Handling Decisions and Loops in Activities
Geschätzte Lektüre: 8 Minuten 128 Ansichten
When you can trace a workflow from start to finish—especially one involving choices or repetition—you’re already thinking like a systems designer. That clarity starts with mastering how decisions and loops appear in activity diagrams. These aren’t just visual flourishes; they’re the backbone of modeling real-world logic in software.
As someone who’s guided dozens of teams through their first enterprise-grade process models, I’ve seen how misusing decision nodes or poorly structured loops lead to confusion, rework, and missed edge cases. The good news? With a few core principles, you can draw decisions that are both accurate and readable from day one.
This chapter walks you through the essential components: decision nodes, guards, merge nodes, and loop constructs. You’ll learn how to structure branching in activity UML so that every path is intentional, and every loop is bounded and understandable. You’ll also avoid common pitfalls that trip up beginners and even experienced modelers.
Understanding Decision Nodes in UML Activity
Decision nodes are the gatekeepers of logic in activity diagrams. Think of them as traffic lights for your process—one incoming flow splits into multiple outgoing paths based on conditions.
Every decision node has a single incoming control flow, but two or more outgoing flows. Each outgoing path must be labeled with a guard condition, which is a boolean expression that determines whether that path is taken.
Here’s a simple example: a login process may decide whether to allow access based on username and password. The decision node is the point where the system checks if the credentials match.
Always use a small diamond shape to represent a decision node. Use clear, concise conditions—never vague phrases like “if valid.” Instead, write: username != null AND password.length >= 6.
Key Rules for Decision Nodes
  • Only one incoming control flow is allowed.
  • Outgoing flows must be labeled with guard conditions in square brackets: [condition].
  • Guards should be mutually exclusive and collectively exhaustive (MECE) where possible.
  • Use the same condition language across all paths to avoid confusion.
When you’re drawing a decision node, ask: “Does every possible outcome have a path?” If not, your model is incomplete.
Mastering Guards: The Logic Behind Branching
Guards are the engine that powers decision-making. They define the exact conditions under which a path is followed.
Let’s say you’re modeling a customer support workflow. After a ticket is submitted, the system checks its priority. The decision node would have three outgoing flows:
  • [priority == "High"] → Assign to senior agent
  • [priority == "Medium"] → Assign to regular agent
  • [priority == "Low"] → Queue for later
Notice the use of equality checks. These are preferred over phrases like “if high priority.” The formal syntax ensures that the model is both executable and verifiable.
Guards can include variables, operators, and even simple method calls. But keep them as simple as possible. Avoid complex expressions like isUserActive() AND (hasSupportPlan OR isPremiumUser)—break them down if they cause clutter.
Best Practice: Use Guard Expressions Wisely
Here’s a comparison of good vs. bad guard usage:
Good Guard Poor Guard
[age >= 18] [user is adult]
[status == "Pending"] AND [timeout < 24] [waiting for approval]
[items.count > 0] [has items]
The first column uses unambiguous expressions. The second relies on interpretation, which can lead to ambiguity during reviews.
Handling Loops in Activity Diagrams
Loops in activity diagrams model repeated actions—especially useful for processing lists, files, or batches.
There are two primary types: while loops and for loops. In UML, these are typically represented using a loop node with a condition and a repetition body.
For example, processing a list of order items:
  1. Start
  2. Set index = 0
  3. Decision: Is index < list.size()?
  4. If yes: Process item at index, increment index, loop back
  5. If no: End
Use the loop node structure to keep repetition clear. It contains a condition (e.g., index < list.size()) and a body that runs repeatedly.
When to Use Loop Nodes
  • When processing arrays, lists, or streams.
  • When the number of iterations is not predetermined but depends on data.
  • When modeling batch jobs (e.g., processing daily logs).
Never use loops for simple sequential steps. That’s what control flows are for.
Using Merge Nodes to Rejoin Flows
After branching, you’ll often need to rejoin flows. That’s where merge nodes come in.
