Mistake 17: Drawing Conclusions That Don’t Match the Evidence
At a recent product strategy session, a team concluded, “We must pivot to AI-driven features because that’s the future.” The only evidence? A single mention of “AI” in the Opportunities quadrant. No linkage to strengths, no data on customer demand, no market validation. This kind of leap isn’t insight—it’s speculation dressed as strategy.
Unsupported SWOT conclusions are among the most dangerous failures in strategic thinking. They happen when teams skip verification and assume a logical connection exists between a factor and a decision, even when the evidence doesn’t support it. The result? Wasted effort, misallocated resources, and strategic drift.
My 20 years of guiding teams through SWOT have shown me this pattern repeatable: a weak link in the chain—assumed logic, unstated assumptions, or misapplied connections—turns a matrix into a decision-making trap. In this chapter, I’ll show you how to detect and eliminate these leaps, build a reasoning trail for every conclusion, and ensure your SWOT decisions are not just plausible, but evidence-based.
The Anatomy of an Unsupported Conclusion
Unsupported SWOT conclusions typically follow a predictable pattern: a factor is selected, a decision is made, and no further justification is provided. The assumption is that the connection is self-evident.
Let’s look at a real example I encountered in a healthcare tech startup:
  • Opportunity: “Rising demand for telehealth services.”
  • Conclusion: “We should launch a new AI-powered virtual assistant within three months.”
No mention of whether the company has AI expertise, whether the customer base is comfortable with AI, or whether the development team can deliver such a feature. The conclusion ignores weak spots and jumps straight to an action based on a single external factor.
Why This Happens
Three forces drive unsupported conclusions:
  • Confirmation bias: Teams favor conclusions that align with what they already believe, especially if they’re excited about a new initiative.
  • Time pressure: In fast-moving environments, teams skip verification to “get to action” quickly.
  • Assumed logic: People assume that because two items coexist—say, an opportunity and a product idea—the connection is valid.
These are not bugs—they’re inevitable if you don’t build in verification steps.
How to Test Whether a Conclusion Is Supported
Every conclusion should be challenged with a simple question: “What evidence in the matrix supports this?” If you can’t point to at least one strong link, the conclusion is unsupported.
Here’s a step-by-step method to test your assumptions:
  1. Write the conclusion clearly. Be specific: “We should expand into Asia because of growing consumer interest.”
  2. Identify the supporting factor(s). “Growing consumer interest” is in the Opportunities quadrant.
  3. Check for alignment with strengths. Do we have the local team? Distribution channels? Regulatory experience?
  4. Verify with data. Is there customer research? Market reports? Actual purchase intent data?
  5. Map the chain of reasoning. If any step fails, the conclusion is unsupported.
Here’s how that plays out in practice:
Step Test Result for Expansion into Asia
1. Conclusion Expand into Asia within 12 months
2. Supporting factor Growing demand for digital health in Southeast Asia Yes – in Opportunities
3. Strength alignment Local sales team? Existing partnerships? Regulatory readiness? No – no team, no partners, no compliance history
4. Data support Market report, customer survey, or beta sign-ups? Only one survey with 15 respondents – insufficient
5. Verdict Conclusion not fully supported Do not proceed
When you apply this process, the flaw becomes obvious: the opportunity isn’t matched with capabilities or proof. The decision is based on a hope, not evidence.
Documenting the Reasoning Trail
One of the most effective ways to prevent unsupported conclusions is to require a reasoning trail for every strategic decision.
This means: every conclusion must be accompanied by a short written justification that answers:
  • Which factor(s) in the SWOT matrix support this?
  • What evidence backs that factor?
  • Are there any contradictions or gaps?
  • What assumptions are being made?
