike formal UML diagrams that can feel static or intimidating, CRC cards are meant to be moved, erased, and rethought. This makes them ideal for agile refinement sessions where the goal is not perfection, but clarity.
Here’s how CRC integrates naturally into the agile lifecycle:
  • Sprint Planning: Use CRC cards to break down complex epics into domain-level components.
  • Backlog Refinement: Turn vague user stories into responsibilities and collaborations.
  • Design Review: Revisit CRC models after implementation to validate alignment.
  • Onboarding: New developers can understand the system by walking through CRC cards.
How CRC Models Inform User Story Refinement
Consider a story like: “As a customer, I want to track my order status so I can plan my delivery.” This is functional, but it lacks depth. CRC modeling brings it alive.
During refinement, the team identifies:
  • Class: Order
  • Responsibility: “Store order status,” “Notify customer of updates”
  • Collaboration: “With Customer,” “To DeliveryService
Now the story isn’t just about tracking—there’s a clear model. This is where agile UML workflow begins: not with a diagram, but with shared understanding.
Step-by-Step: Running a CRC Design Sprint
Running a CRC design sprint isn’t about perfection. It’s about speed, clarity, and team ownership. Here’s a practical workflow I’ve used with teams from fintech to healthcare applications.
  1. Start with a user story. Choose one from the backlog that’s ambiguous or complex.
  2. Identify classes. Ask: “What objects are central to this story?” Write them on cards.
  3. Assign responsibilities. For each class, ask: “What should it do?” Be specific—avoid vague terms like “manage” or “handle.”
  4. Map collaborations. Identify which classes interact with others. Use lines or arrows to show relationships.
  5. Review for completeness. Are all key behaviors captured? Is there a missing entity?
  6. Translate to UML (optional). If needed, sketch a quick class diagram based on the CRC model.
Each step takes 5–10 minutes. A full session lasts 30–45 minutes. The goal isn’t documentation—it’s consensus.
Example: Order Tracking in a Retail App
Class Responsibility Collaboration
Order Store status (pending, shipped, delivered) With Customer, notifies NotificationService
Customer View order history, receive status updates Receives from Order, uses DeliveryService API
DeliveryService Provide tracking info, update delivery status Called by Order, returns to Customer
This table is born from a 15-minute CRC sprint. It’s not a formal model yet—but it’s enough to guide implementation.
Linking CRC to Iterative Modeling
Agile thrives on iteration. But too many teams treat iteration as just coding cycles—missing the opportunity to refine the model. That’s where iterative modeling comes in.
After each sprint, revisit the CRC cards. Ask:
  • Did the implementation match our original responsibilities?
  • Did we miss any behavior?
  • Are any collaborations now redundant or unclear?
This feedback loop is crucial. It turns a one-time sketch into a living design artifact. I’ve seen teams use this to refactor legacy code with remarkable clarity—because every change is tied to a shared understanding.
Here’s how iterative modeling benefits your sprint cycle:
  • Refines future user stories: As you learn from implementation, new stories emerge more clearly.
  • Reduces rework: Misunderstandings caught in refinement are far cheaper than bugs in production.
  • Balances speed and quality: You don’t need full UML up front—just enough design to proceed safely.
When to Advance from CRC to UML
There’s no rule that says you must convert every CRC card to a UML diagram. But when the model stabilizes—after 2–3 sprints—it’s time to formalize.
Use this checklist to decide:
  • Do multiple team members understand the model without explanation?
  • Are responsibilities consistent across stories?
  • Are collaborations well-defined and stable?
  • Is the system being extended in predictable ways?
If yes, it’s time to map CRC elements to class diagrams. Remember: UML doesn’t replace CRC—it inherits from it.
Even with good intent, teams stumble. Here are the most common mistakes in integrating CRC design into agile sprints—and how to fix them.
1. Treating CRC as a One-Time Exercise
Some teams run a CRC session once and never touch it again. That breaks the feedback loop.
Solution: Revisit CRC models at the end of each sprint. Update them based on new behavior or refactored code.
2. Over-Engineering During Refinement
Teams sometimes dive into method signatures, parameters, and visibility too early.
Solution: Focus only on behavior and collaboration. Save details for when the model is stable.
3. Ignoring the Business Context
CRC cards can become purely technical—losing touch with user needs.
Solution: Always tie responsibilities back to user stories. Ask: “Does this help the customer?”
4. Skipping the Team Conversation
Working in isolation may produce a diagram—but not shared understanding.
Solution: Use sticky notes, whiteboards, and pair work. CRC is a team exercise, not a solo task.
How does CRC design sprint help in backlog refinement?
CRC design sprint transforms vague user stories into concrete domain models. By identifying classes, responsibilities, and collaborations, teams uncover hidden complexity and clarify acceptance criteria—making stories more testable and implementable.
Can CRC in agile development replace UML diagrams?
No—CRC isn’t a replacement. It’s a precursor. CRC helps discover and validate design early. UML diagrams provide a formal, persistent record. Use CRC to explore, UML to document.
What’s the difference between agile UML workflow and traditional modeling?
Traditional modeling often starts with full UML diagrams. Agile UML workflow starts with CRC cards and evolves iteratively. It’s responsive to change, avoids over-documentation, and prioritizes team understanding over notation.
When should I stop using CRC cards and start drawing UML class diagrams?
When the model has stabilized—after 2–3 iterations of refinement. Use CRC for exploration; move to UML when you have consistent, repeatable behavior and responsibilities.
How can I keep CRC design sprint sessions productive?
Set a timebox (20–45 minutes), limit participants to 4–6 people, use sticky notes, and rotate roles (facilitator, recorder, timekeeper). Focus on behavior, not syntax.
