Practical Application Scenarios
Время чтения: 2 мин. 284 просмотров
Have you ever walked away from a CRC session with solid ideas—but felt stuck when it came to turning those notes into a proper class diagram? You’re not alone. Many teams struggle to bridge the gap between brainstorming and formal modeling, especially in collaborative or agile environments.
This section is designed to help you move beyond the abstract and see how CRC cards translate into real software architecture. Through real-world examples and team-based workflows, you’ll learn how to apply responsibility-driven design in practice—without jumping straight to code.
Whether you’re modeling a library system, facilitating a planning workshop, or aligning design with sprint goals, this section grounds theory in tangible outcomes. You’ll walk away with a clear process, not just another diagram.
Explore how CRC modeling translates into robust class diagrams across real-world and team-based contexts.
  • Case Study: Modeling a Library System from CRC to UML – A full walkthrough of turning brainstormed CRC notes into a complete class diagram, with clear justification for each decision. This is your go-to class diagram example for domain modeling.
  • Collaborative Workshops: Team-Based CRC-to-UML Sessions – Learn proven facilitation techniques to run effective team CRC modeling sessions that build shared understanding and align developers and architects.
  • Integrating CRC Design into Agile Sprints – See how CRC cards inform user story refinement and sprint planning, making your agile modeling workflow both structured and practical.
  • Common Pitfalls When Converting CRC to UML – Identify frequent mistakes like over-engineering, misreading collaborations, and losing behavioral intent—and learn how to avoid them with simple validation strategies.
By the end, you’ll be able to:
  • Translate CRC cards into a well-structured class diagram example with clear relationships and responsibilities
  • Facilitate a productive team CRC modeling session that leads to a shared understanding of the domain
  • Integrate CRC-based design into agile sprints to support iterative modeling and technical refinement
  • Recognize and correct common CRC to UML errors that undermine clarity and scalability
  • Use CRC modeling as a foundation for software modeling best practices in team environments
  • Apply a lightweight, effective CRC to UML mapping process in real projects
These aren’t just theory exercises—they’re scenarios you’ll encounter in classrooms and real projects. As you progress, you’ll see how a simple idea can evolve into a robust, maintainable model, backed by experience and shared insight.
Прокрутить вверх
