Recap: Building Lasting Design Habits through CRC Practice
Время чтения: 6 мин. 53 просмотров
“I just want to get the code working.” That’s the first sentence I hear most often from developers in their early weeks of design work. It’s honest, and it’s a trap. When design becomes an afterthought, the system grows brittle, tangled, and hard to change. Instead, I’ve learned that the best software starts not with code, but with conversation — with CRC cards.
CRC modeling isn’t about perfection on the first try. It’s about creating a shared language for design. It’s about asking: Who does what? Who talks to whom? When I shift the focus from “what does this code do?” to “what responsibility does this class own?”, I see clarity emerge. That’s where CRC best practices come in — not as rigid rules, but as habits that shape a resilient design culture.
This chapter isn’t about memorizing a checklist. It’s about embedding a design mindset that lasts. You’ll learn how to turn CRC sessions into rituals, how to reflect on what went well and what didn’t, and how to grow your team’s design maturity through continual design improvement. These aren’t abstract theories — they’re the same patterns I’ve seen work across startups, legacy systems, and enterprise teams.
Embedding CRC into Your Design Culture
Design doesn’t happen in isolation. It thrives in teams that talk early, talk often, and talk with purpose. CRC cards are a tool, but their real power lies in how they shape behavior.
Start small. One team, one 30-minute session, one domain concept. That’s where true change begins. Don’t wait for perfect conditions. A whiteboard, sticky notes, or even a digital tool like Visual Paradigm can be enough.
Establish Rituals, Not Tasks
Treat CRC modeling as a ritual — consistent, repeatable, and meaningful. Just like daily standups, make CRC sessions part of your team’s rhythm. Not because someone said so, but because they work.
  • Time it: Keep sessions under 45 minutes. Shorter is better for focus.
  • Assign roles: Rotate facilitator and scribe. This keeps everyone engaged and accountable.
  • Set a clear objective: “Model the checkout flow” or “Validate the user authentication structure.” A clear goal prevents drifting.
  • Review and reflect: After each session, spend 5 minutes asking: What worked? What didn’t? Why?
These rituals grow into habits. And habits become culture. A team that models together, learns together.
Learning from Experience: CRC Lessons Learned
Every team I’ve worked with has repeated the same mistakes — often in different forms. The patterns are familiar, but the recovery is where real growth happens.
These aren’t hypotheticals. I’ve seen them in real workshops, in production systems, and even in code reviews.
Mistake Why It Breaks How to Fix
Overloaded classes with too many responsibilities Breaks cohesion, makes changes risky Ask: “Can this responsibility be split?” Use the Single Responsibility Principle as a filter.
Vague or procedural responsibilities (“Handle payment”) Hard to implement, unclear intent Refactor to action-oriented verbs: “Verify credit card validity” or “Process refund.”
Collaborations without clear purpose Creates spaghetti communication Ask: “Why does this class need to call that one?” If unclear, reconsider the relationship.
These are not failures. They’re feedback. Each misstep is a CRC lesson learned. The goal isn’t to avoid them — it’s to notice them early, learn from them, and evolve.
From CRC Recap to Continuous Design Improvement
At the end of each modeling session, don’t just close the board. Reflect. Ask:
  • Were responsibilities clear and actionable?
  • Did every collaboration serve a defined purpose?
  • Did we uncover a missing class or a redundant one?
  • Was the session focused, or did we drift?
This reflection is your CRC recap. It’s not for documentation. It’s for growth.
I once worked with a team who tracked these reflections in a shared log. After six weeks, they looked back and found that their modeling time had dropped by 40%. Not because they were faster — but because they were smarter. They had learned to avoid repeating the same mistakes.
This is how continual design improvement happens. Not through grand plans, but through small, consistent learning loops.
Practical CRC Best Practices
These habits have stood the test of time — in classrooms, startups, and enterprise systems.
  1. Start with the user story, not the class. Model what the system does, not what it is. Let the behavior guide the structure.
  2. Use active verbs in responsibilities. “Calculate total,” “validate input,” “notify user.” These are concrete, testable actions.
  3. Keep collaboration names minimal and meaningful. “User → OrderProcessor” is clearer than “User interacts with system.”
  4. Update, don’t replace. Don’t discard old CRC cards. Keep them as a history of design evolution.
  5. Pair CRC with code during implementation. Let the card guide the class structure, but don’t treat it as gospel. Adapt as needed.
  6. Encourage disagreement — it’s a sign of engagement. A quiet room means no one is thinking. Healthy debate means the design is alive.
These aren’t rules. They’re guidelines — shaped by real projects, real teams, and real failures.
Final Thoughts: Design Is a Practice, Not a Product
Great design isn’t a destination. It’s a practice. CRC cards help you get there — not by forcing structure, but by encouraging conversation, clarity, and accountability.
Remember: you’re not modeling to please a diagram. You’re modeling to understand. When your team can explain a system’s behavior in simple, shared terms, you’ve won.
Keep your CRC sessions small, your reflections honest, and your habits consistent. Let each session be a step in your journey toward continual design improvement.
And when someone says, “Just get the code working,” remind them: “Yes — but first, let’s make sure we know what ‘working’ actually means.”
How often should I run CRC sessions?
At a minimum, run one per user story or feature. For complex domains, two or three sessions may be needed. The key is consistency — not frequency. Make it a team ritual.
Can CRC cards be used in agile teams?
Absolutely. CRC modeling fits perfectly in agile workflows. Use them during story breakdown, spike sessions, or refactoring sprints. They help teams agree on design before writing code.
What if my team disagrees on responsibilities?
Disagreement is healthy. It means you’re thinking. Use CRC sessions to explore trade-offs. If two people propose different responsibilities, test both against the user story. The one that aligns best with intent wins.
How do I transition from CRC cards to UML class diagrams?
CRC cards naturally map to class diagram elements. Each class becomes a class, each responsibility becomes a method, and each collaboration becomes an association. Use Visual Paradigm to convert and refine.
Do I need digital tools for CRC modeling?
No — physical cards work fine. But digital tools like Visual Paradigm help preserve history, share models, and scale across teams. Use what fits your context.
What if my team resists CRC sessions?
Start small. Run one session with one story. Ask for feedback. Show how it reduced rework or clarified misunderstandings. Let results speak. The habit forms when the benefit becomes visible.
