BPMN Diagram Selection Checklist
Время чтения: 8 мин. 53 просмотров
Most teams don’t struggle with modeling—they struggle with choosing the right view. The moment you realize that a single process can be shown in four different ways, the real challenge begins: which one to use, when, and for whom?
After 20 years of modeling in regulated industries, fintech, and global supply chains, I’ve seen the same mistake repeated: using a process diagram to explain a cross-organizational handoff, or a choreography diagram to train a frontline employee. The result? Confusion, misalignment, and wasted time.
This checklist isn’t a rigid rulebook. It’s a decision-making compass—practical, experience-tested, and built to help you pick the right BPMN diagram type based on real-world constraints: stakeholder needs, automation goals, and integration complexity.
Ask These 5 Questions Before Choosing a Diagram Type
Start with clarity on purpose. Every diagram should answer one primary question. If it doesn’t, it’s likely the wrong type.
1. Who is the primary audience?
Are you speaking to a developer, a compliance officer, a business analyst, or an executive?
  • Developers or technical teams need executable models. Use a process diagram with service tasks, data objects, and clear sequence flows.
  • Executives or business leaders care about ownership, timing, and outcomes. Use a conversation diagram to show who communicates with whom and about what.
  • Legal or compliance teams need precise message exchange rules. A choreography diagram is ideal—no internal logic, just message order and obligations.
  • Operations or cross-functional teams need to see handoffs and responsibilities. A collaboration diagram with pools and message flows is most effective.
2. What level of detail is required?
Too much detail overwhelms. Too little leaves gaps. The right diagram type naturally limits scope.
  • Internal workflow with decision logic? Use a process diagram—it’s built for gateways, loops, and conditional paths.
  • Showing only message exchanges between systems? A choreography diagram keeps the focus on timing and order, not internal steps.
  • Summarizing multiple interactions into a single topic? A conversation diagram groups related messages under a common theme—like “Order Confirmation” or “Claim Escalation.”
3. Is automation or integration the goal?
If the model will be deployed, the diagram type must support execution.
  • Planning to execute the process in a BPM engine? Only a process diagram with executable elements (e.g., service tasks, timers, data inputs) can be deployed.
  • Designing a system interface contract? Use a choreography diagram to define the expected message sequence between systems—this becomes the contract.
  • Mapping integration points across teams? A collaboration diagram clearly shows message flows and responsibilities between pools.
4. Are multiple organizations or systems involved?
When more than one entity is in the loop, the diagram type must reflect that reality.
  • Two departments within the same company? Use a collaboration diagram with lanes in a single pool or separate pools.
  • Partners, suppliers, or external vendors? A choreography diagram defines the agreed-upon behavior without exposing internal processes.
  • Multiple teams with overlapping responsibilities? A conversation diagram simplifies the view by grouping interactions into logical topics.
5. Is this a one-time documentation effort or part of an ongoing model?
Long-term models need consistency. The diagram type should support traceability and reuse.
  • Documenting a legacy process? A process diagram is easiest to create and understand.
  • Building a living model for continuous improvement? Use a collaboration or choreography diagram as the source of truth, then derive process diagrams from it.
  • Creating a model for governance or audit? A conversation diagram provides a high-level audit trail of communication flows.
Decision Matrix: Match Your Scenario to the Right Diagram
Use this table to quickly map common business scenarios to the most appropriate BPMN diagram type. It’s based on real-world modeling projects across banking, healthcare, and logistics.
Business Scenario Recommended Diagram Type Why This Works
Onboarding a new employee with HR, IT, and Finance involved Collaboration Diagram Clearly shows message flows between departments without detailing internal steps.
Defining the message sequence between a bank and a payment gateway Choreography Diagram Establishes a contract for message exchange without revealing internal logic.
Showing how customer service escalates claims across levels Process Diagram Best for modeling internal decision points, loops, and conditional routing.
Presenting the high-level communication structure to a board of directors Conversation Diagram Summarizes key interactions into digestible topics like “Order Fulfillment” or “Dispute Resolution.”
Automating a loan approval workflow with system triggers Process Diagram (Executable) Supports deployment to a BPM engine with service tasks and data mapping.
Documenting how a supplier and retailer exchange order and delivery confirmations Choreography Diagram Focuses on message order and obligations—perfect for contractual clarity.
When to Use Multiple Diagram Types Together
Don’t treat diagram types as mutually exclusive. In mature modeling practices, they work in concert.
For example, start with a choreography diagram to define the contract between two systems. Then, create a collaboration diagram to show how each party’s internal process aligns with that contract. Finally, build a process diagram for each participant to model their internal logic.
This layered approach ensures alignment. If the choreography says “System A sends confirmation before System B processes,” the process diagrams for both systems must reflect that sequence.
Use a conversation diagram as a top-level map to show the entire communication landscape—ideal for architecture reviews or stakeholder onboarding.
Common Pitfalls to Avoid
Even with the checklist, mistakes happen. Here’s what to watch for:
  • Mixing sequence and message flows: Sequence flows belong inside a pool. Message flows cross pools. Confusing them breaks the model’s integrity.
  • Overloading a single diagram: A process diagram with 20 lanes and 100 elements is unreadable. Break it into collaboration or conversation views.
  • Using choreography for internal process design: Choreography hides internal steps. If you need to model decisions or loops, use a process diagram instead.
  • Choosing the wrong diagram for the audience: Executives don’t need gateways. Developers don’t need conversation nodes. Match the diagram to the reader’s role.
Final Advice: Make This Checklist Part of Your Practice
Every time you start a new modeling session, run through this checklist. It takes under two minutes, but it prevents hours of rework.
Teams that adopt this approach report faster stakeholder alignment, fewer rework cycles, and stronger model governance. It’s not about perfection—it’s about clarity.
And remember: the goal isn’t to use every diagram type. It’s to use the right one, at the right time, for the right person.
Which BPMN diagram should I use for a customer onboarding process?
If you’re modeling the internal steps—like document verification, background checks, and account setup—use a process diagram. If the process involves multiple departments or external partners, add a collaboration diagram to show message flows. For executives, a conversation diagram summarizing “Customer Onboarding” as a single communication topic works best.
Can I use a process diagram to show interactions between two companies?
Not effectively. A process diagram is designed for internal workflows. If two companies are involved, use a collaboration diagram with separate pools. This clearly separates responsibilities and shows message flows between them. A process diagram would incorrectly imply a single owner.
When should I use a choreography diagram instead of a collaboration diagram?
Use a choreography diagram when you want to define a contract or agreement between participants without revealing internal logic. It’s ideal for system-to-system integration, legal contracts, or when the internal processes are unknown or irrelevant. Use a collaboration diagram when you need to show both the internal process and the interactions between participants.
Is a conversation diagram just a simplified collaboration diagram?
Yes—but with a purpose. A conversation diagram is a strategic summary. It groups related message exchanges into conversation nodes (e.g., “Order Confirmation,” “Invoice Dispute”) and removes internal details. It’s not a simplified version of collaboration—it’s a different level of abstraction, designed for high-level communication and governance.
What if I’m not sure which diagram to use?
Start with the audience. Ask: “Who will read this, and what do they need to understand?” If it’s a developer, go process. If it’s a business stakeholder, start with conversation. Then refine based on detail and automation needs. The checklist is your guide—not a gatekeeper.
How do I keep multiple diagrams consistent?
Use a single model repository (like Visual Paradigm) and link diagrams through shared participants, message interfaces, and choreography tasks. Name pools and message flows consistently across views. Use traceability features to link a conversation node to its underlying collaboration or choreography diagram. This ensures that changes in one view are reflected where needed.
