Common Misuses of SWOT (and How to Fix Them)
Temps estimé :7 minutes 61 vues
In a recent workshop with a mid-sized retail chain, the team spent two hours listing over 80 items across their SWOT matrix—only to realize they hadn’t prioritized a single factor. The analysis was exhaustive, but directionless. This isn’t an isolated case. I’ve seen the same pattern repeat across industries: teams rush to fill a template without asking the right questions.
SWOT analysis mistakes often stem from treating the framework as a checklist, not a strategic filter. When done poorly, it becomes a data dump with no actionable insight. Worse, it can create false confidence: “We’ve done our SWOT,” they say, as if the work is complete.
But the real work begins after the matrix is filled. The goal isn’t to list strengths and opportunities—it’s to connect them into meaningful strategy. This chapter reveals the most frequent SWOT pitfalls and how to fix them with practical, field-tested approaches.
Why SWOT Breaks Down: The Root of the Problem
SWOT analysis is not a strategy. It’s a diagnostic tool. When misused, it becomes a trap for teams that mistake data collection for decision-making. The most common SWOT pitfalls stem from poor focus, lack of alignment, and weak follow-through.
Here’s what I’ve observed in over 200 strategic planning sessions: teams list everything they can think of, often without clarifying whether a point is truly a strength, an opportunity, a threat, or a weakness.
One team described “having a good culture” as a strength. But culture isn’t a strength—it’s an outcome. What they really meant was “team cohesion,” which might be a strength only if it directly improves performance.
Key SWOT Pitfalls to Avoid
  • Overloading the matrix: More than 10–12 items per category creates analysis paralysis.
  • Using vague or unverifiable statements: “Our brand is strong” is not actionable. “Our brand ranks top 3 in customer trust surveys” is.
  • Ignoring strategic alignment: Strengths don’t automatically translate to strategy. They must be linked to opportunities or threats.
  • Failing to connect SWOT to real decisions: The analysis becomes a wall decoration with no impact on planning or execution.
How to Improve SWOT Analysis: A Four-Step Fix
Fixing SWOT isn’t about changing the model. It’s about changing how you use it. Here’s a field-tested approach I use with clients to turn a weak SWOT into a strategic engine.
Step 1: Apply the 80/20 Rule to Your Inputs
Not every strength or opportunity deserves a spot in the final analysis. Use the 80/20 rule: only include factors that have a measurable impact on performance or strategy.
Ask: “If this factor didn’t exist, would it change our direction?” If not, remove it. This filters noise and sharpens focus.
Step 2: Use the “So What?” Test
For each item, ask: “So what? What does this mean for our strategy?” If you can’t answer in one sentence, it’s not strategic.
Instead of “We have a strong R&D team,” ask: “So what? Our R&D output leads to 50% faster product launches, giving us a competitive edge in niche markets.”
Step 3: Move Beyond Description to Diagnosis
Don’t stop at listing factors. Diagnose their impact. Ask: Is this strength sustainable? Is this opportunity temporary or structural? Is this threat internal or external?
For example, “rising fuel costs” is a threat—but is it an industry-wide trend or a logistics inefficiency? The answer shapes your response.
Step 4: Connect to Strategy Before You Build the TOWS Matrix
Many teams jump straight to TOWS without checking whether the SWOT inputs are fit for purpose. The best SWOT analysis leads to specific strategic questions:
  • Can we leverage this strength to capture this opportunity?
  • How can we neutralize this threat using our weaknesses?
  • Can we turn a weakness into a competitive advantage by targeting this opportunity?
These questions set the stage for meaningful TOWS pairings.
Real Examples: From Mistake to Insight
Let’s look at two real-world examples where SWOT was misused—and how it was fixed.
Case 1: Overloaded SWOT in a Tech Startup
A SaaS startup listed 30 strengths, including “we have good people,” “our team is agile,” and “we believe in innovation.” These were all true—but not strategic.
After applying the “So What?” test, we distilled down to four key strengths:
  • Development cycle under 2 weeks
  • 24/7 customer support with 95% first-response rate
  • 15% lower churn than industry average
  • One of the top 10 most used APIs in the sector
Now, these were actionable. They led to a clear strategy: “Leverage our development speed and API adoption to enter adjacent verticals.”
Case 2: Misclassified Threats in a Manufacturing Firm
A manufacturer listed “increased raw material costs” as a threat. But upon deeper analysis, it was not a macro threat—it was a result of outdated supplier contracts.
Reframing it as a “weakness in procurement negotiation” allowed the team to shift from reactive panic to proactive improvement: “Renegotiate long-term contracts with key suppliers.”
SWOT Pitfalls vs. How to Fix Them: Quick Reference
SWOT Pitfall Why It Fails Fix: How to Improve SWOT Analysis
Too many items in each category Overwhelms decision-making and dilutes focus Limit to 6–8 items per quadrant. Use the 80/20 rule.
Vague or unmeasurable language Not actionable; no clear path to execution Use metrics: “We are #3 in customer satisfaction (NPS 52)”
Not connecting to strategy Analysis becomes a one-off report Ask: “So what?” for every item. Link to strategic goals.
Misclassifying internal/external factors Breaks logical structure of TOWS Use external = beyond control; internal = within control
When SWOT Isn’t Enough: The Transition to TOWS
SWOT analysis mistakes often reveal a deeper issue: teams need more than a list. They need a decision-making framework.
The TOWS matrix is not just a visual upgrade—it’s a strategic filter. It forces you to ask: “How can my strength help me respond to this opportunity?” or “How can I turn this weakness into a shield against this threat?”
But you can’t build a solid TOWS matrix on a weak SWOT. That’s why this chapter isn’t just about fixing SWOT. It’s about laying the foundation for real strategy.
How do I know if my SWOT analysis is too long?
If you have more than 10 items in any category, you’re likely including non-strategic inputs. Apply the 80/20 rule and the “So what?” test. Keep only items that directly impact strategy, performance, or decision-making.
Can I use SWOT if I don’t have data?
SWOT can be based on qualitative insights, but avoid vague statements like “we’re good.” Instead, use observable indicators: “We’ve launched 5 new features in the past 6 months” or “We’ve received 3 client awards in the last year.” These are measurable and more credible.
What’s the difference between SWOT and TOWS?
SWOT identifies factors. TOWS connects them into actionable strategies. SWOT asks “What is?” TOWS asks “What can we do about it?”
How often should I revisit my SWOT analysis?
Revisit every 6–12 months, or when there’s a major shift—new competitor, regulatory change, product launch. Treat SWOT as a living document, not a one-time event.
Is it okay to have no strengths in a SWOT?
Yes, but be honest. If you have no strengths, ask: “What’s holding us back?” Then focus on addressing weaknesses before pursuing opportunities.
Can I use SWOT for personal career planning?
Absolutely. Identify your professional strengths, weaknesses, opportunities (e.g., upskilling, promotions), and threats (e.g., automation, competition). Use it to guide skill development, job transitions, or negotiation goals.
