Responsibility-Driven Design: A Mindset Shift
Время чтения: 7 мин. 52 просмотров
Most developers learn to model systems by focusing on data and structure—what objects exist and how they’re related. But this leads to brittle designs that evolve poorly. The real breakthrough comes not from how you define a class, but from how you define what it *does*. That shift—from structure to behavior—is responsibility-driven design.
It’s not about writing more classes. It’s about assigning work to them with precision. When you think in responsibilities, you begin to see the system as a network of intelligent actors, each with a clear purpose. This mindset doesn’t just improve code quality—it changes how teams collaborate, how decisions are made, and how quickly flaws are spotted.
Over the past two decades, I’ve seen countless teams wrestle with tangled classes that do too much, or miss critical behaviors that later become bugs. The solution rarely lies in a new framework or tool. It lives in a simple change of perspective: design with responsibility first.
This chapter shows you how to make that shift. You’ll learn how to assign responsibilities meaningfully, avoid common overloads, and use CRC cards not just as a tool, but as a way to think. By the end, you’ll understand why RDD isn’t just a technique—it’s a mindset worthy of every project.
What Is Responsibility-Driven Design?
Responsibility-Driven Design (RDD) flips the traditional object modeling paradigm. Instead of asking, “What data does this class hold?” you begin with, “What work should this class be responsible for?”
This subtle shift reorients the entire design process. The goal is to build a system where each class understands its role and performs just one set of related duties—no more, no less.
Let me be clear: RDD doesn’t replace object-oriented principles. It refines them. It’s about applying SRP (Single Responsibility Principle) at the design level, not just in code. When responsibilities are clear, classes become cohesive, testable, and evolve independently.
Core Principles of RDD
Every effective model starts with a few foundational principles. Here are the core tenets I consistently teach:
  • Assign responsibilities to classes, not just data. A class isn’t defined by its attributes—it’s defined by what it does.
  • Use verbs to name responsibilities. “Calculate interest” or “validate user input” are clearer than “process data” or “do something.”
  • Keep responsibilities small and focused. A class should have no more than 3–5 well-defined responsibilities.
  • Collaboration follows responsibility. If one class needs to do something, it doesn’t just call a method—it collaborates with another class to fulfill it.
  • Refactor when responsibilities blur. If a class starts doing two unrelated things, it’s time to split it.
These principles aren’t theoretical. They come from real-world experience—debugging systems where a single class handled user authentication, email sending, log writing, and data export. When one broke, the whole system failed.
How CRC Cards Enable RDD
CRC cards are not just a sketching tool. They are a cognitive scaffold for responsibility-driven thinking. The act of writing a responsibility on a card forces you to phrase it in clear, action-oriented language.
When you see “send confirmation email” on a card, you’re no longer thinking about a class named EmailSender. You’re thinking: Who is responsible for sending this? That question alone stops you from overloading a class.
Let me share a real example: a library system. Early on, a developer put borrowing logic in a “Book” class. It handled checking availability, updating due dates, and notifying overdue users. One small change in the notification logic broke the due date logic. Why? Because the class had too many unrelated responsibilities.
We rewrote the model using CRC cards. Now, “Book” only manages state. “LoanManager” handles due dates and renewals. “NotificationService” sends emails. Each has one clear purpose. The result? A system that’s easier to test, modify, and extend.
Applying CRC Cards for Object Responsibility Modeling
CRC cards help bridge the gap between abstract thinking and concrete design. Here’s how they support object responsibility modeling in practice:
  1. Start with behavior, not structure. Ask: what actions happen in this scenario? “User returns book” leads to: check due date, calculate late fee, update availability.
  2. Assign responsibilities to classes. Assign “check due date” to a “Loan” class. “Calculate late fee” to a “FeeCalculator” class.
  3. Identify collaborations. The “FeeCalculator” needs to know the loan period and rate—so it collaborates with “Loan” and “RatePolicy”.
  4. Review for overlap. If two classes are both calculating fees, one is likely redundant.
  5. Refactor if needed. If a class does five things, split it. Use CRC cards again to reassign responsibilities.
This process isn’t about perfection. It’s about alignment. When the team agrees on who does what, the design becomes a shared understanding—not a document.
Even with CRC cards, it’s easy to fall into traps. Here are the most frequent ones I’ve seen in real projects:
Pitfall Why It Happens How to Fix
Vague responsibilities like “handle data” Lack of clarity about actual behavior Rephrase with a verb: “validate input data” or “store user preferences”
One class handles multiple domains Overloading due to poor separation Split into domain-specific classes: e.g., “PaymentProcessor” and “InvoiceGenerator”
Missing collaborations Focusing only on responsibilities, not interaction After assigning a responsibility, ask: “Who does it need to work with?”
My advice: when in doubt, ask: Is this responsibility truly owned by this class, or is it being passed around? If it’s passed too much, the model is likely too fragmented or too coupled.
Building a Design Culture with RDD
Responsibility-Driven Design is not a one-time activity. It’s a culture. When teams adopt it, they start making decisions differently.
Consider a sprint planning meeting. Instead of assigning tasks like “update the login form,” the team says: “Who is responsible for validating credentials?” That simple shift leads to better ownership, clearer handoffs, and fewer “I thought you’d do it” moments.
RDD principles also help in code reviews. Instead of asking, “Is this well-structured?”, team members now ask: “Does this class have a single, clear responsibility?” It changes the conversation from syntax to intent.
And yes—this mindset works in agile, in legacy systems, even in teams with mixed experience levels. The key is consistency. Use CRC cards early, use them often, and let them guide the conversation.
What’s the difference between object responsibility modeling and traditional class design?
Traditional class design often starts with data: “What properties does this entity have?” Object responsibility modeling starts with behavior: “What work does this class need to perform?” The latter leads to more maintainable, testable designs.
Can I use CRC cards in a remote team environment?
Absolutely. Tools like Visual Paradigm work well. The key is to keep the process interactive: assign roles, have each member write responsibilities, then discuss alignment. The act of writing forces clarity.
How do I know if I’ve assigned responsibilities correctly?
Ask: Is this responsibility small enough to be tested? Is it unique to this class? Is it something this class *must* do, not just something it could do? If the answer is yes, you’re on the right track.
Are CRC cards still useful in modern development with frameworks like Spring or Django?
Yes. Frameworks handle infrastructure, but they don’t decide *what* your classes should do. CRC cards help you answer that. They’re not about coding—they’re about design intent.
How often should we revisit CRC cards during development?
Revisit them during refactoring, after major feature changes, or whenever a class becomes hard to test. They’re not a one-time setup. Think of them as living documents that evolve with the system.
What if team members disagree on responsibilities?
That’s normal—and healthy. Use the CRC card session as a discussion tool. Write down each person’s view, then debate: “Which one supports the system’s goals better?” Disagreement is how you uncover hidden assumptions.
