Step-by-Step Matrix Construction: From SWOT to Strategy Table
Temps estimé :7 minutes 43 vues
Imagine a retail chain facing declining foot traffic and rising competition. Leadership runs a SWOT analysis but struggles to turn insights into actionable plans. The issue isn’t the data—it’s the method. Many teams stop at listing factors instead of connecting them. That’s where the TOWS matrix becomes essential. It transforms isolated observations into strategic options by forcing purposeful relationships between internal strengths and external opportunities.
Over two decades, I’ve guided hundreds of teams through this exact challenge. The real breakthrough isn’t in collecting data—it’s in how you link it. The TOWS matrix isn’t just a diagram. It’s a decision engine built on logic, not guesswork. When executed with care, it turns SWOT results into four distinct strategic pathways.
This guide walks you through the exact steps I use in consulting engagements. You’ll learn how to organize SWOT elements, identify meaningful pairings, and document strategies that are both realistic and impactful. You’ll also avoid common pitfalls that derail even well-intentioned efforts.
Step 1: Prepare Your SWOT Analysis
Before building a TOWS matrix, ensure your SWOT analysis is complete and focused. This is not a brainstorming session. It’s a precision exercise.
Review your SWOT list and ask: Is each item specific, measurable, and relevant? Vague entries like “good leadership” or “market growth” weaken the entire process. Replace them with “strong executive team with 70% retention” or “market growing at 5% annually.”
Here’s a checklist to verify readiness:
  • Each item in Strengths and Weaknesses is internal and controllable.
  • Each item in Opportunities and Threats is external and beyond immediate control.
  • No more than 5–6 items per quadrant to avoid overload.
  • All items are concise—ideally one short sentence or phrase.
Once verified, you’re ready to map them into the TOWS matrix structure.
Step 2: Set Up the TOWS Matrix Structure
Draw a 2×2 grid. Label the quadrants as follows:
External Environment
Internal Opportunities (O) Threats (T)
Strengths (S) SO Strategies ST Strategies
Weaknesses (W) WO Strategies WT Strategies
Each cell represents a strategic pairing. The goal is to create actionable options by combining internal factors with external conditions.
Step 3: Generate SO Strategies (Strengths + Opportunities)
These are your growth and expansion paths. They rely on your internal strengths to capitalize on external opportunities.
Ask: “How can our strengths be leveraged to pursue this opportunity?”
For example, if your company has a strong R&D team (Strength) and there’s growing demand for sustainable products (Opportunity), a possible SO strategy is: “Expand product line with eco-friendly offerings and launch a targeted marketing campaign in high-growth regions.”
Use this framework:
  1. Identify the key strength.
  2. Link it to a relevant opportunity.
  3. Construct a clear, outcome-focused action.
  4. Ensure it’s measurable and time-bound.
Focus on high-impact opportunities. Not every opportunity justifies a strategy—only those where internal strengths create a clear competitive edge.
Step 4: Generate ST Strategies (Strengths + Threats)
This quadrant is about protection. Your strengths should be used to counter external threats.
Ask: “How can our strengths help us avoid or mitigate this threat?”
Example: A manufacturing company with a rigid but efficient production line (Strength) faces rising automation in its sector (Threat). A viable ST strategy: “Invest in automation upgrades to maintain cost leadership while preserving production stability.”
Key considerations:
  • Don’t just react—anticipate.
  • Use strengths to buffer risks.
  • Consider both defensive and offensive actions.
These strategies often require capital investment but protect long-term viability.
Step 5: Generate WO Strategies (Weaknesses + Opportunities)
These are improvement and growth strategies. They target weaknesses to exploit opportunities.
Ask: “How can we fix this weakness to pursue this opportunity?”
Example: A startup lacks brand recognition (Weakness) but identifies a niche market with low competition (Opportunity). A WO strategy: “Partner with industry influencers to build credibility and launch a digital-first marketing campaign.”
