When to Move from CRC to UML
Время чтения: 7 мин. 201 просмотров
There’s a quiet turning point in every collaborative design session—when the buzz of brainstorming gives way to clarity. That moment isn’t defined by a deadline or a checkbox. It’s when the team stops asking, “What could this be?” and starts affirming, “This is how it works.” That shift is your cue to move from CRC to UML.
Over two decades of guiding teams through design workshops, I’ve seen countless groups rush the transition—only to struggle with ambiguity. I’ve also seen teams wait too long, losing momentum and valuable insights. The sweet spot lies not in timelines, but in intent: when the design has become a shared mental model, not just a set of paper notes.
When to move CRC to UML isn’t about how many cards you’ve filled or how many iterations you’ve run. It’s when the collaboration patterns feel stable, responsibilities are unambiguous, and the team agrees on the structure. That’s not a formality—it’s a signal that a shared understanding has taken root.
Recognizing the Readiness Cues
Formalizing a CRC model into UML isn’t a technical chore. It’s a decision rooted in design maturity. Here are the real-world signals I’ve come to trust.
1. Shared Understanding Across Roles
When developers, product managers, and QA members can all point to the same class and explain its responsibility without hesitation, the team has reached consensus.
That shared clarity is rare early on. It usually emerges after a few rounds of discussion where roles are refined, responsibilities are re-examined, and dependencies are clarified.
Wait for it. Don’t force the handoff. Premature transition leads to misaligned assumptions.
2. Stable Collaboration Patterns
Collaborations—those lines between CRC cards—are more than arrows. They’re relationships with intent. If the team can trace how a Customer interacts with a Cart, and how the Cart talks to a PaymentProcessor, then the interaction flow is solid.
When these relationships no longer change with every discussion, you’re ready to model them formally.
3. Minimal Open Questions About Responsibilities
Ask the team: “What’s the one thing we’re still uncertain about?” If the answer isn’t about class boundaries or behavior, but rather about edge cases or exceptions, then the core model is stable.
Reserve edge-case analysis for later—once the structure is clear. Trying to model exceptions during CRC brainstorming only clutters the design.
Project Milestones That Signal Readiness
While design maturity is the true indicator, project context often provides clear timing cues. These aren’t rigid rules, but pragmatic anchors.
  • After sprint planning or backlog refinement – If the team has just committed to a user story that requires a new domain model, CRC is a natural starting point. Once the model emerges, move to UML for documentation.
  • Before technical design approval – UML is often required for architecture review boards. Use the CRC-to-UML handoff as a stepping stone to formal sign-off.
  • At the start of implementation – When developers begin coding, having a UML diagram ensures consistency. CRC is great for discovery, but code is built from models.
  • After team feedback cycles – If you’ve run a workshop with cross-functional input and no major rework is suggested, the model is likely mature enough for formalization.
These aren’t triggers to act immediately. They’re signs to pause and assess.
Checklist: Is Your CRC Ready for UML?
Use this checklist during your final design review before transitioning. If you can confidently answer “yes” to all, you’re ready for the CRC handoff point.
Criterion Yes / No
Team agrees on all class responsibilities without contradiction ____
Collaboration paths are consistent across all roles ____
No critical responsibilities are missing or ambiguous ____
Class boundaries are clear and well-separated ____
Team has reviewed and approved the model ____
When every box is checked, you’re not just ready—you’re set.
Modeling Workflow Timing: A Practical Timeline
Understanding the rhythm of your team’s workflow helps you time the transition correctly. Here’s how I’ve seen it unfold in real projects.
  1. Week 1–2: CRC Brainstorming – Teams explore roles, responsibilities, and interactions. The goal is exploration, not perfection. No UML yet.
  2. Week 3: Refinement Session – Review the model. Eliminate duplicates, clarify responsibilities, resolve conflicts. This is where the model stabilizes.
  3. Week 4: CRC Handoff Point – The team formally agrees on the current state. This is the moment to begin the transition to UML.
  4. Week 5: UML Documentation – Using a tool like Visual Paradigm, convert the CRC model into a class diagram with attributes, methods, and relationships.
This timeline isn’t fixed. It varies by team, project, and domain complexity. But the pattern holds: discovery first, then formalization.
The key is not the calendar—but the team’s confidence in the model.
Common Traps in the Transition
Even when the team is ready, missteps can happen. Here’s what to watch for.
  • Over-abstracting too soon – Turning every class into an abstract base class or interface because “it might change” is a sign of premature design. Wait for patterns to emerge.
  • Ignoring naming consistency – CRC cards often use informal terms. Before moving to UML, standardize naming: OrderItem not Order item.
  • Forgetting visibility – CRC doesn’t track access levels. In UML, + (public), - (private), and # (protected) matter. Don’t skip this step.
  • Missing multiplicity – A collaboration in CRC might imply “one or more.” In UML, that becomes 1..*. Always define cardinality.
These are not errors in the model—they’re omissions in translation. They happen when teams rush the transition without a clear process.
What to Do Instead: A Gentle Transition Strategy
Don’t force a full handoff. Instead, use a phased approach.
  1. Map CRC to UML in parallel – Have one person sketch the UML diagram while the team reviews the CRC model. This ensures alignment.
  2. Use a shared tool – Tools like Visual Paradigm allow time collaboration. Draw the class diagram as the team discusses.
  3. Document decisions – For each class, add a small note: “Why is this public?” or “Why does this have a collection?” This preserves intent.
  4. Review with stakeholders – Show the UML diagram to non-developers. If they understand it, the model is clear.
Transition CRC to UML not as a one-time event, but as a shared journey of clarity.
When is the best time to convert CRC cards to UML?
When the team has reached a stable, shared understanding of responsibilities and collaborations. This usually happens after 2–3 refinement cycles, once feedback cycles have settled.
Can I move from CRC to UML in one session?
Yes—but only if the model is mature. In practice, it’s better to split the work: one session for finalizing CRC, another for drafting the UML diagram. This prevents fatigue and ensures quality.
What’s the difference between CRC handoff point and UML handoff?
The CRC handoff point is the moment the team agrees the model is ready. The UML handoff is when the diagram is complete and reviewed. They’re not the same—handoff point is about agreement, UML handoff is about completion.
Should I use UML even if my team uses agile practices?
Absolutely. Agile doesn’t mean no documentation. UML is a tool for clarity, not bureaucracy. Use it to document domain models, not to write specifications. Keep diagrams focused and minimal.
How do I handle disagreements when transitioning CRC to UML?
Use the model as a discussion tool, not a decision-maker. Revisit the CRC cards. Ask: “What does this class do?” “Who owns this responsibility?” Align around intent, not notation.
What if my CRC model changes after I’ve started UML?
That’s normal. Expect evolution. Use versioning or annotations to track changes. The UML model should reflect the current consensus, not a snapshot from earlier. Keep the flow alive.
Прокрутить вверх
