Model Assessment: How to Know When You’re Done
Время чтения: 7 мин. 62 просмотров
One small decision sets apart those who finish their BPMN diagrams with confidence and those who endlessly tweak them: deciding upfront what «done» really means. Too many start by drawing flow arrows and end up checking off boxes only after a stakeholder says “This feels off.” I’ve seen teams spend weeks refining a single process, only to realize they were optimizing for visuals, not clarity. The right choice? Define your success criteria before you draw the first symbol.
BPMN model assessment isn’t about perfection. It’s about alignment. When stakeholders—technical, business, and operational—can agree on the meaning of a diagram, you’re ready. In this chapter, I’ll walk you through the four pillars of model maturity: completeness, clarity, correctness, and stakeholder buy-in. You’ll get a practical BPMN review checklist, real validation tips, and the mindset shift needed to move from doubt to decision.
What Does “Done” Really Mean in BPMN?
Too many learners assume a model is complete when all the boxes are filled and the flows connect. That’s a trap. A diagram is only complete when it answers three questions: Who needs to understand it? What are they supposed to do? And how do they know they’ve done it right?
Ask yourself: Does your model reflect the actual process, or just a simplified version? I once worked with a team modeling a loan approval process. They had every step, but left out three key decision points involving credit score thresholds. The model looked fine—until auditors asked, “How do you determine rejection?” That’s when the real work began.
Model maturity isn’t measured by how many elements you’ve added. It’s measured by how well the model communicates intent to its audience. A model that’s clear to a developer may confuse a business analyst. That’s why assessment must consider both logic and audience.
Core Criteria for BPMN Model Assessment
Assessment isn’t a one-time event. It’s a continuous evaluation built on four measurable criteria. I use these in every project, no matter the size.
1. Completeness: No Missing Links, No Blank Flows
Every process must begin with a start event and end with an end event. A model without one or both is not a process—it’s a fragment.
Check for:
  • At least one start event (default: message, timer, or none)
  • At least one end event (terminate or completion)
  • Valid sequence flow from start to end with no orphaned activities
  • Every decision point has both outcomes accounted for (yes/no, pass/fail)
If you’ve drawn a gateway, ask: “What happens if this condition is true? What if it’s false?” Both paths must lead somewhere meaningful.
2. Clarity: The Audience Should Understand Without Asking
Clarity isn’t about how pretty your diagram looks. It’s about how easily someone can follow it. A model that takes five seconds to understand by a non-technical person is more valuable than one that takes 30 minutes.
Apply these rules:
  • Use plain language in labels. Avoid jargon like “initiate,” “validate,” “escalate.” Instead, use “submit application,” “check credit score,” “forward to manager.”
  • Keep swimlanes focused. One role per lane. If a task belongs to both IT and Finance, split it or label it “Shared.”
  • Use consistent naming. If you call a task “Approve Request” in one place, don’t call it “Review” elsewhere.
  • Group related tasks. If you have five steps in a row before a decision, consider a sub-process.
BPMN model maturity grows when your audience doesn’t ask “What does this mean?”
3. Correctness: Logic that Reflects Real Work
Even a perfectly laid-out diagram fails if it doesn’t match how work actually happens. I’ve seen models with “Review” tasks that happened before “Submit,” or “Approve” steps occurring without a formal request.
Validate correctness with these actions:
  • Walk through the model step-by-step as if you are the person executing it.
  • Check every decision point: Is the condition clear? Can it be tested? (e.g., “Is credit score ≥ 650?” is testable. “Is the applicant good?” is not.)
  • Verify that parallel branches make sense. Two tasks running simultaneously only when both are needed.
  • Ensure events are triggered by actual inputs. A “Timer” event must specify the time. A “Message” event must name the sender.
Correctness isn’t a feature—it’s the foundation. Without it, the model becomes a map to nowhere.
4. Stakeholder Alignment: Everyone Sees the Same Process
My biggest insight? A model is not complete until the people who will use it agree it’s right. I’ve seen diagrams approved by IT, only to be rejected by operations because they weren’t involved in the modeling.
Use this simple step:
  • Host a 30-minute walkthrough with key stakeholders: the process owner, a frontline worker, and a manager.
  • Ask: “Does this match what you actually do?”
  • Listen for “No, it’s different here.” That’s not feedback—it’s a red flag.
When stakeholders can say “Yes, that’s how we do it,” your model has achieved alignment. That’s the final milestone.
BPMN Review Checklist: Your Daily Guide to Model Maturity
Keep this checklist handy. Run it every time you refine a model, especially before sharing with others.
Check Yes/No
Start and end events are present
All decision points have both outcomes defined
Every activity has a responsible role (swimlane)
Language is plain and consistent
Sequence flows are not crossed
Parallel or exclusive gateways are used correctly
Sub-processes are used to reduce clutter
Model has been reviewed by at least one stakeholder
Score: 8–9 = Strong model. 6–7 = Needs minor edits. 5 or fewer = Reevaluate logic or scope.
BPMN Validation Tips from the Field
Here are five practical tips I’ve learned over 20 years of mentoring:
  1. Use Visual Paradigm’s built-in validation—it flags missing events, invalid flows, and duplicate labels. Let the tool catch what you miss.
  2. Test with a real person—ask a colleague unfamiliar with the model to walk through it. If they pause or ask questions, your model needs work.
  3. Color-code paths—use different colors for main flow, alternative paths, and exceptions. This makes decision logic easier to scan.
  4. Limit decisions per diagram—more than three decision points increases cognitive load. Break complex flows into sub-processes.
  5. Document assumptions—add a note: “Assumes approval takes 24 hours maximum.” This prevents misinterpretation.
These tips aren’t just tricks. They’re habits that build BPMN model maturity over time.
When You’re Not Sure: A Decision Tree
Use this simple flow when you’re stuck:
  • Can a non-technical person understand this without help? → No → Simplify labels, reduce complexity.
  • Does every path lead to a clear outcome? → No → Add missing end events or decision logic.
  • Has a frontline worker verified it? → No → Schedule a walkthrough.
  • Does it match the actual process, not a wish? → No → Reinterview the team.
When all answers are yes, you’re ready.
What’s the best way to know when a BPMN model is truly finished?
When the process owner, a frontline worker, and a manager can all confirm the model reflects their daily work and agree on the next steps. No more questions. No more edits.
How do I handle conflicting feedback during a BPMN review?
Use a decision matrix. Rate feedback by impact on clarity, correctness, and stakeholder trust. Prioritize changes that affect more than one criterion. If still stuck, involve a neutral third party—the process owner often resolves it.
Can a model be too simple?
Yes. A model that omits key decisions, roles, or exceptions may mislead. But simplicity is good—just not at the cost of accuracy. The goal is to be clear and complete, not minimal.
Should I validate every model, even small ones?
Absolutely. A small model can still misrepresent a critical step. I’ve seen a single missing approval gate cause a $50,000 compliance risk. Validation isn’t about size—it’s about impact.
How often should I re-evaluate a BPMN model?
Reassess when the process changes, when stakeholders report confusion, or every 6–12 months. Models decay over time, especially when workflows evolve without updating diagrams.
Can BPMN model assessment be automated?
Yes, through tools like Visual Paradigm. They check for syntax errors, missing events, and flow consistency. But no tool replaces human judgment—especially for context, intent, and stakeholder alignment.
