Step-by-Step: Constructing Your First Fishbone Diagram
Geschätzte Lektüre: 5 Minuten 48 Ansichten
Every great fix starts with a clear understanding of what’s really broken.
When I’m asked how to make a fishbone diagram, I don’t start with tools — I start with the problem. The real power lies in organizing thinking, not just drawing lines.
This chapter walks you through building your first Ishikawa diagram with purpose, clarity, and practical insight. You’ll learn how to structure the problem, define categories, and turn group brainstorming into actionable insights.
You’ll walk away not just with a diagram, but with a method — one that turns vague frustration into measurable, fixable causes.
Step 1: Define the Problem — The Head of Your Diagram
Before drawing a single line, you must define the problem clearly and objectively.
A vague problem like “Our software is slow” leads to unactionable causes. A well-crafted problem statement such as “User login takes longer than 10 seconds in 30% of cases during peak hours” gives you a clear target.
Use this format: “The [effect] occurs because of [specific, measurable issue].” Be precise. Avoid blame. Focus on observable and measurable outcomes.
Key tip: Avoid symptoms, target actual performance gaps
Ask: “Is this statement describing a symptom or a root issue?” If it’s a symptom (e.g., “customers complain”), rephrase it to focus on the measurable behavior.
Example:
  • Weak: “Customers are unhappy with the delivery time.”
  • Strong: “Delivery time exceeds 72 hours for 15% of orders in the Midwest region.”
Step 2: Draw the Spine and Main Categories
The backbone is the spine. The main categories — usually 4 to 6 — are the bones. These are your framework for structured thinking.
I recommend starting with the traditional 6M categories:
  • Machine
  • Manpower
  • Method
  • Measurement
  • Materials
  • Environment
These cover most operational environments. For software or service teams, you might adjust:
  • People → Team Structure
  • Method → Process Design
  • Measurement → KPIs & Monitoring
  • Environment → Deployment Environment
Select your categories based on context
Don’t force the 6M. If you’re analyzing a customer service failure, “Environment” might become “Customer Context” or “Support Channels.” Flexibility keeps the diagram relevant.
Use a digital tool like Visual Paradigm to sketch the skeleton quickly. The goal is clarity, not aesthetics.
Step 3: Brainstorm Causes under Each Category
Now comes the heart of the process: turning group thinking into structured causes.
Use a facilitation method like silent brainstorming or the Nominal Group Technique to avoid dominant voices. Give everyone 10 minutes to write down causes under each category—no discussion, no judgment.
Afterward, collect and cluster similar ideas. Avoid repeating the same cause under multiple categories. That’s a sign of confusion, not insight.
Ask “Why?” to dig deeper
When a cause is listed — say, “Server downtime” — ask: “Why does this happen?” Then ask again. Keep going until you reach a root-level trigger, like “Auto-scaling failed due to misconfigured load balancer rules.”
Not every branch needs five layers. Some may stop at two. That’s okay. Depth depends on relevance, not quantity.
Step 4: Prioritize and Validate Causes
Not all causes are equally likely or impactful. After completing the diagram, it’s time to separate noise from signal.
Use a simple scoring system:
Criteria Score (1–5)
Frequency of occurrence 1–5
Impact on problem 1–5
Ease of verification 1–5
Total Max 15
Rank the top three causes by score. These become your focus for deeper investigation.
Remember: A fishbone isn’t a final report. It’s a hypothesis generator.
Step 5: Link to Data and Take Action
Without data, the fishbone is just a map of assumptions. Connect each high-priority cause to a metric.
For example:
  • Cause: “Database queries timeout under load”
  • Data: 68% of timeouts occurred between 8–10 AM, coinciding with peak login activity
  • Action: Optimize query indexes and implement caching for high-frequency requests
This transforms the diagram from a brainstorming aid into a project launchpad.
Use the diagram in your post-mortem report, improvement board, or agile retrospective. It’s not just a visual — it’s evidence.
How do I start a fishbone diagram when I don’t know the problem?
Start with observable data. If a metric is off, build the problem statement around that. “Customer support tickets increased by 40% last week” is a better starting point than “We’re having issues.” Never assume — measure first.
Can I use a fishbone diagram for non-technical problems like customer complaints?
Absolutely. The structure works for service failures, employee turnover, or even UX frustrations. Just adapt the categories — “Customer Process,” “Staff Training,” “Feedback Mechanism” — to fit your context.
What if my team keeps listing the same cause under multiple categories?
That’s a red flag. Reassess: is this cause truly distinct? If “poor communication” appears under both “People” and “Process,” ask: “Is the root issue a lack of training, or a flawed handoff procedure?” Consolidate under the true source.
How many causes should I list on each branch?
There’s no fixed number. 3–7 per branch is typical. Focus on quality, not quantity. If you’re at 10 and they’re all vague (“management issues”), dig deeper. Ask “What kind of management issue?” to uncover specifics.
Is there a difference between a fishbone diagram and a root cause analysis process?
Yes. A fishbone diagram is a *tool* used within the broader root cause analysis process. The full RCA process includes problem definition, data collection, cause identification (where fishbone helps), validation, and solution implementation. The diagram is one step — but a critical one.
Should I use digital tools or sketch by hand?
Use digital tools for collaboration, version control, and sharing. But sketching by hand builds mental engagement and encourages deeper thinking. Use both: hand-draw during planning, then digitize for documentation and reporting.
