Refactoring Through CRC Feedback Cycles
Estimated reading: 7 minutes 47 views
About 6 out of 10 teams I’ve worked with assume that once a class diagram is drawn, the design is locked in. That’s a mistake. The real power of CRC modeling lies not in the first draft—but in how it evolves through CRC iteration and structured feedback. When teams treat CRC cards as living documents rather than static inputs, the resulting UML models become more accurate, cohesive, and aligned with actual system behavior.
I’ve seen teams spend weeks refining a class diagram only to discover it doesn’t reflect user stories or domain interactions. The fix isn’t in adding more complexity—it’s in re-engaging the CRC process. Each round of feedback, especially from cross-functional team members, reveals gaps in responsibility mapping, incomplete collaborations, or ambiguous associations.
This chapter shows how to use UML improvement cycle feedback loops to turn early, informal CRC sketches into robust, maintainable class diagrams. You’ll learn how to apply responsibility revision not as a cleanup step, but as a core design activity that strengthens the entire model.
Why Feedback Cycles Are the Heart of Model Evolution
UML diagrams aren’t static blueprints. They’re living models that reflect team understanding. Without feedback, they become artifacts of individual assumptions, not shared knowledge.
When CRC sessions are followed by open reviews, diverse perspectives surface missing responsibilities, conflicting assumptions, or duplicated classes. That’s not a flaw—it’s a feature.
The key is to treat every feedback round as a CRC iteration, where the team revisits the cards, re-evaluates responsibilities, and then updates the UML diagram accordingly. This isn’t rework—it’s refinement.
How Feedback Translates into Model Improvement
Feedback isn’t just about fixing errors. It’s about deepening understanding. A developer might question why a PaymentProcessor class has a sendReceipt() method. The CRC team may realize that receipt handling is better managed by a NotificationService.
That insight triggers a responsibility revision. The class diagram is updated: PaymentProcessor now depends on NotificationService, and the association is properly labeled.
This pattern—identify → challenge → revise → reflect—forms the UML improvement cycle. Each iteration tightens the model’s alignment with real-world behavior, not just syntax.
Implementing the CRC Feedback Loop
Design isn’t linear. It’s recursive. The most effective teams use structured feedback loops that mirror agile inspection cycles, but at the model level.
Step-by-Step Feedback Cycle
  1. Conduct a CRC session to explore a system area (e.g., order processing).
  2. Map findings into a preliminary UML class diagram.
  3. Host a 30-minute design review with developers, testers, and domain experts.
  4. Collect feedback on: missing responsibilities, unclear associations, or duplicated roles.
  5. Revise CRC cards with new insights—this is a CRC iteration.
  6. Update the UML diagram based on revised responsibilities.
  7. Repeat until consensus and consistency are achieved.
Each cycle tightens the design. The diagram becomes more than a document—it becomes a shared source of truth.
What to Look for in Feedback
Not all feedback is equally valuable. Focus on input that challenges assumptions or reveals behavioral gaps. Examples:
  • “Why does Customer manage Order history? Shouldn’t that be handled by a HistoryService?”
  • “The InventoryManager seems to need StockLevel data. Is that an attribute or a separate class?”
  • “I don’t see a link between Payment and Order. How’s payment confirmed?”
These questions aren’t bugs—they’re design signals. They point to missing responsibilities or misunderstood collaborations.
Common Pitfalls in Feedback Integration
Even with good intentions, teams can misstep. Here’s how to avoid common traps:
1. Over-Engineering During Feedback
Feedback often brings up “what if” scenarios. A tester might suggest adding a ValidationRule class or a PaymentStatus enum. Push back if it’s speculative. Ask: “Does this belong to the current scope?” If not, log it as a future enhancement, not a design requirement.
Keep the model focused. Use responsibility revision only to fix what’s already implied—not to add every possible variation.
2. Ignoring Behavioral Intent
One team added a LogService class to every class with a “process” responsibility. The model became bloated and hard to navigate.
Instead, ask: “What behavior is actually being modeled?” If logging is a side effect, use a flag or a simple method. If it’s a core concern, then consider a separate class—but only if it’s invoked across multiple scenarios.
3. Repeating the Same Feedback
If the same question arises in multiple reviews, the CRC cards are likely unclear. Revisit the responsibility wording. Use active verbs: “notify user,” “calculate total,” “validate payment.” Avoid vague terms like “handle” or “process.”
Clarity in CRC cards reduces ambiguity in UML models.
When to Stop the Loop
There’s no magic number of iterations. But you can tell it’s time to stop when:
  • Feedback is focused on minor refinements (e.g., naming, visibility).
  • Team consensus is stable across multiple reviews.
  • All key domain scenarios are modeled and validated.
At that point, the model is ready for documentation, code generation, or integration into the development workflow.
Tools to Support Iterative Refactoring
Modern modeling tools like Visual Paradigm simplify the CRC UML refactoring workflow. You can:
  • Link CRC cards directly to UML classes for traceability.
  • Use version control to track changes across feedback cycles.
  • Automatically generate class diagrams from updated CRC data.
These features turn the feedback loop into a collaborative, auditable process—not a series of disjointed edits.
Real-World Example: Order Processing Refactoring
Consider a team modeling an e-commerce order system. Their first UML diagram had:
  • Order with calculateTotal()
  • Order with sendConfirmation()
  • Order with updateInventory()
During a review, a developer asked: “Who manages inventory changes? Shouldn’t that be in a separate service?”
This triggered a CRC iteration. The team revised the cards:
  • Order holds calculateTotal() and notifyCustomer()
  • InventoryService handles updateStock()
  • Order depends on InventoryService
The updated UML diagram now reflects a clearer separation of concerns. The responsibility revision improved cohesion and reduced coupling.
How many CRC iterations should I run before finalizing the UML model?
There’s no fixed number. I’ve seen teams complete the process in 2–3 rounds. If your feedback cycle yields only minor edits (naming, visibility, minor association tweaks), you’re ready to move on.
Can I use CRC cards in a sprint review or planning meeting?
Absolutely. CRC cards are ideal for planning because they’re quick to sketch and easy to discuss. Use them in backlog refinement to explore domain complexity before writing user stories or designing classes.
What if team members disagree on responsibility assignment?
Disagreement is healthy. Use it as a signal to re-express responsibilities in behavioral terms. Ask: “What happens when X occurs?” That often reveals the correct actor and responsibility.
Does CRC UML refactoring slow down development?
Not if done right. The upfront effort reduces rework later. A well-refined model leads to cleaner code, fewer bugs, and faster onboarding.
Is it okay to skip CRC cards and go straight to UML?
No. CRC cards help teams explore intent before committing to structure. Skipping them often leads to over-abstracted, rigid models that don’t reflect real behavior.
How do I ensure feedback is constructive and not just criticism?
Frame feedback around behavior, not people. Instead of “This is wrong,” try “I noticed this method might be called from multiple places—could it be a better fit in a separate service?”
