Running a 90-Day OKR Pilot
Temps estimé :2 minutes 243 vues
You’ve aligned your vision, defined your objectives, and set meaningful key results. But how do you turn that clarity into daily action? Too often, teams struggle not with strategy—but with execution. This section is designed for teams ready to move from planning to practice. You’ll find a step-by-step 90-day rollout plan that help you avoid common pitfalls and build sustainable momentum.
Over the next few chapters, you’ll get what I’ve used with dozens of growing organizations: frameworks that work, templates that adapt, and playbooks that guide your team through the first critical steps. No fluff. Just what you need to implement OKRs with confidence.
Here’s a clear roadmap of what you’ll learn and how it applies to your team’s success:
  • Run Your First 90-Day OKR Pilot: A Step-by-Step Playbook – Follow a structured, realistic plan to launch OKRs in your team, complete with setup, sprint cycles, and review checkpoints.
  • Measuring the ROI of OKR Implementation – Learn how to quantify the real business impact of your OKRs by comparing performance metrics before and after adoption.
  • Sustaining Momentum: How to Keep OKRs Fresh Over Time – Avoid stagnation with strategies for refreshing goals, maintaining engagement, and embedding OKRs into your team’s rhythm.
By the End, You Should Be Able to
  • Run a realistic 90-day OKR pilot with clear milestones and team accountability.
  • Measure and report on the real business value delivered by your OKR initiative.
  • Keep your team engaged through regular reviews, feedback loops, and goal refresh cycles.
  • Integrate OKR practices into your team’s routine without adding overhead.
Let’s turn vision into action.
Retour en haut