Here’s a template you can use:
[Decision]: Launch AI chatbot in Q3
[Supported by]:
  - Opportunity: Rising demand for 24/7 customer support (Source: 2024 customer survey, N=420)
  - Strength: Existing AI infrastructure (Tech lead confirmation, Q2 2024 upgrade)
[Assumptions]:
  - Customer base is open to AI interactions
  - No significant cultural resistance in target markets
[Constraints]:
  - No dedicated UX designer assigned
  - Compliance review pending
[Verdict]: Proceed with caution. Recommend pilot test before full rollout.
This forces transparency. If the reasoning is weak, you’ll see it immediately.
Common SWOT Logic Errors to Watch For
Even experienced teams fall into the same traps. Here are the most frequent SWOT logic errors I’ve observed:
  • Opportunity → Action without capability check: “Customers want mobile access” → “Build a mobile app.” But if no team can build it, you’re already in overreach.
  • Threat → Inaction without mitigation: “Regulation may restrict data access.” Conclusion: “We’ll wait and see.” This isn’t strategy—it’s risk denial.
  • Weakness → Overcorrection: “We have no customer insight.” Conclusion: “Hire 10 new researchers.” No context on budget or timeline.
  • Strength → Unproven market application: “We’re agile.” Conclusion: “We can launch in 6 weeks.” But agility doesn’t mean speed in every context.
Each of these is a leap. Each one undermines credibility.
Practical Steps to Avoid Unsupported Conclusions
Use this checklist during any SWOT follow-up:
  1. Never make a decision without asking: “What in the SWOT supports this?” If you can’t point to at least one item, pause.
  2. Link conclusions to multiple factors. Strong decisions are built on convergence—a match between opportunity and strength, or threat and weakness.
  3. Use the “If… then… because” structure. “If we have AI infrastructure (strength) and customers want faster support (opportunity), then launching a chatbot makes sense.”
  4. Assign reasoning accountability. Have each decision signed off by the person who proposed it, with a note on evidence used.
  5. Review conclusions at the end of the session. Run through the top 3 decisions using the reasoning trail. Challenge each one.
These steps don’t take much time—but they prevent major missteps.
Testing SWOT Assumptions with a Simple Framework
Use this framework to stress-test any assumption:
Assumption Testable Question How to Verify
Customers want AI features Are they willing to pay for them? Check product feedback, survey data, or pilot usage
We can deliver fast Do we have the bandwidth and tools? Review sprint capacity, team size, tech stack
The market is ready Are competitors already succeeding here? Check public benchmarks, case studies, or reviews
Ask it for every major conclusion. If you can’t answer the “how to verify” part, the assumption is not grounded.
How do I know if my conclusion is truly supported by the SWOT matrix?
Ask: “Can I point to at least one factor in the matrix and show how it logically leads to this decision?” If not, the conclusion is unsupported. Dig deeper—what’s missing? A strength? A data point? A risk?
Can a conclusion be valid even if it doesn’t directly link to one factor?
Yes—but only if it’s supported by the convergence of multiple factors. For example: “We should improve customer onboarding” may stem from a weakness (slow setup) and an opportunity (rising demand). When multiple factors align, the conclusion is stronger.
What if the team insists the connection is obvious?
That’s a red flag. “Obvious” is often a shortcut for “unverified.” Use the reasoning trail. If the logic is unclear, ask: “Can you walk me through the evidence step by step?” It forces teams to confront gaps.
Is it okay to make a decision based on a hunch if the evidence is thin?
No—especially in strategy. Hunches are useful for generating ideas, not for final decisions. Use them as hypotheses to test, not justifications to act. Always separate “idea” from “decision.”
How can I encourage teams to document reasoning without adding bureaucracy?
Use a simple template—one paragraph per decision. Assign a single owner to write it. Keep it short, mandatory, and review it as part of the decision log. It becomes a learning tool, not a burden.
What if the evidence contradicts the conclusion?
That’s good. It means the SWOT is working. When evidence contradicts a conclusion, reassess. Maybe the opportunity isn’t there. Maybe the strength isn’t what we thought. Let the data guide you—not your hopes.
