Evaluating the Success of a Fishbone Analysis
Estimated reading: 6 minutes 49 views
Too many teams treat the completed Fishbone diagram as a finish line. They draw the bones, assign causes, and walk away—only to see the same problem return in a month. The real work begins after the diagram is full. I’ve seen this play out across manufacturing floors, software sprints, and healthcare operations. The missing piece? A structured way to evaluate whether the analysis truly solved the problem.
Simply identifying causes is not enough. What matters is whether those causes were validated, whether the corrective actions worked, and whether the problem solving outcomes were measurable. Without evaluation, you’re just collecting ideas—no different from a brainstorming session with no follow-through.
This chapter walks you through the critical steps to evaluate fishbone analysis. You’ll learn how to define success, track measurable outcomes, and close the loop with feedback. No theory. Just field-tested methods I’ve used in over 200 root cause sessions across industries.
Why Evaluation Is the Hidden Step in Problem Solving
Most guides stop at “draw the diagram.” But the power of Fishbone thinking lies in its ability to generate insight, not just structure. Without evaluation, you risk building on assumptions.
I once facilitated a session for a logistics team that identified “inadequate training” as a root cause of delivery delays. They implemented training—but delays persisted. A year later, we re-evaluated the analysis and discovered the real issue: scheduling software not aligned with warehouse capacity. The original cause was real, but not the primary one.
Evaluation ensures you’re not just solving a symptom, but verifying the actual root cause. Here’s how:
  • Revisit the problem statement—was it clear, measurable, and actionable?
  • Trace each selected cause to real data or evidence, not just opinion.
  • Link corrective actions directly to validated causes—no guesswork.
  • Measure impact over time—before, during, and after implementation.
Without this, you’re not conducting an analysis. You’re just documenting what people believed.
Key Metrics for Root Cause Validation
Quantitative feedback is the best way to evaluate fishbone analysis. You need metrics that answer: Did the fix actually reduce the problem?
Here are five core root cause validation metrics I use in every evaluation:
  1. Problem frequency reduction—track how often the issue occurs before and after the fix (e.g., defects per day, service tickets per week).
  2. Time to resolution—did incident resolution get faster? (e.g., average repair time dropped from 4 hours to 1.2 hours).
  3. Cost of non-conformance—did waste, rework, or returns decrease? (e.g., $50k/month to $12k/month).
  4. Repeat occurrence rate—if the problem reappeared, was it due to incomplete action or a new root cause?
  5. Team confidence score—on a scale of 1–5, how confident are team members the issue is resolved? (A drop in confidence is a red flag.)
These aren’t just checkboxes. They’re signals. If frequency drops 70% but cost remains high, you may have fixed one symptom but not the core inefficiency.
Creating a Fishbone Effectiveness Review Process
Start with a simple review framework. I recommend a 30-day post-implementation check-in—no more, no less. Here’s how to structure it:
Review Step Action Owner
Revisit original problem statement Compare current state to initial definition Facilitator
Verify cause-action alignment Check if each action responds to a validated cause Team
Evaluate metric progress Compare pre/post data for all key indicators Data Analyst
Identify lingering issues Document any recurring incidents or new patterns Team
Update the Fishbone diagram Mark validated causes, add outcome status Facilitator
This process turns a static diagram into a living document. It shows not just what was done, but whether it worked.
Measuring Problem Solving Outcomes
Not all outcomes are quantitative. Some are qualitative, but still measurable. For example:
  • Customer satisfaction scores increased from 3.4 to 4.6 post-fix.
  • Team morale improved—measured via anonymous pulse survey.
  • Incident reports decreased by 60%, and no new cases cited the same root cause.
These outcomes confirm that the fix wasn’t just applied—it was effective.
Use this checklist to assess your problem solving outcomes:
  • Did the primary measure show improvement?
  • Did team members report confidence in the solution?
  • Was the fix sustainable beyond 30–60 days?
  • Did it prevent related issues from emerging?
  • Can the solution be replicated in similar processes?
If you answer “no” to any of these, the analysis isn’t fully successful—yet.
Iterating for Lasting Improvement
Evaluation isn’t a one-time event. It’s part of a cycle.
When the data shows the fix didn’t work, don’t discard the Fishbone. Use it again. Go back to the diagram and ask: Was the right cause selected? Was the action incomplete? Did we miss a dependency?
I once worked with a software team who implemented a fix for slow deployment times. The Fishbone showed “inadequate automation” as a root cause. They added CI/CD pipelines—but builds still lagged. Re-evaluation revealed the real issue: server resource contention during peak hours. The original cause was valid, but incomplete.
That’s why iteration is critical. Every evaluation is a new opportunity to refine your understanding. Use the same Fishbone template to document:
  • What worked
  • What didn’t
  • What new data emerged
  • What to test next
Think of it as a quality feedback loop, not a one-off report.
How do I know if I’ve found the real root cause?
Ask: Would the problem disappear if this cause were eliminated? If yes, and data confirms it, it’s a strong candidate. Test with a controlled experiment if possible. Never rely on consensus alone—validate with metrics.
What if the problem comes back after a fix?
Re-evaluate the Fishbone. The cause may have been partially correct but not comprehensive. Look for hidden dependencies, process handoffs, or environmental factors. Re-apply the analysis using updated data.
Can I evaluate a Fishbone without data?
Not reliably. Data gives credibility. If data isn’t available, use proxy indicators—e.g., customer complaints, team feedback, or incident frequency. But always aim for measurable outcomes.
How often should I review a fishbone analysis?
Do a formal review 30 days after implementation. Then re-check every 90 days. Adjust frequency based on risk or complexity. High-impact problems need monthly reviews.
What if multiple causes were selected but only one was fixed?
Track outcomes for each cause independently. If the fix worked, the data will show a reduction in the problem metric. If not, the unaddressed causes are likely still in play. Prioritize based on impact.
How do I communicate evaluation results to leadership?
Use a simple summary: “Problem: X. Fix: Y. Outcome: Z% reduction in X. Recommendation: Sustain.” Lead with the impact. Avoid jargon. Show the before-and-after data. Leadership wants results, not diagrams.
