Collaboration and Practice
Время чтения: 2 мин. 306 просмотров
Have you ever tried to model a system alone, only to realize your class responsibilities don’t make sense when shared with a teammate? Or perhaps you’ve led a design session where the conversation stalled because no one knew how to start? This section addresses those real moments—where theory meets teamwork.
Collaboration isn’t just about working together. It’s about building shared understanding through structured interaction. In this section, you’ll move beyond solo modeling and explore how CRC cards become a shared language for teams, educators, and developers alike. Drawing from over two decades of experience, I’ll guide you through practical techniques that turn abstract ideas into tangible, actionable design.
By the end, you’ll know how to run a focused CRC workshop, use CRC cards to explain complex systems to non-technical stakeholders, and avoid common modeling pitfalls—without overcomplicating the process.
With real-world practice in mind, here’s what you’ll explore:
  • Collaborative CRC Workshops: Engaging Your Team Effectively – Learn how to plan and run an interactive CRC card session using facilitation techniques and defined roles to keep teams focused and productive.
  • CRC Cards as a Teaching and Communication Tool – Discover how educators and technical leads use CRC cards to simplify complex systems for both students and business stakeholders.
  • Digitizing and Sharing CRC Models in Visual Paradigm – See how physical CRC sessions can become persistent, shareable models using cloud-based tools—ideal for remote or evolving projects.
  • Common Mistakes in CRC Modeling (and How to Fix Them) – Identify and correct frequent errors like vague responsibilities or duplicated classes with concrete examples and correction strategies.
  • Plan and facilitate a successful team CRC modeling session
  • Use CRC cards as a visual teaching aid to explain object-oriented design basics
  • Run a run CRC session with clear structure and group dynamics
  • Convert physical CRC cards into digital models for long-term use
  • Identify and correct common CRC modeling mistakes that derail collaboration
  • Apply group modeling techniques to improve system design quality in teams
Прокрутить вверх