A merge node accepts multiple incoming control flows and produces one outgoing flow. It’s essentially the opposite of a decision node.
For example: a user can be either a guest or a registered user. Both paths lead to a “show dashboard” action. The merge node ensures the process continues regardless of the path taken.
Use merge nodes to avoid creating multiple end points. They’re especially helpful when you want to combine multiple success paths after a decision.
When to Use Merge Nodes
  • After a decision with multiple paths that all lead to the same next action.
  • To unify flows that were split by a fork (parallelism).
  • To simplify complex diagrams with redundant endpoints.
Always ensure the incoming flows are logically compatible. If one path ends in an error and another in success, merging them prematurely can mislead.
Practical Tips for Clear Branching in Activity UML
Here are real-world techniques I’ve used with teams to keep activity diagrams readable and maintainable:
  1. Group related decisions: Avoid placing decision nodes too far apart. If you have multiple decisions in a row, consider grouping them into a single decision block.
  2. Label guards consistently: Use the same variable names and operators across all guards. Avoid mixing “age > 18” with “age >= 18”.
  3. Limit decisions per page: If your diagram has more than 3 decision nodes, consider breaking it into sub-processes.
  4. Use swimlanes for ownership: Assign decision points to specific roles or departments to clarify responsibility.
  5. Test with real data: Walk through your diagram using sample inputs. Does it behave as expected? This is the fastest way to catch logic errors.
Common Pitfalls to Avoid
Even experienced modelers make these mistakes. Avoid them early to save time later.
  • Missing guards: All outgoing flows from a decision node must have a guard. Omitting one leads to ambiguity.
  • Overusing nested decisions: Deep nesting (e.g., decision → decision → decision) makes diagrams hard to read. Refactor into separate diagrams or use subroutines.
  • Unreachable paths: A guard like [false] creates a dead end. Always validate that each path can be reached.
  • Confusing merge with decision: Remember: decision splits; merge joins. Don’t swap them by accident.
  • Loop without exit: A while loop must have a condition that eventually becomes false. Otherwise, you create an infinite loop.
Real Example: Modeling a User Registration Process
Let’s walk through a simple but realistic example: a user registration system.
  1. Start
  2. Enter email and password
  3. Decision: Is email valid? → [email.matches(/^[^\s@]+@[^\s@]+\.[^\s@]+$/)]
    • Yes → Continue
    • No → Show error, loop back
  4. Decision: Is password strong? → [password.length >= 8 AND containsLetter AND containsDigit]
    • Yes → Continue
  5. Decision: Is email already registered? → [!isRegistered(email)]
    • Yes → Show error, loop back
    • No → Create user
  6. Send welcome email
  7. End
This example uses decision nodes, guards, loops, and merge-like behavior (via multiple paths leading to the same action). Notice how each step is testable and unambiguous.
What is a decision node in UML activity?
A decision node is a diamond-shaped symbol that splits a single incoming control flow into multiple outgoing flows based on condition checks. Each outgoing path must be labeled with a guard condition.
Can I have multiple decision nodes in one activity diagram?
Absolutely. But keep the number manageable. More than three in a row may suggest the need for sub-processes or a refactored design.
How do I represent a while loop in an activity diagram?
Use a loop node with a condition and a body. The flow starts inside the loop, checks the condition at the end, and loops back if true. Use the loop construct to make repetition explicit and bounded.
Why use merge nodes instead of just connecting flows?
Merge nodes ensure that multiple flows can converge without ambiguity. They prevent accidental creation of multiple end points and clarify that all paths lead to the same next step.
What’s the difference between a decision and a merge node?
Decision nodes split a flow into multiple paths based on conditions. Merge nodes join multiple incoming flows into one outgoing flow. They are complementary: decision → merge → next action.
Can I use activity diagrams for business process modeling?
Yes. Activity diagrams are excellent for modeling business workflows—especially when they involve decisions, loops, and responsibilities. They’re widely used in BPMN and enterprise process documentation.
