Mixing Technical Tasks with User Stories
Estimated reading: 8 minutes 60 views
Too many teams conflate engineering work with user-facing outcomes, treating technical chores as if they’re stories. This blurs the line between what delivers value and what keeps the system running. I’ve seen teams spend sprints building logging frameworks, API wrappers, or database migrations—all labeled as “user stories” because they were “part of the work.” But that’s not how Agile works.
Stories are not technical tasks. They are placeholders for conversation. They exist to capture a user’s need, a business outcome, or a meaningful interaction. Technical tasks, on the other hand, are internal, non-interactive, and exist to support the delivery of value—not to be the value itself.
This chapter isn’t about making technical work invisible. It’s about making it visible in the right place. You’ll learn to recognize when a task is being disguised as a story, how to reframe it properly, and where to track it without undermining the product backlog’s focus on user value.
What Is a Real User Story?
It Must Deliver Value to a User
A user story is not a task. It’s not a feature. It’s not a requirement. It’s a promise to have a conversation about a user need.
Ask: “Who is this for? What do they want? Why do they want it?” If you can’t answer those in a way that makes sense to a human being—not a tester or a developer—you’re not writing a story.
Here’s what a real user story looks like:
  • As a customer browsing the product catalog,
  • I want to filter items by price range,
  • so that I can quickly find affordable options.
The value is in the “so that” clause. The user gains a faster way to achieve a goal.
What Are Technical Tasks (and Why They Don’t Belong in the Backlog)
Technical tasks are things like:
  • Set up the authentication service.
  • Write unit tests for the user login module.
  • Refactor the payment processor to use async queues.
  • Add error logging to the API gateway.
These are essential. But they don’t represent a user experience. No user sees or cares about a logging configuration. They only care if the app works, stays fast, and doesn’t crash.
When you put technical tasks in the product backlog, you’re shifting focus from outcomes to outputs. You’re measuring progress by “how many tasks are done,” not “how many users can now do what they need.” That’s the root of wasted effort.
Why Confusing the Two Causes Real Problems
It Distorts Prioritization
If technical tasks are mixed with stories, the backlog becomes a jumbled list of “things to do.” The product owner can’t prioritize meaningfully because they can’t distinguish between “this helps the user” and “this helps the system.”
Imagine trying to decide between “Implement secure password hashing” and “Add a new filter for product ratings.” The latter has clear user value. The former is a necessary technical step, but it doesn’t help anyone directly. Prioritizing based on effort alone leads to wasted sprints on invisible work.
It Skews Velocity and Delivery Metrics
Velocity measures story points completed per sprint. But if technical tasks are counted as stories, velocity inflates. Teams start to “complete” 30 story points of “work” that no user ever sees.
That’s not progress. It’s deception. It creates a false sense of accomplishment and masks real delivery issues.
It Breaks the Conversation Principle
Agile says: a story is a placeholder for a conversation. But when a technical task is written as a story, the conversation becomes about code, not users.
Instead of discussing “how do we make filtering faster?” the team debates “should we use Redis or a database index?” That’s not a conversation about value. It’s a technical design meeting.
How to Separate Technical Tasks from User Stories
Use a Two-Tier Backlog Structure
Keep your product backlog focused on user outcomes. Use a separate list for technical work—what some call “spikes,” “refactoring,” or “infrastructure tasks.”
Here’s how to structure it:
Backlog Type Examples Who Owns It?
User Story As a shopper, I want to save items to my wishlist so I can return later. Product Owner
Technical Task Set up Redis caching layer for product search results. Lead Developer / DevOps
Spikes Research performance impact of full-text search vs Elasticsearch. Dev Team
Only user stories go into the main backlog. Technical tasks belong in a dedicated team backlog or technical debt log.
Ask the “So That” Question Every Time
Before writing or accepting any story, ask:
“Is this about something a user can see, feel, or benefit from?”
If the answer is no, it’s not a user story. It’s a technical task.
Try this:
  • “I want to add pagination to the search results.” → No user value. Not a story.
  • “I want to add pagination so I can load results faster.” → Still about the system, not the user.
  • “As a user, I want search results to load in under 1.5 seconds, so I don’t lose interest.” → Now we’re talking. Value is defined.
Reframe Tasks as Conditions of Satisfaction or Acceptance Criteria
Sometimes, technical work is needed to enable user value. That’s fine. But the story should still be about the user.
Example:
As a customer,
I want to filter products by price range,
Acceptance Criteria:
- The filter must allow setting a min and max price.
- Results must update in real time without page refresh.
- The filtering must work under 500ms latency, even with 100,000 items.
The “500ms latency” condition is a technical requirement—but it’s part of the acceptance, not the story itself.
  • Mistake: Writing “I want to use React hooks” as a story.
  • Fix: Reframe it: “As a frontend developer, I want to use React hooks so that I can reuse logic across components and reduce code duplication.” But even this is still not user value. Better: “As a user, I want the app to respond instantly to filter changes, so I don’t feel stuck.”
  • Mistake: A story titled “Fix login timeout bug.”
  • Fix: The user doesn’t care about timeouts. They care about not being locked out mid-task. Rewrite: “As a logged-in user, I want the session to stay active during inactivity, so I don’t lose progress when I step away.”
  • Mistake: A backlog item that says “Refactor the payment service.”
  • Fix: This isn’t a user story. Move it to the technical debt log. If it’s needed to enable a story, attach it as a dependency.
Final Takeaways
  • Never confuse technical tasks with user stories. One delivers value, the other supports delivery.
  • Use a two-tier backlog: user stories in the main product backlog, technical tasks in a separate list.
  • Always ask: “Does this help a user?” If not, it’s not a story.
  • Acceptance criteria can include technical conditions, but the story must remain user-focused.
  • Engineering stories confusion leads to misaligned priorities, inflated velocity, and wasted effort.
Remember: a story is not a task. It’s a conversation starter about user value. When you get that straight, your team stops building things nobody wants—and starts delivering what matters.
What’s the difference between a user story and a technical task?
A user story captures a user’s need or desired outcome. A technical task is work that supports delivery but doesn’t provide direct user value. For example: “I want to filter products by price” is a story. “Add a new database index for price columns” is a task.
Can technical tasks be part of a user story?
Yes—but only as acceptance criteria or conditions of satisfaction. The story itself must focus on user value. Technical work should not be the story.
Why is engineering stories confusion a problem in Agile teams?
It leads to misaligned priorities, inflated velocity, and a lack of transparency. Teams may “complete” technical work but deliver no visible value. This erodes trust in the backlog and undermines the Agile principle of delivering working software frequently.
How do I know if a task is really a user story?
Ask: “Would the user notice or care about this?” If not, it’s a task. If yes—rephrase it to focus on the user’s benefit, not the technical method.
Can technical tasks be estimated and tracked in sprints?
Yes—but only in a separate technical backlog. Track them separately from user stories. Do not include them in story points or velocity calculations.
What if the team insists that “the tech work is the story”?
Challenge the assumption. Ask: “Who benefits from this?” If the answer is “the system” or “the developers,” it’s not a user story. Redirect to a value-driven framing. Use examples from real users to clarify expectations.
