When to Use CRC Cards in Your Design Process
Время чтения: 7 мин. 58 просмотров
One of the most common mistakes I’ve seen in early design phases is jumping straight into UML diagrams without first understanding the core responsibilities and collaborations. It’s like trying to build a house with blueprints before sketching the layout. The result? Overcomplicated classes, unclear boundaries, and endless rework.
The real power of CRC cards lies not in replacing formal modeling, but in preparing your mind for it. They’re not just a drawing tool — they’re a conversation starter, a thinking aid, and a team alignment mechanism. When used at the right time, they cut through abstraction and help everyone — from junior developers to product owners — speak the same language.
This chapter explains exactly when to use CRC cards in your workflow. You’ll learn how to time them with your project phase, how to avoid common misuse, and how they fit — or don’t fit — with other modeling tools. Most importantly, you’ll see why when you use CRC cards often matters more than the cards themselves.
Best Stages to Use CRC Cards in Your Design Flow
1. During Early Domain Analysis — The Brainstorming Phase
Start with CRC cards when you’re first exploring the problem domain. Before writing code or drawing diagrams, gather the team around a table or digital workspace and ask: “What are the key entities in this system?”
This is where CRC cards shine. They’re lightweight, fast, and encourage active participation. You’re not looking for perfection — you’re looking for ideas.
  • Use CRC cards to identify potential classes from user stories or process workflows.
  • Invite non-technical stakeholders to name classes — they often spot real-world entities you’d miss.
  • Focus on what each class does, not how it does it.
For example, in a library management system, you might start with: Book, Borrower, Librarian, Loan, Due Date. These aren’t final classes — they’re starting points.
2. When Decomposing User Stories or Requirements
Agile teams often face user stories that are too broad: “As a user, I want to manage my profile.” CRC cards help break that down.
Ask: “What classes are involved in managing a profile?” Then draft cards for each. As you assign responsibilities, you’ll naturally reveal hidden entities — like ProfileValidator or NotificationService.
Use this process to:
  • Discover responsibilities that weren’t explicit in the story.
  • Clarify ownership — who decides if a phone number is valid?
  • Identify gaps in the system before coding begins.
3. Before Creating UML Class Diagrams
Many teams jump straight to UML, but that’s like writing a report before outlining the sections. CRC cards are a perfect bridge between idea and diagram.
Once your team agrees on classes, responsibilities, and collaborations, you can convert those into a UML class diagram with confidence. The CRC session ensures you’re not just drawing lines — you’re modeling real intent.
Here’s a simple decision checklist:
Check Use CRC Cards?
Exploring domain concepts without existing models Yes
Breaking down complex user stories Yes
Designing a new module from scratch Yes
Finalizing class structure for documentation No — use UML
Refactoring a legacy system (after analysis) Yes — but later in the process
When NOT to Use CRC Cards
Just because they’re helpful doesn’t mean they’re always appropriate. Here are the situations where CRC cards may slow you down or add no value:
1. In the Final Design Documentation Phase
When you’re preparing final UML diagrams for architecture review or API documentation, CRC cards are too informal. They lack the precision needed for formal documentation.
Use them to inform the class diagram, but don’t hand them in as deliverables. The final output should be a clean, properly formatted UML diagram — not a stack of index cards.
2. For Large, Established Systems
If your team is already working on a mature system with hundreds of classes, running full CRC sessions for every new feature is inefficient.
Instead, use CRC cards for:
  • Small new features
  • Refactoring tricky components
  • Onboarding new team members
For larger changes, rely on more structured tools like UML or component diagrams.
3. When You Already Have a Firm Design
If you’ve already defined the system structure and responsibilities, CRC cards become redundant. They’re not for verification — they’re for discovery.
Don’t use CRC cards as a validation tool after the design is complete. That’s the job of code reviews, tests, and static analysis.
CRC Cards vs UML: Choosing the Right Tool for the Job
Understanding the difference between CRC cards and UML isn’t about which is better — it’s about knowing when to use which.
CRC cards are ideal for early-stage exploration, team collaboration, and rapid prototyping. They emphasize responsibility and conversation. They’re designed for thinking, not documentation.
UML class diagrams are formal, standardized, and precise. They’re used for communication with architects, documentation, and integration with code generation tools. They prioritize structure and relationships.
Think of CRC cards as the first draft of your design. UML as the final manuscript.
Here’s how to decide:
  1. When you’re unsure — use CRC cards.
  2. When you’re ready to formalize — convert to UML.
  3. When you need to share with others — use UML.
  4. When you’re brainstorming with a team — use CRC.
Real-World Use Cases: Where CRC Cards Excel
Let’s look at actual scenarios where CRC cards deliver the most value.
Use Case 1: Onboarding a New Developer
When a new team member joins, it’s easy to hand over code — but much harder to explain the system’s intent. A 30-minute CRC session can map out core classes and their responsibilities.
This isn’t just documentation — it’s shared understanding.
Use Case 2: Agile Sprint Planning
Before sprint planning, run a CRC session on the upcoming user stories. Focus on: “Which classes are involved? What must they do?”
The outcome helps estimate effort, identify risks, and guide story decomposition.
Use Case 3: Design Reviews with Non-Technical Stakeholders
Executives, product managers, or QA leads often struggle with UML diagrams. CRC cards are visual, simple, and language-neutral.
They help explain complex systems without technical jargon — a huge win for clarity and buy-in.
Integrating CRC Cards into Your Workflow
Here’s how to make CRC cards a natural part of your design process.
  1. Start early: Use them during backlog refinement or sprint kickoffs.
  2. Keep them light: Don’t overformat. Use pencil, sticky notes, or a simple app.
  3. Focus on collaboration: Let the team debate, revise, and challenge each other.
  4. Convert to UML when ready: Once responsibilities are clear, draw the class diagram.
  5. Archive them: Store CRC sessions as part of your design history — future developers will thank you.
When should I use CRC cards instead of jumping straight to UML?
Use CRC cards before UML. They help you think through responsibilities and collaborations in a low-pressure, collaborative setting. UML is best used after you’ve established the core design — not as a starting point.
How do CRC cards fit into the agile software design phase?
CRC cards are excellent in agile workflows. They support user story breakdown, sprint planning, and design spikes. Use them to explore new features quickly and align the team before coding.
Are CRC cards still valuable in modern software development?
Absolutely. While tools have evolved, the core challenge — designing systems around responsibilities — hasn’t changed. CRC cards remain one of the best tools for fostering shared understanding, especially in team-based or agile environments.
Can I use CRC cards for non-software modeling?
Yes. CRC thinking applies to any domain requiring role-based collaboration. Business process modeling, UX workflows, and system handoffs between departments all benefit from identifying who does what — just like CRC.
What’s the biggest mistake in CRC card usage?
Trying to use CRC cards for final documentation. They’re not meant to replace UML diagrams. Also, writing vague responsibilities like “handle data” or “manage user info” undermines the whole purpose. Be specific: “validate email format” or “update user status”.
Do I need software tools to use CRC cards?
No — physical index cards work fine. But digital tools like Visual Paradigm can help save, share, and evolve your models. Use what fits your team. The key is thinking collaboratively, not the medium.
