How to Draw Basic Class Relationships
Leitura estimada: 6 minutos 179 vistas
When you’re building a class diagram, how do you decide whether to connect two classes with a solid line, a line with a triangle, or a filled diamond? This is the question that trips up countless beginners.
My 20+ years working with teams on real software projects have taught me: clarity in relationships comes not from memorizing symbols, but from understanding their meaning in context.
Here, you’ll learn how to draw and interpret the four foundational UML class relationships—association, inheritance, aggregation, and composition—using real-world examples you can apply immediately.
Understanding the Core Relationships
UML class relationships are the backbone of structural modeling. They clarify how objects interact, share data, and depend on one another.
Each relationship has a specific purpose and notation. Getting them right means your diagrams become tools for communication, not just visual clutter.
1. Association: A Connection Between Classes
An association represents a structural link between two classes. It shows that one class uses or interacts with another.
Use solid lines with open arrowheads to indicate direction. The arrow points to the class being referenced.
Example: A Student enrolls in a Course. The Student class has a reference to Course.
Student  ----> Course
Always label the association with a role name (e.g., “enrolls in”) or a navigability indicator if the relationship is one-way.
2. Generalization (Inheritance): “Is-a” Relationship
Generalization represents inheritance—when one class is a specialized version of another.
Draw it with a solid line and a hollow triangle pointing to the parent class.
Example: A Car is a Vehicle. The Car class inherits from Vehicle.
Vehicle
  Car
Use generalization only when you’re modeling a true “is-a” hierarchy. Avoid using it just because two classes share methods.
💡 Note: In UML, inheritance is also called “generalization.” The arrow always points to the generalized (parent) class.
3. Aggregation: “Has-a” (Whole-Part, Loose Coupling)
Aggregation models a “has-a” relationship where one class contains another, but the contained object can exist independently.
Use a hollow diamond at the whole (container) end of a line.
Example: A University has a Department. If the university closes, the department can still exist elsewhere.
University (○) ----> Department
Aggregation is passive. The container doesn’t manage the lifetime of the part.
4. Composition: “Has-a” (Whole-Part, Strong Coupling)
Composition is a stronger form of aggregation. The part cannot exist independently of the whole.
Use a filled diamond at the whole end of the line.
Example: A House has a Room. If the house is demolished, the room ceases to exist.
House (●) ----> Room
Composition implies ownership. The whole controls the part’s lifecycle.
When to Use Which Relationship: A Decision Flow
Knowing the symbols isn’t enough. The real skill is choosing the right one based on your intent.
Ask yourself these questions when drawing class relationships:
  • Is it inheritance? Does the child class logically extend the parent? Use generalization.
  • Is there ownership or lifecycle control? Does the whole manage the part’s existence? Use composition.
  • Can the part survive independently? If yes, use aggregation.
  • Is there no ownership, just a link? Use association.
Quick Reference Table: UML Relationships
Relationship Notation Meaning Use Case
Association Line with open arrow Interaction or reference Student enrolls in Course
Generalization Hollow triangle Is-a (inheritance) Car is a Vehicle
Aggregation Hollow diamond Has-a (loose) University has a Department
Composition Filled diamond Has-a (strong) House has a Room
Common Mistakes to Avoid
Even experienced modelers make these errors. Here’s how to avoid them:
  • Overusing inheritance: Don’t model every shared behavior with inheritance. Favor composition over inheritance when possible.
  • Confusing aggregation with composition: Ask: “Can the part exist without the whole?” If yes, aggregation. If no, composition.
  • Using generalization for mere similarity: Just because two classes share methods doesn’t mean one is a subtype. Only use generalization when the “is-a” relationship holds.
  • Ignoring multiplicity: Always define cardinality (e.g., 1..*, 0..1) to clarify how many objects are involved. This prevents ambiguity.
Practical Example: Library Management System
Let’s walk through a real-world example to see these relationships in action.
Consider a Library that holds Books. Each Book has a Category. A Librarian manages the Library.
  • Library has Book → Composition (if books are destroyed when the library closes)
  • Book has Category → Aggregation (a category can exist without a book)
  • Librarian manages Library → Association (one-way reference)
  • Book is a Publication → Generalization (inheritance)
Using these rules ensures your class diagram reflects actual system behavior.
Best Practices for Clean, Effective Diagrams
Even the best relationships become useless if the diagram is cluttered or ambiguous.
Follow these principles:
  1. Keep it simple: Start with core classes and relationships. Add complexity only when needed.
  2. Label roles and multiplicities: Always include role names (e.g., “borrows”, “owns”) and cardinality (e.g., 1..*).
  3. Use consistent layout: Group related classes together. Align lines to reduce crossing.
  4. Review for meaning: Ask: “Does this diagram tell me what the system really does?” If not, simplify or clarify.
What’s the difference between aggregation and composition?
Aggregation is a “loose” has-a relationship where the part can survive independently. Composition is “strong” has-a: the part cannot outlive the whole. Use composition when the part’s lifecycle is controlled by the whole.
Can I use both association and composition in the same diagram?
Yes. Association shows a general relationship. Composition specifies a stronger, ownership-based link. For example, a Bank has a Branch (composition), and Branch has Customer (association).
When should I avoid inheritance in class diagrams?
Avoid inheritance if the relationship is not truly “is-a.” Use composition to combine behaviors instead. It’s safer, more flexible, and easier to maintain.
How do I draw multiple relationships between the same two classes?
Use different roles and multiplicities. For example, a Student can be enrolled in multiple Courses, and a Course can have many Students. Use role names like “enrolls in” and “has students” to clarify direction.
Is UML inheritance and association the same as dependency?
No. Dependency is a weaker, temporary relationship (e.g., a method uses a class as a parameter). Association is permanent and structural. Generalization is inheritance. They are distinct and should not be confused.
How do I know if I need a generalization or just a simple association?
If one class extends the behavior of another and is a true subtype (e.g., Student extends Person), use generalization. If it just uses or references another class, use association.
Final Thoughts
Mastering UML class relationships isn’t about memorizing symbols—it’s about thinking clearly about how your objects interact.
Start with simple associations. Then, add inheritance only when you have a true “is-a” hierarchy. Use composition and aggregation to model ownership and containment accurately.
Remember: a well-drawn class diagram doesn’t just look good—it prevents misunderstandings, guides implementation, and helps teams align on design.
Now, grab a tool like Visual Paradigm and try drawing a basic class diagram for a simple e-commerce system. Focus on the relationships first. You’ll be surprised how much clarity comes from just getting the connections right.
