Pitfalls of Over-Structuring with BPMN
Время чтения: 7 мин. 78 просмотров
One small shift in mindset separates those who model realistic workflows from those trapped in overly rigid flows. It’s the difference between designing for what can happen versus what must happen. I’ve seen teams spend weeks building BPMN diagrams that follow every possible branch for exceptions—only to discover the model breaks when a real user deviates from the path.
That’s the core problem: mistaking control for clarity. BPMN excels at modeling predictable, rule-based processes. But when applied to adaptive work—like troubleshooting, investigations, or customer disputes—forcing every decision into a flowchart creates a brittle model. The real issue isn’t the tool. It’s the belief that every path must be planned in advance.
This chapter reveals how BPMN modeling mistakes emerge from over-engineering, and how you can avoid them with practical BPMN best practices. You’ll learn when to stop modeling decisions and start trusting judgment.
When Over-Structuring Becomes a Design Failure
BPMN was never built for uncertainty. It thrives on sequence, gateways, and clear transitions. But when those same elements are applied to situations where the next step depends on human insight, the model becomes a liability.
I once reviewed a BPMN diagram for a customer service escalation process. It had 14 exclusive gateways, each checking for a different reason—“Did the customer mention refunds?”, “Was the complaint submitted after hours?”, “Did the agent apologize?”. The flow was exhaustive, but unrealistic. In practice, agents didn’t answer all questions in order. They adapted. The diagram didn’t reflect behavior—it reflected an ideal.
Over-structuring in BPMN leads to:
  • Unrealistic assumptions about user behavior
  • Overly complex decision logic that’s hard to maintain
  • False sense of control and predictability
  • Increased risk of model drift when real work deviates
The Flaw in the Logic
Too many analysts treat BPMN as a decision tree. The problem is, real-world decisions aren’t always binary. They’re contextual, iterative, and often incomplete. A gateway that asks “Is the issue resolved?” might be followed by a “Yes” path that leads to closure—but what if the customer says, “I don’t know, maybe”? The model has no place for ambiguity.
BPMN doesn’t handle uncertainty well. When you force it to, you end up with “if-then” chains that assume every condition is knowable in advance. That’s not process modeling. That’s bureaucracy.
Recognizing the Warning Signs
Here are the red flags that signal you’re over-structurizing with BPMN:
  1. More than 5 gateways in a single sequence flow — If you’re creating a path for every possible decision point, reconsider your approach.
  2. “Yes/No” questions that require external judgment — If the answer depends on expertise, experience, or incomplete data, BPMN may not be the right tool.
  3. Sequence flows that loop back to earlier tasks — This often indicates a need for adaptive control, which BPMN handles poorly.
  4. Tasks with unclear preconditions — If you can’t define a clear trigger or condition for starting a task, the flow is likely too dynamic for BPMN.
These signs aren’t about bad design. They’re about mismatched tooling. BPMN is for structured work. When you see these patterns, ask: Is this process or a case?
Real-World Example: The Insurance Claim That Broke a Flow
A claims team modeled a standard payment approval process in BPMN. The flow included gateways for:
  • “Is the damage below $5,000?”
  • “Is the vehicle insured?”
  • “Was the claim submitted within 30 days?”
  • “Does the driver have a clean record?”
Every gate followed a strict order. But when a complex claim came in involving a stolen car with a disputed title, the adjuster had to pause, gather documents, consult legal, and re-evaluate eligibility. The model couldn’t adapt. The team had to manually override the flow, defeating the purpose of automation.
This wasn’t a failure of the model. It was a failure of tool selection. The process wasn’t repeatable—it was investigative. It required flexibility.
How to Apply BPMN Best Practices
There is a better way. BPMN best practices aren’t about making things more detailed. They’re about making them right. Here’s how to avoid BPMN modeling mistakes:
1. Model Only What’s Predictable
Use BPMN when the sequence is known, the steps are fixed, and the outcomes are deterministic. Examples include:
  • Invoice approval workflows
  • Manufacturing production sequences
  • Onboarding new employees
If the process is defined by rules and clear triggers, BPMN is appropriate.
2. Accept That Flexibility Isn’t a Flaw
Adaptive work isn’t chaotic. It’s intelligent. When a process involves discovery, investigation, or judgment, consider whether CMMN might be better. A case model doesn’t enforce a path—it enables one.
BPMN is a conveyor belt. CMMN is a workshop. Know which one you’re building.
3. Use BPMN for Core Flow, CMMN for Exceptions
Don’t throw out the baby with the bathwater. A hybrid model is often the best solution. Use BPMN for the main workflow, and embed a CMMN case plan for handling exceptions.
For example:
  • BPMN: “Approve customer contract”
  • Subprocess: CMMN case for “Dispute Resolution”
This keeps the main flow simple while allowing complex, adaptive handling of conflicts.
4. Apply Lean Principles to Modeling
Ask: “Can this be simplified?” If a gateway exists only to handle rare exceptions, consider whether that logic should be managed outside the flow.
Use event-driven patterns where possible. Let events trigger actions instead of forcing decisions into sequence. This reduces complexity and increases model resilience.
Decision Checklist: BPMN or CMMN?
Use this quick guide to assess whether you’re over-structuring with BPMN.
Consideration Use BPMN Use CMMN
Sequence is fixed and repeatable ✔ Yes ✖ No
Next step depends on expert judgment ✖ No ✔ Yes
Multiple paths require dynamic decision-making ✖ No ✔ Yes
Work involves discovery, investigation, or documentation ✖ No ✔ Yes
Process is triggered by events, not conditions ✔ Yes ✔ Yes
This isn’t a rigid rule. But if more than two columns favor CMMN, it’s likely the better fit.
Can I use BPMN for an adaptive process if I add many gateways?
No. Adding gateways to cover exceptions doesn’t make BPMN adaptive. It makes the model unwieldy and brittle. You’ll still need human judgment to navigate the branches. CMMN is designed for this kind of work.
What’s the difference between a BPMN gateway and a CMMN sentry?
A BPMN gateway evaluates conditions to determine a path. A CMMN sentry evaluates whether a condition is met before allowing a task to be entered. The key difference: sentries are event-driven and allow dynamic control. Gateways are path-based and enforce sequence.
Is over-structuring always a mistake?
Not always. If the process is highly regulated (e.g., medical device compliance), detailed modeling may be required. But even then, consider using CMMN to manage exceptions, keeping the core BPMN flow simple.
Can I use both BPMN and CMMN in the same process?
Absolutely. This is called a hybrid model. Use BPMN for predictable workflow, and embed a CMMN case plan for handling exceptions, investigations, or ad hoc decisions. This is a best practice in mature organizations.
How do I know if I’m over-structuring?
Ask: “Would a real person follow this flow exactly as drawn?” If the answer is “no,” you’re likely over-structuring. If the next step depends on context, experience, or incomplete information, CMMN is likely the better choice.
What’s the risk of not fixing over-structured BPMN models?
Models become outdated quickly. Teams ignore them. Automation fails. Stakeholders lose trust. You end up with a “digital artifact” that no one uses—because it doesn’t reflect reality.
Key Takeaways
  • BPMN pitfalls arise when the model tries to control unpredictability.
  • Over-structuring leads to fragile, unmaintainable diagrams.
  • BPMN best practices favor simplicity, predictability, and flow clarity.
  • When work depends on judgment, insight, or discovery—CMMN is often the better tool.
  • Hybrid models using both BPMN and CMMN are the future of adaptive process design.
Remember: The best models aren’t the most complex. They’re the ones that reflect how work actually gets done. If your BPMN model feels like a rulebook rather than a guide, it’s time to re-evaluate.
