Creating a Simple Project: Modeling a Smart Home Subsystem
When modeling complex systems, clarity begins with a single, well-defined scope. I’ve learned over two decades that the most robust models start not with diagrams, but with a clear understanding of what the system is supposed to do—and what it isn’t. This rule holds whether you’re modeling a spacecraft or a smart home thermostat. In this chapter, we’ll walk through a complete SysML example project: modeling a smart home lighting subsystem. We’ll use real-world constraints and trade-offs to build a model that’s not just accurate, but actionable.
By the end, you’ll know how to combine structure and behavior models in SysML to represent real systems. You’ll use Block Definition Diagrams (BDD), Internal Block Diagrams (IBD), Activity and Sequence Diagrams, and trace requirements—all with the clarity and focus of a seasoned systems engineer. This is not theoretical. This is how I’ve helped teams avoid integration failures by modeling early and modeling right.
Step 1: Define the Scope and System Boundary
Before drawing any diagram, define what the system is. For our smart home subsystem, we’ll focus on the lighting control system—specifically, the automated control of indoor lights based on occupancy, time of day, and manual override.
Key decisions at this stage:
- What’s included? Interior lights, sensors, and control logic.
- What’s excluded? HVAC, security cameras, or external lighting.
- Who are the stakeholders? Homeowner, installer, and future maintenance engineer.
Defining the boundary prevents scope creep and sets the foundation for consistent modeling. This is where many beginner models fail—jumping into diagrams without first asking, “What exactly are we modeling?”
Step 2: Model the Structure with a Block Definition Diagram (BDD)
Start by identifying the main components. In SysML, we use Blocks to represent system elements. Here’s how we break down the smart home lighting system:
- LightingControlSystem – the top-level block.
- Light – the physical device (e.g., LED fixture).
- OccupancySensor – detects movement.
- TimeController – manages daylight/night mode.
- UserInterface – allows manual override via app or switch.
Draw a BDD with these blocks. Use composition to show that the LightingControlSystem contains one or more Light blocks, and association to link sensors and controllers to the system. This structure is your blueprint.
Real-world insight: I’ve seen teams model every light as a separate block. That’s overkill. Instead, model types of lights—e.g., «LivingRoomLight» or «HallwayLight»—and use multiplicity to show how many exist per zone.
Step 3: Detail Internal Architecture with an Internal Block Diagram (IBD)
The IBD reveals how components connect. Let’s say the LightingControlSystem has ports:
- in port: receives signals from OccupancySensor and TimeController.
- out port: sends commands to the Light blocks.
Draw the IBD. Show the internal connectors between the ports and the component blocks. For example:
- OccupancySensor → LightingControlSystem (in port)
- TimeController → LightingControlSystem (in port)
- LightingControlSystem → Light (out port)
Use ports and parts to make the flow explicit. This is where SysML shines: you’re not just showing *what* is connected—you show *how* data and control flow between components.
Pro tip: Use internal links to connect internal parts. This avoids clutter and keeps the diagram readable. A well-structured IBD tells a story: “Signal comes in. Decision is made. Light turns on.”
Step 4: Model Behavior with Activity and Sequence Diagrams
Activity Diagram: Light Control Logic
Now model the workflow. The core behavior is: “If someone enters the room and it’s dark, turn on the light.”
Use an activity diagram with:
- Initial Node: Start when a sensor detects motion.
- Decision Node: Is it daytime? If yes, do nothing. If no, continue.
- Action: Turn on the light.
- Final Node: Light is now on.
Include object flows to show the sensor reading, time of day check, and control signal. This is a clear, executable logic path.
Sequence Diagram: Interaction Between Components
To model timing and interaction, use a sequence diagram. The scenario: “User turns on the light manually.”
Draw the lifelines: UserInterface, LightingControlSystem, and Light.
Sequence of messages:
- UserInterface → LightingControlSystem: “Turn on light”
- LightingControlSystem → Light: “Power on”
- Light → LightingControlSystem: “On”
- LightingControlSystem → UserInterface: “Light is on”
Use alt or opt fragments to model conditional behavior. For example, if the system is already on, no action is needed.
This diagram clarifies responsibility and timing—critical for software and embedded systems developers.
Step 5: Connect Requirements and Traceability
A model is only as good as its requirements. Define key requirements and link them to design elements.
Example requirements:
- R1: The system shall turn on lights when motion is detected after sunset.
- R2: The system shall allow manual override via a mobile app.
- R3: The system shall not turn on lights during daytime unless manually activated.
Use a requirements diagram to show these. Then, use allocation to link:
- R1 → Activity Diagram: “Check time and occupancy”
- R2 → Sequence Diagram: “Manual turn-on”
- R3 → TimeController block
Allocation is the backbone of MBSE. It ensures that every requirement is implemented, verified, and traceable across the lifecycle.
Traceability Matrix
| Requirement ID | Description | Linked Model Element | Verification Method |
| R1 | Auto-on after sunset | Activity Diagram, TimeController | Simulation |
| R2 | Manual override | Sequence Diagram, UserInterface | Test case |
| R3 | No auto-on in daylight | TimeController, Condition check | Test case |
This matrix ensures no requirement is lost in translation. You can’t verify what you can’t link.
Step 6: Validate and Refine the Model
After building the model, validate it by asking:
- Does every requirement have a design trace?
- Do all behavior diagrams align with the structure?
- Can the system be simulated or tested from the model?
Use tool features (like Visual Paradigm’s model validation engine) to find inconsistencies—e.g., a block with no internal parts, or a requirement with no allocation.
Refine iteratively. The first version will never be perfect. That’s okay. The goal is not to get it right the first time—but to get it right *before* deployment.
What’s the difference between a SysML modeling example and a real-world system?
A SysML modeling example like this smart home project is a simplified version of a real system. It focuses on core principles: structure, behavior, and traceability. In practice, the model may include more components (like power supplies, communication protocols), safety requirements, and environmental conditions. But the design pattern remains the same.
Can I use SysML for software-only systems?
Absolutely. SysML is ideal for software-integrated systems. You can model software components as Blocks, define their interactions with sequence and activity diagrams, and trace requirements. This is how I’ve helped teams model embedded firmware and IoT applications.
How do I avoid over-modeling in SysML?
Start simple. Model only what’s necessary. Use composition only when needed. Avoid creating a block for every instance. Ask: “Is this detail needed for design, verification, or stakeholder communication?” If not, cut it.
Why should I use both BDD and IBD instead of just one?
BDD defines the system’s high-level components and relationships. IBD shows how those components are connected internally. Together, they give a complete picture: “What is in the system?” and “How do they connect?”
How do I know if my SysML model is correct?
Correctness isn’t just syntax. A model is correct if: it matches requirements, all diagrams are consistent, and it can be used to generate test cases or drive a simulation. Use checklists and validation tools to verify.
Can I export this model to generate documentation?
Yes. Tools like Visual Paradigm allow you to export diagrams and requirements into professional reports (PDF, Word). Use this to communicate with non-technical stakeholders or for compliance documentation.