Why it works: It uses an external opportunity to drive internal capability development. This is where growth begins for under-resourced teams.
Pro tip: Ensure the chosen opportunity is large enough to justify the effort of improving the weakness.
Step 6: Generate WT Strategies (Weaknesses + Threats)
These are defensive or survival strategies. They address internal weaknesses before they’re exposed by external threats.
Ask: “How can we protect ourselves from this threat by fixing our weakness?”
Example: A small e-commerce brand has outdated cybersecurity systems (Weakness) and the threat of rising data breaches (Threat). A WT strategy: “Outsource IT security to a certified firm and implement mandatory employee training within 90 days.”
These strategies are often urgent and resource-intensive. They signal where risk mitigation is critical.
Remember: Not all WT strategies need to be large-scale. Sometimes, a small change—like updating software patches—can prevent a major failure.
Step 7: Refine and Prioritize Your Strategies
Now that you have 12–20 strategy options, apply a simple filtering process:
  1. Feasibility: Can the team execute this with current resources?
  2. Impact: Will it significantly affect performance or market position?
  3. Alignment: Does it support your organization’s mission and long-term goals?
  4. Timeline: Is it achievable within 6–18 months?
Discard options that fail three or more criteria. Keep the rest for further evaluation.
For deeper prioritization, use a weighted scoring model:
Strategy Feasibility (1-5) Impact (1-5) Alignment (1-5) Score (Total)
Expand eco-friendly product line 4 5 5 14
Partner with influencers 5 4 4 13
Outsource cybersecurity 4 5 5 14
Use this to rank your top 3–5 strategies and build an implementation plan.
Best Practices for Building TOWS Matrix
  • Limit inputs per quadrant: No more than 5–6 items. Overloading kills focus.
  • Use action verbs: Start each strategy with “Launch,” “Invest,” “Partner,” “Improve.”
  • Involve cross-functional teams: Sales, operations, and finance perspectives reveal blind spots.
  • Review for logic: Ask: “Does this strategy actually connect the internal and external factors?”
  • Document assumptions: Especially for future-proofing, such as “If market growth continues at 5%…”
Common Mistakes to Avoid
  • Listing ideas without pairing: “We have a strong team” and “Market is growing” are not a strategy—yet.
  • Mixing internal and external: A “strong brand” is internal; “growing demand” is external. Keep them separate.
  • Creating vague strategies: “Improve leadership” is not actionable. “Implement quarterly leadership workshops” is.
  • Ignoring the WT quadrant: Defensive strategies are often overlooked but critical for sustainability.
How do I start building TOWS matrix from scratch?
Begin by completing a focused SWOT analysis with no more than five items per quadrant. Use a 2×2 grid labeled SO, ST, WO, WT. For each cell, combine a strength or weakness with an opportunity or threat. Ask, “How can we use this to achieve a goal?” Then write a clear, action-oriented strategy.
Can I use TOWS matrix for personal career planning?
Absolutely. Apply internal strengths (e.g., strong communication) and weaknesses (e.g., limited public speaking) to external opportunities (e.g., promotion to team lead) and threats (e.g., rising competition). Strategies like “enroll in a leadership course” or “volunteer for high-visibility projects” can emerge from this process.
Is TOWS matrix suitable for startups?
Yes. Startups often face high uncertainty. TOWS helps them identify which strengths to leverage and which weaknesses to fix before competitors do. It’s especially useful for early-stage pivoting and investor presentations.
How long does it take to create a TOWS matrix?
With a ready SWOT, a focused team can complete the matrix in 60–90 minutes. Refining and prioritizing strategies adds another 30–60 minutes. The time investment is justified by the clarity gained.
What’s the difference between SWOT and TOWS?
SWOT identifies factors. TOWS turns them into strategy. SWOT is descriptive. TOWS is prescriptive. TOWS forces you to ask, “What should we do?”—not just “What do we have?”
